> Hmm, interesting. I thought the theorum states that there is no single
> formula that covers all possible polynomials of a given degree. However,
> Wikipedia asserts something far stronger: It seems to claim that you can
> construct a single, fixed polynomial who's solutions (which are also
> fixed) cannot be expressed by radicals.
It's an interesting fact. However, at one point, it occured to me that
we take radicals for granted as computable. Consider sqrt(2). Somehow,
we're OK with expressing a number as "the number which, when squared,
equals two." Yet, we have no way of expressing it otherwise. We've all
seen approximations to this number, we would recognize it if we saw the
first few digits, yet we can't actually communicate it without
describing it in terms of the solution to x*x = 2. (There may be other
properties it has that we could use to describe it, but we still can't
just write it down and point to it, like we can with, say, an integer.
We can never find its precise value, we can only approximate it.)
So, it's kind of interesting that when we can't come up with a way to
describe a number besides "one of the roots of this degree-5
polynomial," we typically consider that less descriptive than the value
of an expression with radicals.
- Slime
I guess the point is, if you say sqrt(2), there are several simple
algorithms that will allow you to compute exactly what number this is.
Whereas if you say "the root of this complicated polynomial", there's no
immediate way of computing it. (You'd have to say *which* root, for
starters...)
The root notation is kind of a standardised way of mentioning the roots
of particularly simple polynomials.
(Indeed, if you say Solve[x^5 - x + 1, x] to Mathematica, it replies
with something like x = Root[1 - #1 + #1^5, 1], which simply means "the
first root of x^5 - x + 1".)
Then again, A/B means "the solution to Bx - A = 0". And if you want to
be pedantic about it, 768 means 7*10^2 + 6*10^1 + 8*10^0.
All of these are *representations of* numbers. The question is how
useful they are, in a given context.
Standard roots are useful in that, for example, Sqrt(8) is clearly
larger than Sqrt(2). But given Root[1 - #1 + #1^5, 1] and Root[1 - #1 +
#1^5, 2], which one is larger? (Actually, at least one of those is
complex, so it's probably not a meaningful question.) Decimal
approximations are less accurate than fractions, yet vastly easier to
compare and do arithmetic with. And so on.
Usually, the roots of an arbitrary polynomial aren't very easy to work
with. But then, a 20-mile formula is no less easy to work on either.
http://en.wikipedia.org/wiki/Chaitin%27s_constant
How about a number that's trivial to describe in words, has an intuitive
meaning, yet is provably impossible to compute?
Quoth the raven:
Need S'Mores!
Invisible wrote:
> Really? I was sure an algebraic number is any number computable using
> only addition, subtraction, multiplication, division and extraction of
> roots.
http://lmgtfy.com/?q=algebraic+number&l=1
Also see the subsection:
http://en.wikipedia.org/wiki/Algebraic_number#Numbers_defined_by_radicals
>> roots.
Right. I think I see what happened here.
An algebraic number is any number that is the solution to a polynomial
equation. And since I thought that all such numbers are constructable by
radicals, I assumed "solution of a polynomial" and "constructable by
radicals" were equivilent definitions for an algebraic number.
Apparently they aren't equivilent. (Which still seems deeply weird to me...)
As I say, I thought the problem was that no single formula could
encompass the solutions to every possible 5th-degree polynomial. I
didn't realise that there are single, fixed polynomials who's solutions
are simply inexpressible.
I suspect that the reason here might be largely historical. IIRC long
ago, the concept of what number could be defined "exactly" was
essentially derived from the Greek notion of which number could be
constructed using only a straightedge and a compass. It turns out that
everything you can write with integers, addition, subtraction,
multiplication, division and square roots can be written in this form.
Thus if you had a number written in this form, you knew that it could be
created with a compass-straightedge construction, but other things like
pi, cube roots, etc. were iffier -- particularly so with roots of
general polynomials. This probably set the stage for looking at
"allowed numbers" as being build by the combination of a set of basic
functions, even when the set of allowed elementary functions was
extended to allow things like nth-roots, exp and log which don't
correspond to circle-straightedge constructions. Nowadays computers
allow us to compute roots to arbitrary polynomials relatively
efficiently, so this way of thinking about things isn't as useful as it
used to be.
Caveat: The above is pure conjecture.
>>> of roots.
> me...)
You'll get used to it soon enough. I'm sure the result was surprising
to many people when it came out. Beautiful bit of math too.
Really? Exactly? I would like to see that algorithm! =)
> starters...)
To my knowledge (which may have big holes in this area), calculating a
square root and finding the root of a polynomial are both typically done
with iterative algorithms that converge on a result (and can't give you
the "true" precise answer). In fact, I think the most common way of
approximating either one is with Newton's method. You illustrate my
point: even though calculating a square root and the root of a
polynomial are similar tasks with similar limitations, you believe that
sqrt(2) can be "computed exactly" whereas you agree that a root of a
polynomial cannot.
The problem of *which* root does complicate things some in the
polynomial case.
Yeah. We just seem to culturally draw the line between what we consider
useful and not useful somewhere between radicals and roots of
polynomials, which aren't very different. I suppose there are reasons to
have the line there, but I don't think many people realize that it's an
arbitrary line.
Slime <pov### [at] slimeland com> writes:
Yes. Once you're in the vicinity of a real root (to keep it simple), you
can calculate it to arbitrary precision.
You can compute it to as much precision as you can compute any other
result. In practise, that's enough.
>> starters...)
> polynomial cannot.
To some extent, it's like the difference between a fraction and a
decimal. The latter is readily comparable and easy to operate on. The
former... less so. (E.g., is 17/21 > 1247/1918?)
If I say Sqrt(5), it is immediately obvious that one such number exists,
is strictly positive, and is somewhere between 1 and 5. If I say "x^5 -
3x^3 + 4x - 6 = 0", it is not immediately obvious how many unique
solutions exist, whether any of them are purely real (and if so, what
their sign is), what the magnitudes of these solutions are, or anything
else. Deducing even these basic facts is quite a bit of work.
In this respect, the Sqrt() function is a kind of "standard form" for
equation solutions. And by putting things into standard forms of one
kind or another, they become more useful.
> arbitrary line.
Arbitrary, perhaps. (It depends on your definition of "useful",
obviously.) In this case, it doesn't look especially arbitrary to me.
Heh, all the best ones are. ;-)
I'm still trying to figure out whether there exists a geometric way to
construct logarithms...
Move your pen along at a speed inversely proportional to the distance from
where you started for X seconds. Or something like that :-)
On 8/10/2010 6:32 PM, andrel wrote:
> On 10-8-2010 17:31, Darren New wrote:
>> clipka wrote:
>>> Yeah, sure. I recite that daily from memory before I go to sleep...
>> This would be a better use of your time:
>> http://en.wikipedia.org/wiki/Feynman_point
> Kate does 116 if I have counted correctly:
> http://www.youtube.com/watch?v=kZSHr5E7fZY
How many digits of pi do you need before your calculation of the volume
of the universe is off by no more than the average volume of a water
molecule?
John
> molecule?
> Regards,
> John
one mol of water is 18 gram is 18 ml hence volume of one molecule of
water is (18×10^-3 /(6.02214179×10^23))=
universe 3×10^80
therefore ratio of these volumes:
3×10^80/(18×10^-3 /(6.02214179×10^23))= 10^106
> molecule?
50 digits allows you to compute the radius of the observable universe to
within the diammeter of a hydrogen atom.
As for whole water molecules, and volumes rather than lengths, I can't
say off the top of my head.
http://blog.orphi.me.uk/
>> volume of the universe is off by no more than the average volume of a
>> water molecule?
>> Regards,
>> John
> universe 3×10^80
How did you measure that ?
What's the speed of the expansion everyone is claiming to happen ?
So, we would be fine with integer of 353 bits, at least for volume
expressed in water molecule... what about an hydrogen atom instead ?
Could computer technology get past the wall of 384 bits for integer one
day ? (and what would they compute ?)
Real software engineers work from 9 to 5, because that is<br/>
the way the job is described in the formal spec. Working<br/>
late would feel like using an undocumented external procedure.
Am 23.08.2010 09:18, schrieb Le_Forgeron:
> day ?
Computer technology already does that. Typically not in hardware, but in
software it's state of the art.
Cryptographic stuff for instance. Current encryption and digital
signature technology typically require integer computations with 1024
bits or more.
It's not really difficult to implement, actually. All you need to do is
think of a processor's "native" integer types as digits. For instance,
on an 8-bit processor you'd perform your computations in base 256.
>> day ?
correction: it was state of the art 40 odd years ago.
>>> water molecule?
>>> Regards,
>>> John
>> universe 3×10^80
I didn't, but it is the value both wolfram and wikipedia give. I assume
it is the best I can do for now.
That wasn't the question ;)
"This machine is state of the art."
"But it doesn't work."
"Well, yes. That's the state of the art, I'm afraid."
Quoth the raven:
Need S'Mores!
