![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 08 Jul 2010 21:41:39 +0100, Stephen wrote:
>> Indeed, ice maybe, if you haven't had the chance to properly chill it,
>> if it's a cheaper whisky. The better ones, of course, you won't want
>> to do that in order to get the full flavour. ;-)
> Ice maybe in your summer ;-)
Perhaps, but I think even then, not for the good stuff - wouldn't want to
dilute it. ;-)
>>> Slainte Mhath.
>> Do dheagh shlàinte. :-)
> May all your renders be fast and clean. :-D
And yours as well. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> dilute it. ;-)
No of course not but when the water of life is warmer than blood
temperature, something must be done.
And everyone else's too.
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> Why has nobody yet invented a car door which can be opened half way?
> Every car I've ever seen has hinges which try to force the door fully
> open or fully closed.
Actually, on further investigation, it seems my car door does have two
stops. You can have the door shut, 100% open, or 80% open. Which,
obviously, is no use at all if you want the door 30% open because of the
car next to you.
(It also seems that might be the reason the door bounces. If you swing
the door open, the springs try to shut the door until it reaches about
75% open. Then the springs try to force the door open to 80%. Obviously
the momentum of the door makes it overshoot this, and it then bounces
off the end stop.)
Literally, there's so little difference between 80% and 100% that I
hadn't even noticed until now.
(If you think about it, the distance from the edge of the door to the
body of the car is equal to the sine of the angle through which the door
angle. But 80% open is well into the plateau region near the top of the
sine curve (i.e., the difference between 80% open and 100% open makes
almost no difference to how badly you just smashed up the car next to you).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> to dilute it. ;-)
Move to a cooler clime. ;-)
Hear, hear! :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> to dilute it. ;-)
I did, I came back home.
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, there you go. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It doesn't feel like it today at 30° C
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Aye, here it's been pretty miserable as well.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A bit cooler today, Max 25° C
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's a good temp, actually where we're at right now. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
