POV-Ray : Newsgroups : povray.off-topic : Poles and zeroes (Or Invisible is Evil...) Server Time
11 Sep 2025 21:39:17 EDT (-0400)
  Poles and zeroes (Or Invisible is Evil...) (Message 1 to 5 of 5)
Subject: Poles and zeroes (Or Invisible is Evil...)
Date: 9 Sep 2010 12:16:28
Message: <4c89085c$1@news.povray.org>
So,
Andrew prodded me a bit with the whole "You know, you could use a linear
filter rather than an fft" bit. It got me thinking about IIR (infinite
impulse response) filters.
I made some offhand remark about IIR filters being exceedingly difficult
to design.
So. I first read a primer on how IIR works. OK, seems simple enough.
Multiply some of the input stream by a few coefficients and multiply
some of the output stream by a few coefficients add it all together, and
you get a filter.
Good. Remarkably simple and very easy to calculate. But how does one
design the coefficients? Poles and Zeros and something called the z
transform, the discrete cousin of the Laplace transform. Laplace
transform.... ooh, isn't that complicated?
I was surprised when I realized just how simple it really is.
Essentially a Fourier transform, but adding exponential curves to the
mix. So you have increasing and decaying waveforms. So, after reading
about that and gaining an understanding on that, I turned to the Z
transform. Which is a bit different. Foremost, it's discrete, of course,
but also uses polar coordinates rather than rectangular.
Now, my understanding of how poles and zeros relate to the way a filter
will respond is this:
The poles and zeros in the s domain are arranged along the imaginary
axis, and their position on this axis determines the frequency they will
affect. The higher the imaginary portion, the higher the frequency, the
real portion affects the exponential attack or decay. Obviously, the
magnitude of the effect is related to their distance from the axis.
Poles cannot be on the positive side of this axis. (The exponent
increases on the positive side, therefore any filter built on that would
be unstable and oscillate)
Now, that's all fine and great for doing nice manipulations to equations
and designing analog filters, but it doesn't quite fit into the discrete
world. Enter the z domain.
The z domain has similar properties to the s domain, only polar. So the
magnitude relates to how the exponent will attack or decay, and the
phase relates to the frequency. The polar orientation of the z domain
actually makes sense when you think about it. There is only a finite
number of frequencies available, and like the DFT, they will reflect at
the halfway point. This is also why poles and zeros are symmetrical
about the Real axis.
So, the polar coordinates will need to be translated to rectangular
before they can be plugged into an equation as complex numbers.
What's the frequency response? In the s domain, it's the slice of the
complex plane along the imaginary axis. In the z domain, it's the
cylinder of the complex plane defined by the unit circle, and only
really the top half of that.
So once you have the coordinates, they need to be plugged into something
to get the coefficients for the filter. That's where the z transform
comes in. Which for each unit of the summation does this:
X[z] = x[0]*z^0 + x[1]*z^-1 + ... + x[n]*z^-n
So then,
The equation for an IIR filter:
y[n] = a0*x[n] + a1*x[n-1] + ... + b1*y[n-1] + ...
becomes, through the Z transform:
H[z] = (a0 + a1*z^-1  + a2*z^-2 + a3*z^-3 ...)/(- b1*z^-1  - b2*z^-2 +
-b3*z^-3 ...)
While I understand what the Z transform does, I'm not quite sure exactly
what steps were taken to arrive at the form presented above.
But with that, it becomes rather easy to translate the locations of
poles and zeros to the coefficients:
for(n = 0; n < n_poles; n++)
z[n] = z[n-1]
for(i = n-1; i > 0; i--)
  z[i] = -p[n]*z[i] + z[i-1]
z[0] = -p[n]*z[0]
The code may be a bit buggy.... I grabbed that from my notes from the
other day.
(Keeping in mind, of course, complex numbers are used in the code above)
Going the other way, however is a different story....
~Mike
Subject: Re: Poles and zeroes (Invisible IS Evil...)
Date: 10 Sep 2010 04:38:13
Message: <4c89ee75$1@news.povray.org>
On 09/09/2010 05:13 PM, Mike Raiford wrote:
> So,
> to design.
And I remember thinking "yeah, it's harder than FIR, but not as hard as
you might imagine".
> you get a filter.
It's like two FIR filters in a feedback loop. Instead of using a
bazillion coefficients to generate the impulse response you want, you
generate it by feedback.
Now, a perfect lowpass filter has sinc(t) as its impulse response. The
sinc function decays as 1/t. A feedback loop can produce a signal which
decays as exp(-t), which is nearly the same (but not quite). Because of
this coincidence, you can build a very good IIR lowpass filter with very
few coefficients. If you wanted to build some completely arbitrary kind
of filter, you'd likely have much more of a problem. But all four common
filter types (i.e., lowpass, highpass, bandpass and bandreject) just
happen to have sinusoidal impulse responses that decay in a nearly
exponential way.
The net result is a fairly good filter with very little computer power.
You don't need to actually *perform* the Laplace transform. Fortunately...
And, just as you have the continuous Fourier transform and the discrete
Fourier transform, you have the Laplace transform (continuous) and the
Z-transform (discrete).
> The poles and zeros in the s-domain are arranged along the imaginary
> What's the frequency response? In the s-domain, it's the slice of the
> complex plane along the imaginary axis. In the z-domain, it's the
Indeed. If you imagine the s-domain as a giant sheet of rubber, the
poles pull it upwards, and the zeros pull it downwards. (Except that
that analogy still doesn't explain why arranging a few poles in a
semicircle makes the sheet approach zero at the edges...) If you look at
the mathematics of a polynomial, it all becomes clear(er).
Let's back up here a moment.
You can take the Fourier transform of any signal. Likewise, you can take
the Laplace transform (or Z-transform) of any signal. I can draw some
random waveform and Z-transform it, and I'll get some sort of result in
the Z-domain.
However, if you take the Laplace transform of a waveform which just
happens to be the solution to a (linear) differential equation,
something very special happens: the resulting function is always the
ratio of two polynomials. Something even more impressive happens, in
fact: the coefficients of this polynomial are *related* to the
coefficients of the differential equation!
When you move to the Z-transform, a similar effect occurs.
If I'm remembering this right (from off the top of my head), you end up with
   T(z) = (a[0] z^0 + a[1] z^-1 + a[2] z^-2 + ...) / (1 - b[0] z^0 -
b[1] z^-1 - b[2] z^-2 - ...)
where a[n] and b[n] are the coefficients from the difference equation
(i.e., the filter coefficients).
Of course, to build a function with specific poles and zeros, you write
   T(z) = (z - r0)(z - r1)(z - r2)... / (z - p0)(z - p1)(z - p2)...
where r0, r1, r2... are the zeros, and p0, p1, p2... are the poles. But
for the previous equation, you want the function's coefficients, not its
roots.
Fortunately, computing the coefficients from the roots is a trivial
matter of opening some brackets.
Unfortunately, computing the roots from the coefficients means solving a
(possibly very high degree) rational polynomial - a highly non-trivial
operation.
But, fortunately, you never need to go in this direction to design a
filter, only to analyse one. (And in that case, you don't need exact
solutions anyway.)
Notice that you do not, at any point, need to *perform* a Z-transform.
It's just that if you take an arbitrary difference equation and
Z-transform it, you see that a rational function plops out, and its
coefficients are related to the original difference equation. Once you
know that relationship exists, you can use it to design filters.
And that's why the Z-transform matters, even though you don't actually
use it yourself.
Next fun thing: Transforming from rectangular to polar coordinates. It's
not as simple as you think it is. If you just transform all the poles
and zeros, the resulting filter doesn't have the same frequency response
as the original. You need to be more clever for that...
Date: 10 Sep 2010 04:42:40
Message: <4c89ef80$1@news.povray.org>
Other fun things:
* If you place a pole and a zero on top of each other, mathematics says
they should cancel each other out. In the real world, this doesn't work
at all! (It's called a pole-zero cancellation, and you want to stay the
hell away from it.)
* An IIR filter is a feedback loop. Feedback magnifies rounding errors.
So after you design your filter, you may find that it doesn't actually
have the frequency response it's supposed to have. (Depending on whether
you use fixed-point or floating-point arithmetic, and at what precision.)
* The more poles a lowpass filter has, the better its frequency response
theoretically becomes. However, more poles increases the passband gain,
so you have to turn down the A-coefficients, while the extra poles keep
increasing the number and magnitude of the B-coefficients. Gradually you
end up with a filter that's less and less sensitive to its input
(A-coefficients), and has higher and higher gain in the feedback path
(B-coefficients). Can you spell "unstable"?
Date: 10 Sep 2010 08:38:34
Message: <4c8a26ca@news.povray.org>
What the whole arctangent thing? Oh, yeah... Thankfully most programming
languages have a function called atan2 ;)
Magnitude is simple to calculate, though. It's just the distance formula
after all.
I only wish I had this enthusiasm for mathematics when I was in school.
It would have made my algebra, geometry and trig classes much more
enjoyable.
> Other fun things:
> hell away from it.)
Ooh, Hmm... lets see: 0/0 .... would that be a big fat "NaN"? I know
that as a denominator approaches 0 the quotient approaches infinity. 0
in the numerator is always 0, but I don't know that 0 divided by itself
is defined.
And yes, it appears that for IEEE floats that is definitely the case (at
least, on the Intel architecture.) that 0 divided by itself is NaN.
Right. I was having a bit of fun with this exact fact the other day with
Falstad's filter applet. I pushed the filter to the point where it would
rounding error slowly crept in. It was interesting to listen to as it
started as white noise, but occasional harmonics would sneak in and
dance around. Eventually the program would give up, claiming
instability. I'm not sure when the applet decides the filter is
unstable, My guess is when a result is infinite or NaN that's it. You
can't adjust gain on that, and it doesn't translate to a finite integer
very well. I suppose you could clip....
Yep. With all filter types there's a limit to the number of pole/zero
pairs you can use before the filter loses stability.
What's also extremely interesting is the fact that the poles/zeros of
the IIR filter can be used to design that filter as an electronic circuit.
~Mike
Date: 10 Sep 2010 10:54:35
Message: <4c8a46ab@news.povray.org>
> after all.
Actually, a complex log() will do it for you quite nicely. But that's
not my point; my point is that if you just transform all the poles and
zeros, the filter's response changes. The tricky part is transforming
from the s-domain to the z-domain while still keeping approximately the
same frequency response.
> enjoyable.
Join the friggin' club! All we did in math classes at school was long
division. Pages and pages and pages of it. No wonder kids grow up
thinking that that's all there is to mathematics...
(Also, "hey, GET OFF MY LAWN!")
>> hell away from it.)
If you try to run a filter with a pole and a zero on top of each other,
what actually happens is that it's wildly unstable. The mathematics says
the two could cancel out and give you a flat response, but in reality
that's not what happens. (Regardless of what type of arithmetic you use
- whether it has a concept of NaN or not.)
When a filter goes unstable, the output magnitude increases
exponentially. It can't be hard to detect; if the filter operates on
numbers +/-1 and you start getting numbers > 1,000, it's probably gone
wrong. ;-)
Only IIR filters have poles. Technically, if you take the Laplace or
Z-transform of an FIR filter, you'll find it has lots of zeros (one for
every point in the kernel) and no poles. But that's not a very useful
way to analyse an FIR filter...
Filter design *began* with using the Laplace transform to design
analogue IIR filters. FIR filters are more or less only feasible with
digital electronics. They're much easier to design, they have far
superior precision, and they require a crapload more compute power.
If you want to make precision alterations to a signal, you want FIR. If
you want to make stuff that sounds cool, you want IIR. ;-)
