POV-Ray : Newsgroups : povray.off-topic : Merge hundreds of images together? Server Time
11 Jun 2026 23:14:42 EDT (-0400)
  Merge hundreds of images together? (Message 11 to 15 of 15)
Subject: Re: Merge hundreds of images together?
Date: 2 Jul 2010 21:03:23
Message: <4c2e8c5b$1@news.povray.org>
Darren New wrote:
> Kevin Wampler wrote:
>> the trick was to average pairs of images in a binary tree pattern
> I think that's only going to work if you have a number of images that's
> a power of two. Certainly merging 3 images this way isn't going to
> balance them.
I think I also kept track of a weight for each image to account for
that, but it's a good point that I should have mentioned.
Date: 2 Jul 2010 21:26:59
Message: <4c2e91e3$1@news.povray.org>
clipka wrote:
> Am 02.07.2010 18:26, schrieb Shay:
>> Using Linux?
>> A BIT on-topic; Pictures produced using POV animation.
>> gives a poor result.
> Why not use POV-Ray for the job?
A dedicated tool wouldn't need to load all images into RAM before starting.
Date: 3 Jul 2010 11:39:01
Message: <4c2f5995$1@news.povray.org>
On 07/02/2010 01:16 PM, Darren New wrote:
> Darren New wrote:
>> If you use the textual version of PPM, you can open it in a text editor
> convert xyz.png -compress None xyz.ppm
> Then edit xyz.ppm in a text editor. You'll get a header (P3), the X, Y,
> and maximum data value, then X*Y ascii integers.
> Read em, average em, convert em back.
I should have thought of this; I have written code in Python for
handling PPMs. Only problem is that I have to make and format a list of
the files so that Python can read the list. My Python skills are not
such that I can call a Python program with program(args). Still, a Vim
script should make quick work of that.
Shouldn't need longs. Hope not, at least, I've got no idea how to deal
with them in Python.
  -Shay
Date: 7 Jul 2010 11:55:01
Message: <web.4c34a1ee7dfe797f3771cd8e0@news.povray.org>
>   -Shay
import os
import sys
path=sys.argv[1]
filelist=os.listdir(path)
#print the file list:
print "\n".join(filelist)
for filename in filelist:
  if os.path.isfile(filename):
    #do whatever
and start your script with the folder as a parameter, e.g. ./foo.py
/home/usr/blah
Date: 7 Jul 2010 13:50:26
Message: <4C34BE74.3080803@n.n>
Thank you.
On 07/07/2010 10:49 AM, Aydan wrote:
> import os
> import sys
> path=sys.argv[1]
>      #do whatever
