POV-Ray : Newsgroups : povray.off-topic : The computer project Server Time
15 May 2026 07:39:11 EDT (-0400)
  The computer project (Message 101 to 110 of 180)
Subject: Re: The computer project
Date: 13 Jun 2010 03:18:36
Message: <4c14864c$1@news.povray.org>
On 12/06/2010 9:47 PM, Sabrina Kilian wrote:
> Not all cats are elitist fuzz-and-claws. Some fuss when they are more
> than an arms length away from someone. Mine yowls when he has to use his
> litter in the middle of the night, since it means leaving the room.
> Howls on the way out and back, just to wake me up and let me know that I
> am missed. Could do without that, actually.
criticise politeness. :-)
Have you tried talking back to him?
Best Regards,
Date: 13 Jun 2010 04:43:56
Message: <4c149a4c$1@news.povray.org>
>> I don't know. Maybe it's just because it's Saturday morning and *yet
>> again* I'm sitting all alone in my bedroom feeling bored and lonely,
>> with nowhere to go and nobody to talk to. Perhaps I just need to go
>> listen to some more Neil Sekada or something...
> Don't listen to bored and lonely music when you are bored and lonely.
Apparently I'm listening to a different Neil Sedaka than everybody
else... The one I have is like liquified sunshine in a bottle.
http://blog.orphi.me.uk/
Date: 13 Jun 2010 06:23:31
Message: <4c14b1a3$1@news.povray.org>
On 6/10/2010 3:40 PM, Orchid XP v8 wrote:
> nemesis wrote:
>> and you say you're a retard... o_O
> Well, I _did_ just spend several weeks building a simulated model of a
> trivially simple computer when I could just, uh, use a real one...
> When you think about the amount of _useful_ stuff I could have done with
> that much time and energy, you start to understand why I feel
> unfulfilled with my life. :-(
Are you going to re-create the model in Dwarf Fortress? :P
http://isometricland.com
Date: 13 Jun 2010 06:44:12
Message: <4c14b67c$1@news.povray.org>
...so anybody have anything to say about the design itself? ;-)
Date: 13 Jun 2010 10:13:08
Message: <4c14e774$1@news.povray.org>
Am 13.06.2010 12:44, schrieb Orchid XP v8:
* Did you think about how to implement a stack (and subroutine calls)?
* The address space is not only piffling, but outright insufficient,
especially given the limited instruction set; some things you could do
about it:
- As your commands are all 2 bytes wide, you can require that they be
16-bit aligned, so you can increase address space available for programs
to 512 bytes (=256 instructions).
- You could further increase the total address space by separating code
from data (Harvard architecture), using two separate "Read" control
lines. (The CPU could still easily be used in von-Neumann-Mode by ORing
the two "Read" lines externally.)
Date: 13 Jun 2010 10:23:35
Message: <4c14e9e7@news.povray.org>
Yes: With great difficulty. ;-)
There are instructions to load and save the PC. Your "stack pointer" is
going to be a RAM register rather than a CPU register. You'll have to
manually incriment/decriment it, which will be absurdly tedious. But it
can be done.
Well, there is that.
I'm not seriously expecting to make a usable computer out of it. I'll
just be amazed if it actually ****ing works at all! Currently it works
in the simulator, but I don't think the simulator is taking gate delays
into account, and I'm really not sure how that affects all the
edge-triggered circuits I've used. (!!) There's also the minor detail
that even the trivial little design I have now is going to take an
absurd number of gates to realise in hardware...
> some things you could do about it:
In other words, make memory 16-bit addressible rather than 8-bit
addressible.
> - Harvard architecture.
That could work...
The other possibility, of course, is to just connect up more address
lines. Makes little or no difference in software, but in hardware I
suddenly have to put a hell of a lot more wires together. ;-)
Date: 13 Jun 2010 13:02:26
Message: <4c150f22$1@news.povray.org>
Am 13.06.2010 16:23, schrieb Orchid XP v8:
>> programs to 512 bytes (=256 instructions).
> addressible.
Well, you could do /that/, too, but I was merely thinking of making the
memory 9-bit addressable, by using a 9-bit program counter and
automatically shifting the value left by 1 bit (filling with zero) when
loading an 8-bit value into the PC.
Sure ;-)
You should really have a look at FPGAs if you want to save the money,
time and hassle of wiring up a hell lot of 74xx gates.
If you want to go for classic 5V logic and thru-hole mounting (as
opposed to SMD), maybe you won't find a suitably "sized" FPGA to fit
your whole CPU inside, but you should surely find some PLCC-packaged 5V
or 3V-5V FPGA to fit at least the complete control matrix; I'd suggest
the Lattice ispMACH 4A5-64/32 44-pin PLCC for the job, which will give
you up to 32 I/O pins with optional in- and/or output flip-flops, 2 more
input-only pins, plus 32 bits worth of flip-flops for internal registers.
That would leave you with one 74xx for each register and each of the ALU
functionalities to wire up, which should lessen the pain already.
Alternatively, you could use another ispMACH for the ALU (which might
also include the X, Y and Z registers), and (if required) a third one
for all the rest.
Or, if you know how to solder SMD packages (or know someone to do that
for you), you could go for something bigger, such as an ispMACH
4A5-128/64 or 4A5-192/96, which should allow you to do all in one chip
(except the main memory).
(The ispMACH 4 series is officially discontinued - which is a pity
because I think the M4A5-64/32 was ideal for experimenting given that it
runs on 5V and fits in inexpensive thru-hole mounted sockets - but some
devices, including the M4A5-64/32 PLCC, are still available even in
stock at Lattice, at prices of about 5$ apiece.)
Date: 13 Jun 2010 14:00:07
Message: <4c151ca7@news.povray.org>
>> addressible.
Oh right, I see...
> Sure ;-)
I did briefly entertain the idea of a 4-bit design. Certainly my CPU
loads 16 bits from RAM on every instruction cycle, yet has only 17 valid
opcodes (not 2^16 or even 2^8). On the other hand, a 4-bit address space
is about as useful as... um...
I have a sinking feeling that if I went to the [extreme] expensive of
getting an FPGA rig, I'd probably then find that I'm too stupid to make
it do anything anyway! :-/
Date: 13 Jun 2010 14:16:50
Message: <4c152092$1@news.povray.org>
Did you see the post about making DF turing complete? Apparently you can
connect waterfalls or dwarfs or something to do NAND gates and build an
entire computer out of it.
Oh, there it is. GIYF.
http://www.boingboing.net/2010/04/15/colossal-turing-mach.html
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 13 Jun 2010 14:18:26
Message: <4c1520f2$1@news.povray.org>
Welcome to writing a FORTH interpreter on the 6502!
