![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Logic Simulator.... For whomever wants to look at it.
Date: 28 May 2010 12:01:01
Message: <4bffe8bd@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
New thread at Andrew's request:
Download Location:
http://sourceforge.net/projects/logicsim/files/
Be sure to read the notes. Requires .NET Framework 3.5
I'll reply to this thread for updates.
This is wiring only, with minimal select and drag features.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Logic Simulator.... For whomever wants to look at it.
Date: 28 May 2010 18:34:54
Message: <4c00450e@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Download Location:
*Downloads source code and Mono*
*Tries compiling*
SimulatorControl.cs(745,34): error CS0103: The name `Properties' does not
exist in the current context
SimulatorControl.cs(757,38): error CS0103: The name `Properties' does not
Tracer.cs(26,38): error CS1502: The best overloaded method match for
`LogicSim.Tracer.Tracer(string, System.Diagnostics.TraceLevel)' has some
invalid arguments
Tracer.cs(14,19): (Location of the symbol related to previous error)
Tracer.cs(26,38): error CS1503: Argument `#2' cannot convert
`System.Diagnostics.SourceLevels' expression to type
`System.Diagnostics.TraceLevel'
Hmm... I think I'll go for the binary :)
*Downloads .exe*
Well, at least it starts.
*Clicks on a wire*
** (LogicSim.exe:15845): WARNING **: GdipSetPenCustomEndCap isn't
implemented
System.NotImplementedException: The requested feature is not implemented
[GDI+ status: NotImplemented]
at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000]
at System.Drawing.Graphics.DrawImage (System.Drawing.Image image,
Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight,
GraphicsUnit srcUnit, System.Drawing.Imaging.ImageAttributes imageAttr)
[0x00000]
at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:DrawImage
(System.Drawing.Image,System.Drawing.Rectangle,int,int,int,int,System.Drawing.GraphicsUnit,System.Drawing.Imaging.ImageAttributes)
Okay, maybe not :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 May 2010 00:15:22
Message: <4c0094da$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 5/28/2010 5:34 PM, Nicolas Alvarez wrote:
>> Download Location:
> *Tries compiling*
> invalid arguments
Oh...
That one looks like an issue with release builds:
There's a conditional there, and the code when DEBUG is not defined is
wrong. I haven't run a release build yet.
> *Downloads .exe*
> *Clicks on a wire*
> implemented
> [0x00000]
> Okay, maybe not :)
What is your execution environment? If you're trying to run it under
mono, I'm pretty sure it won't work. I haven't had any chance to port it
to mono, and it looks like it's missing a few things.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 May 2010 20:58:01
Message: <4c01b819@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> *Downloads .exe*
>> *Clicks on a wire*
>> implemented
>> srcHeight, GraphicsUnit srcUnit, System.Drawing.Imaging.ImageAttributes
>> imageAttr)
>> [0x00000]
>> Okay, maybe not :)
I'm on Debian Linux, 64-bit; with Mono 2.4.4.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 30 May 2010 00:06:10
Message: <4c01e432@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Do you know if Mono will run projects with Linq?
I'd like to be able to port this to mono when it's done. I use some Linq
features on the collections (mostly just a couple of the extension
methods (such as Select and Where) as a convenience)
It looks like a few of the GDI+ things I may have to look out for, I
might recode a few portions of the code that's relying on custom end
caps, since that seems to be a problem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 30 May 2010 01:21:55
Message: <4c01f5f3@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I wrote 200 lines of C# in my life, and it didn't involve Linq or graphics.
Just an HTTP request and some XML parsing :)
I barely know what Linq *is* :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 2 Jun 2010 12:04:53
Message: <4c068125$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Download Location:
I've updated the files online. Now contains a toolbar, menu bar,
selection and dragging works, and the properties list populates with
some basic information (And a small amount of stray data that needs to
be hidden from the property list)
Release note contains more information on hotkeys and such.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 2 Jun 2010 12:11:42
Message: <4c0682be$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You might wanna start putting version numbers on this stuff, so people
can tell what version they have / what's on SF.
Just a friendly suggestion. ;-)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 2 Jun 2010 17:08:30
Message: <4c06c84e$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sure, but not right now. It's not even a usable application at this
point. It's basically a release to test and get feedback.
Maybe I'll start giving it version strings like "ui-test-0.0.02-06-2010"
Seems a bit silly, though.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 3 Jun 2010 07:47:40
Message: <4c07965c$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I usually just assign a unique number to each one I release. Like, the
first one is Test01.exe, the next one is Test02.exe, and so on. Just a
small thing.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
