![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thinking on it a bit, it sounds like unit testing is just a way to add
Eiffel-style programming-by-contract to your code without any actual
language support for it.
Ada - the programming language trying to avoid
you literally shooting yourself in the foot.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I thought the term was "design by contract"?
Well whatever. Contracts seem like a nice idea; you make it clear who's
supposed to check for error conditions - whether it's supposed to be the
caller or the callee. And you can enforce it by enabling checks at
runtime. Having said that, I don't recall using it much myself in my own
code.
On top of that, any kind of testing is going to be easier if a
function's output depends only on its current inputs...
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah. Brain-O.
> code.
Yep. Every time you use "assert" to check your inputs, you're doing that.
Except with minimal language assistance.
Unit testing just takes those asserts outside the function.
Yep. The problem with "unit testing" per se is that it only tests a unit. It
doesn't test anything except the invariants of the unit you're testing.
Eiffel - The language that lets you specify exactly
that the code does what you think it does, even if
it doesn't do what you wanted.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> that. Except with minimal language assistance.
Eiffel has preconditions *and* postconditions, which most people don't
seem to bother checking with assert() calls.
Whilst Haskell does have an assert() function, it seems to be more
popular to use QuickCheck.
QuickCheck does automated randomised testing. Give QC a property that's
supposed to hold for any inputs, and it generates inputs at random and
checks whether the property holds.
The big snag, of course, if that if your code fails only under very
specific, rare circumstances, randomised testing might not hit the bug.
(This is why books on testing talk about testing limits, flow control
paths, etc.)
Also, asserts or design by contract will catch the source of a crash in
a live running program. (Assuming that enabling the tests doesn't slow
the program to the speed of a glacier...)
> unit. It doesn't test anything except the invariants of the unit you're
> testing.
I thought the idea was that you then combine several units into a larger
unit, and test that (and so on, recursively). Then again, maybe that's
what they mean by "integration testing"...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A little thought experiment: How would you write a comprehensive
postcondition to a function that sorts a list/array of elements?
(Assume there is no reliable third-party sorting function available.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorting a container is at best O(n log n), but determining whether one
is already sorted is only O(n). :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here's a better one: You write a compiler. How the **** do you determine
whether it actually works properly? (!)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm, that's not what I asked.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes. The postconditions are checked with unit tests. And people try to check
invariants that way too. And unit tests generally don't try to check loop
invariants.
Again, you're checking invariants, which I find is usually not that useful.
Yes, that's integration testing. Then there's "functional testing", where
you test the program does what the customer actually wants. Then there's
system testing, where you make sure the program does what the customer
actually wants even when interacting with other code (basically).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Trivial.
Forall(i < length-1) assert(j[i]<=j[i+1]);
Basically, the definition of sorting. Of course, you need to be able to put
qualifiers in your assertions.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
