POV-Ray : Newsgroups : povray.off-topic : Programming language discussion Server Time
7 Jul 2026 20:40:51 EDT (-0400)
  Programming language discussion (Message 31 to 40 of 47)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Programming language discussion
Date: 27 Oct 2010 13:00:16
Message: <4cc85aa0@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> In Haskell, "unions" are a fundamental part of the language. One of the
> fundamental branching primitives is based on them. Nullable fields use
> unions, lists are unions, trees are unions, just about everything ends
> up being a union. [Insert witty Thatcher jokes here.]
  I'm not exactly sure if your concept of "union" is the same as C's
concept of "union". A union in C has a fixed size. It's not a dynamic
data container, like a list or a tree.
Date: 27 Oct 2010 14:27:33
Message: <4cc86f15$1@news.povray.org>
Warp wrote:
> It's not a dynamic data container, like a list or a tree.
Remember that in Haskell these are defined recursively. So a "tree" in this
case is union { struct { tree*left, tree*right }, struct { node data } }
A list is
union { struct {node data, list* next} , struct {node data} }
I.e., what he's calling "tree" would be "node of a tree" in C.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 27 Oct 2010 17:15:47
Message: <4cc89683$1@news.povray.org>
Yeah, I should have been clearer about that. A list *node* is a union. A
tree *node* is a union.
http://blog.orphi.me.uk/
Date: 28 Oct 2010 11:38:40
Message: <4cc998ff@news.povray.org>
  What would the harm be if eg. list nodes were structs instead?
Date: 28 Oct 2010 11:46:52
Message: <4cc99aec$1@news.povray.org>
Nothing. It's just that in Haskell, you can't implement it that way.
[Correction: You can't implement *finite* lists that way.] And, with
unions being a fundamental part of the language, you don't need to.
Date: 28 Oct 2010 13:36:45
Message: <4cc9b4ad$1@news.povray.org>
Since "null" is a union in Haskell to (i.e., it either has data in it or it
has no data in it), this wouldn't really save you anything.
   Serving Suggestion:
Date: 28 Oct 2010 13:41:26
Message: <4cc9b5c6@news.povray.org>
  It saves checking the node type for each single operation you do to any
node in the list. It the node is a struct, its contents are fixed and thus
you don't have to check anything.
Date: 28 Oct 2010 14:00:22
Message: <4cc9ba36$1@news.povray.org>
If the node is a struct, you still have to check if it's the end of the list
or a leaf of the tree.  You still have to do the equivalent of the text in
if (node->next != NULL) ...
In any case, this checking process is built into the syntax of the language.
That (and more) is what is meant by "pattern matching" constructs. So
checking the tag on the union (so to speak) is done in a type-safe way with
pretty much the same amount of work as checking for a NULL pointer.
   Serving Suggestion:
Date: 28 Oct 2010 15:21:06
Message: <4cc9cd22$1@news.povray.org>
On the other hand, in a language where unions appear all over the place,
the implementors go to great lengths to make it really efficient.
Besides, normally just about any code that does stuff to a linked list
ends up doing something like
   while (list != null)
     do stuff;
     list = next node;
So there's a check in there anyway. All we're doing by using a union is
making it a different check.
Date: 28 Oct 2010 15:26:37
Message: <4cc9ce6d$1@news.povray.org>
Perhaps I should elaborate further:
I'm not attempting to argue that unions are such a fundamental feature
that every programming language should have them. I'm just pointing out
that *in Haskell* they are extremely fundamental. Which, clearly, is a
different statement.
