![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> OK, so it's taken me an entire week to code this up. See what you think
> of it. It definitely works in Firefox 3.5.13, but realistically it ought
> to work with anything that supports XHTML, SVG, JavaScript and DOM
> manipulations.
> To use it, just unzip everything into the same folder, and open the
> XHTML page. Hopefully the controls and the display are self-explanatory.
> (Assuming you know what Huffman codes *are*, of course!)
The pretty graphics just flicker onto the screen then disappear!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The design intention is this: If you click "compress", the browser locks
up and has a heart attack, and then eventually spits out the compressed
bitstream. However, if you click on "step compress", you should get a
bunch of buttons further down the page which you can use to step through
the process one stage at a time. The "abort" button quits the simulation
and unlocks all the controls. The button furthest to the left does small
steps, the button furthest to the right does big steps.
Now, that's what is *supposed* to happen. Whether it actually works in
all browsers is another matter...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
...aaaaaaand I still haven't learned to tell left from right,
apparently. o_O
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Cool - I missed that bit!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I guess this illustrates Darren's point the other day - *everything* is
obvious to the person who designed it...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 22/10/2010 02:41 PM, Invisible wrote:
> To use it, just unzip everything...
Speaking of compression: This is about 35KB of source code, yet 7zip has
squished it into an 11KB file. That's about 68% compression. So half of
what I wrote was "necessary". ;-)
It's ironic really. Writing a program that *does* Huffman compression is
fairly trivial. Writing a program that *demonstrates* Huffman
compression is quite non-trivial. _Especially_ in an untyped, rather
promiscuous language like JavaScript. Man, so many global variables! >_<
Not to mention that function names are global too. Yuck!
So yeah, the program is just a tad buggy in places. I think I could
probably improve my abstractions though. I've already done that several
times
For example, originally the code for each step handled twiddling all the
buttons on and off, etc. Things became drastically easier when I
refactored the whole thing. Now I have a data structure representing
steps, and utility functions that handle moving to the next step, etc.
And a utility function that automatically reads this structure and does
the necessary things to the UI. Suddenly everything becomes much easier.
But hey, we all know that having the right abstractions is critical to
computer programming, right?
I remember when programming a computer required serious tools. Like, we
Windows installed, and nothing else, and write stuff like... well, this.
(IE doesn't support SVG yet though, does it?) You'd have to use Notepad
of course [*shiver*], but you can now program a computer with almost
nothing other than what comes with the OS.
(Of course, if you install Linux you probably get GCC by default anyway.
:-P Along with software for every imaginable task, most of which you
don't want and can't remove...)
Anyway, I'm going to go away and ruminate on this for a while now. No
doubt I'll end up rewriting the whole thing yet again, and it'll be even
bigger and better. It's how I work. I call it "iterative prototyping". ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible escreveu:
> manipulations.
doesn't work on IE8: it never seems to open xhtml files and "downloads"
the file and opens in Firefox instead.
doesn't work in Firefox 3.0.14:
Error: row.children is undefined
Source File: file:///D:/Temp/Huffman-06/UI-SymbolTable.js
Line: 62
it's the same browser used for your previous version.
a game sig: http://tinyurl.com/d3rxz9
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nice!
P.S.: It hangs with one character compression (not that it makes any
sense :))
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 22/10/2010 05:54 PM, nemesis wrote:
> Invisible escreveu:
>> think of it. It definitely works in Firefox 3.5.13, but realistically
>> it ought to work with anything that supports XHTML, SVG, JavaScript
>> and DOM manipulations.
Yeah, I noticed that IE just plain doesn't like XHTML, for whatever reason.
> Line: 62
Hmm, that's an interesting place for it to fail... It's just vanilla DOM
stuff. (Unless something is going screwy earlier than that, resulting in
the variable not pointing to what it should be.)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 22/10/2010 07:49 PM, Florian Pesth wrote:
> Nice!
Thanks. I've spent my entire week developing this.
> sense :))
Yes, I failed to take into account this possibility. (Although I'm
actually a bit surprised about exactly where it fails - it should make
it past that particular step OK.)
In fact it falls over if the input contains only one unique character;
you can have twenty of them, it'll still fall over. It's a limitation of
the algorithm, but the program should fail more gracefully than that.
(If you haven't tried it yet, it fails on empty input too.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
