POV-Ray : Newsgroups : povray.off-topic : Damn that's sweet. Server Time
14 May 2026 17:03:29 EDT (-0400)
  Damn that's sweet. (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Damn that's sweet.
Date: 27 Jul 2010 11:20:51
Message: <4c4ef953$1@news.povray.org>
scott wrote:
>> Because when you're talking about thousands of dollars as the smallest
>> increment, that wastes space.
> Oh I see, so it's like a base-10 float?
Not exactly.  It's packed BCD. Two decimal digits per byte. The exponent is
declared at the source code level but isn't stored in memory. It's more like
"take that number that has two decimal places and add it to this number here
that has four decimal places."
>> And usually (at least in modern standards) these numbers go up to
>> something like 38 digits. So why would an "int" be better than packed
>> decimal in terms of processing speed?
> It would avoid the need for custom hardware, but obviously it works out
> faster per $ to get the non-standard CPUs if that's what they actually use.
They're really only non-standard compared to x86. Most of the mainframe CPUs
have had decimal math for years. When you're talking about 38-digit binary
numbers with assorted number of digits after the decimal points, trying to
do all that in pure machine-register-size integer operations is slow. You
don't want slow.
Or, to phrase it another way... You need to print 30 million phone bills
with itemized phone calls today. How much time are you going to spend
dividing by ten in order to be able to print the cost of each call, vs the
storage space you waste by storing the call times and costs as BCD instead
of binary?
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
Date: 27 Jul 2010 12:02:47
Message: <4c4f0327$1@news.povray.org>
> CPUs have had decimal math for years.
Oh, as did the 6502 in its own way, for that matter. As does the 8086.
Date: 27 Jul 2010 12:09:54
Message: <4c4f04d2@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> And, like floating point, it would be quite the PITA to translate scaled
> integer numbers into something you could print efficiently, compared to
> using BCD.
  This CPU broke the 5 GHz barrier. I don't think printing efficiency is
an issue.
> Why would plain integers be *better* than packed BCD for this sort of
> application?
  2's complement binary registers require simpler circuitry to be operated
with, compared to BCD registers, hence making the CPU design simpler (and
hence less expensive).
  The value range of BCD registers is smaller than that of 2's complement
binary registers.
Date: 27 Jul 2010 12:15:07
Message: <4c4f060b$1@news.povray.org>
Until it's time to scale the decimal place.
Add a 30-digit number with two decimal places to a 30-digit number with 4
decimal places in binary.
Now do the same in BCD.
But, surely, Intel's mainframe CPU division doesn't know anything about
efficiency of instructions and data.
Date: 27 Jul 2010 13:08:05
Message: <4c4f1275$1@news.povray.org>
>> mainframe CPUs have had decimal math for years.
The B status flag puts the 6502 into BCD mode. God only knows what that
actually means in practice; I never tried it.
http://blog.orphi.me.uk/
Date: 27 Jul 2010 14:30:00
Message: <web.4c4f2479b519de59dda002d60@news.povray.org>
Another reason for retaining hardware decimal instructions would be for backward
compatibility.  The company I work for has thousands of cobol programs that use
decimal instructions. It would be impossible to upgrade to the new processor
without that feature.  IBM has to insure the upgrade path for it's customers is
as painless as possible.
Isaac.
Date: 27 Jul 2010 15:18:26
Message: <4c4f3102$1@news.povray.org>
On 7/27/2010 8:01 AM, Darren New wrote:
> scott wrote:
>> Why not just store the total pence/cents in an int?
> increment, that wastes space. Because when you add dollars to pennies to
> fractional pennies, you need to do the scaling anyway. Because when you
> print out the number, you wind up doing a whole bunch of divide-by-10's
> anyway, and lots and lots of financial processing involves printing out
> numbers.
The real reason is, to some extent, that, at one time, they "did" only
store the rounded values, then someone figured out how to "add up" those
extra missing bits, and dump them into their own bank account, so now
financial software, unless the coder is a complete idiot, **never**
throws away enough of the data to allow someone to make millions, via
that trick, from rounding errors. ;)
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 28 Jul 2010 08:29:16
Message: <4c50229c$1@news.povray.org>
What do you mean non-standard?  Every single bank, every single
insurance company, every single government tax agency/ministry/dept.,
most airline, universities, and large companies with more than a 1000
employees worldwide has one or more IBM mainframes.
I'd call that "standard"!
Tin foil hat dept:  And they all have a phone line to call back home in
case of problems.  The more paranoid think Big Blue can also use those
phone lines for its own nefarious purposes.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 28 Jul 2010 08:49:38
Message: <4c502762$1@news.povray.org>
> What do you mean non-standard?  Every single bank, every single insurance
> company, every single government tax agency/ministry/dept., most airline,
> universities, and large companies with more than a 1000 employees
And they also have 1000 or more x86 machines each :-)  That's what I meant,
that way more x86/x64 CPUs are manufactured, so obviously they are cheaper.
I just wondered if you worked it out on a performance per $ metric (eg how
many $ equipment do you need to print 30 million bills in 24 hours), would
using the IBM mainframe be cheaper than using a room full of x86 machines?
Date: 29 Jul 2010 09:33:12
Message: <4c518318$1@news.povray.org>
That's a recent development.  Most banks, up to 10 years ago, had 3278
terminals hooked up to 3174 cluster controllers in their branches, not
PCs.  The loan officer probably had a portable (which she used to access
the host-based financial applications anyway, plus a little Excel and
Word here and there), but that's it.
> That's what I
> meant, that way more x86/x64 CPUs are manufactured, so obviously they
> are cheaper. I just wondered if you worked it out on a performance per $
> metric (eg how many $ equipment do you need to print 30 million bills in
> 24 hours), would using the IBM mainframe be cheaper than using a room
Mainframes do way more than overnight batch jobs.  A typical mainframe
environment will allow for 99.999% uptime.  Handle millions of
transactions per day with response times below 5 secs.  A similar
environment made out of x86 or x64 hardware, with the required
redundancy, clustering and load-balancers required to achieve five-9s
uptime (That's less than 25 secs of downtime PER MONTH!) as well has
handle the number of transactions at the same speed will probably be as
expensive, if not more.
That's the main reason banks and airlines (the two industries I'm
familiar with) don't change their systems.
Anyway, by "standard" I didn't mean "Most. Popular. Ever.", I meant that
for its intended use it IS still the de facto standard.
