POV-Ray : Newsgroups : povray.off-topic : Exotic electronics Server Time
12 Sep 2025 06:51:15 EDT (-0400)
  Exotic electronics (Message 1 to 10 of 24)
Subject: Exotic electronics
Date: 4 Jun 2010 05:22:46
Message: <4c08c5e6@news.povray.org>
On Monday, my father and I went on a little father-and-son expedition to
the outer reaches of his loft. We found some really far-out stuff up
there. Most of it was to do with electronics, although I also found a
gas cylinder marked "CO2", and a small bottle of white powder marked
"KNO3"...
Some capacitors are small brown things like little chocolate buttons.
(But significantly less tasty.) Then there's the "electrolytic" ones,
which are small blue things that look like they belong in a licorish
all-sorts bag. Some a really small (about 5mm diammeter). Some are a bit
bigger (15 mm diammeter).
When I was in my dad's loft, I found capacitors the size of friggin'
soda cans! o_O WTF are *those* for??
(I mean, are they that size because they have a higher capacitance or
something? I gather a capacitor is one of the few components where the
physical size of the device determines its electronical characteristics...)
Also, most transformers are small square lumps about the size of your
thumb. (Then again, you use them on 5V electrics.) I saw a transformer
up there that was about 15cm along all three edges. Presumably in this
case the size is to allow it to handle higher current without melting.
And then there were the transistors. Normal transistors are tiny black
plastic cylinders with long legs. Occasionally you'll see a transistor
that's metal and slightly fatter. But my dad showed me some transistors
which were about 4cm across, bolted to a heat sink the size of my car's
radiator. Apparently these are "power transistors". o_O
We also found a box containing more 14-pin DIL sockets then it is
humanly normal to have. And a bunch of 7400-series chips. In particular,
these are the original, obsolete, 7400 chips. 7400, 7408, 7402, etc. Not
74LS00 or even 74S00, but vanilla 7400 TTL. They're that old.
We also found a stack of unopened boxes containing LEDs. Now when I was
at Maplin I bought a bag of mixed LEDs - which is great, because you get
a lot of LEDs for not much money, but OTOH they're all different. Now I
have a matching set!
Subject: Re: Exotic electronics
Date: 4 Jun 2010 05:54:44
Message: <4c08cd64$1@news.povray.org>
My dad would bring home/have all sorts of sizes of stuff like that.
Probably still has an arbitrary mass of otherwise unidentifiable
components.  (He worked at GTE Airfone for most of my childhood.)  The
bigger capacitors would go with heavier-duty electronics...a good UPS, I
imagine, probably has one or more of them.
Guess it just depends what sub-branch of electrical engineering your dad
is into and you get to see as a kid.
Tim Cook
http://empyrean.freesitespace.net
Date: 4 Jun 2010 07:24:27
Message: <4c08e26b$1@news.povray.org>
Hmm, what to do with all that stuff. Caps, power transistor, and a few
transformers.
I know!
Railgun!
Date: 4 Jun 2010 08:16:13
Message: <4c08ee8d$1@news.povray.org>
> transformers.
Hehe... with a handfull of caps, some diodes and a 555 timer as the
clock source, you can create your very own chargepump.
(Plug it into http://www.falstad.com/circuit)
$ 1 5.0E-6 10.20027730826997 50 5.0 50
d 144 112 192 112 1 0.805904783
d 192 112 240 112 1 0.805904783
d 240 112 288 112 1 0.805904783
d 288 112 336 112 1 0.805904783
c 192 112 192 208 0 1.0E-5 4.466071842606139
c 240 112 240 256 0 1.0E-5 8.960381260256856
c 288 112 288 208 0 1.0E-5 8.419397603519451
c 528 112 528 256 0 1.0E-5 20.732461600283102
g 336 256 336 336 0
w 432 256 336 256 0
w 336 256 240 256 0
w 288 208 192 208 0
w 192 208 144 208 0
R 144 112 80 112 0 0 40.0 5.0 0.0 0.0 0.5
R 144 208 80 208 1 2 10000.0 2.5 2.5 0.0 0.5
w 528 112 608 112 2
w 288 208 384 208 0
c 336 112 336 256 0 1.0E-5 12.870708825821993
c 384 112 384 208 0 1.0E-5 12.322975506019386
c 432 112 432 256 0 1.0E-5 16.78270116633109
c 480 112 480 208 0 1.0E-5 16.250773941269088
w 432 256 528 256 0
w 384 208 480 208 0
d 336 112 384 112 1 0.805904783
d 384 112 432 112 1 0.805904783
d 432 112 480 112 1 0.805904783
d 480 112 528 112 1 0.805904783
~Mike
Date: 4 Jun 2010 08:29:19
Message: <4c08f19f$1@news.povray.org>
This, apparently, is why USB flash drives can work. They use a charge
pump to generate the large voltages needed to erase a block prior to
reprogramming it.
Date: 4 Jun 2010 11:57:54
Message: <4c092282$1@news.povray.org>
Wow.  I kind of feel sorry now for all the people who grew up after ICs were
common and don't know how capacitors work or what a power transistor is for.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 4 Jun 2010 13:11:01
Message: <4c0933a5$1@news.povray.org>
> were common and don't know how capacitors work or what a power
> transistor is for.
Any specific reason?
Anyway, I only work with low-power electronics, so I don't know a whole
heap about how to engineer (say) the lifting motors for a gigawatt damn
sluce.
http://blog.orphi.me.uk/
Date: 4 Jun 2010 13:15:18
Message: <4c0934a6@news.povray.org>
> thumb.
I'm about to blow your mind:
http://www.google.com/images?hl=en&source=imghp&q=power
+transformer&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
Jim
Date: 4 Jun 2010 13:22:08
Message: <4c093640$1@news.povray.org>
>> thumb.
Yeah, well *obviously* a transformer than supplies 20,000 homes is going
to be slightly bigger than the one that supplies the 20 mA to the
speaker in your pocket radio. :-P
The thing is, you don't have a transformer like that IN YOUR HOUSE. And
yet, my dad for some reason DOES have this monster transformer...
Date: 4 Jun 2010 13:43:56
Message: <4c093b5c$1@news.povray.org>
>>> thumb.
I do have a pretty good sized transformer in a PSU for an amateur radio
rig in the basement.
Jim
