POV-Ray : Newsgroups : povray.off-topic : Logic Simulator.... For whomever wants to look at it. Server Time
7 Apr 2026 17:10:24 EDT (-0400)
  Logic Simulator.... For whomever wants to look at it. (Message 4 to 13 of 53)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Logic Simulator.... For whomever wants to look at it.
Date: 29 May 2010 20:58:01
Message: <4c01b819@news.povray.org>
Mike Raiford wrote:
> On 5/28/2010 5:34 PM, Nicolas Alvarez wrote:
>> Hmm... I think I'll go for the binary :)
>> *Downloads .exe*
>> Well, at least it starts.
>> *Clicks on a wire*
>> ** (LogicSim.exe:15845): WARNING **: GdipSetPenCustomEndCap isn't
>> implemented
>> System.NotImplementedException: The requested feature is not implemented
>> [GDI+ status: NotImplemented]
>>    at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000]
>>    at System.Drawing.Graphics.DrawImage (System.Drawing.Image image,
>> Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32
>> srcHeight, GraphicsUnit srcUnit, System.Drawing.Imaging.ImageAttributes
>> imageAttr)
>> [0x00000]
>>    at (wrapper remoting-invoke-with-check)
>>    System.Drawing.Graphics:DrawImage
(System.Drawing.Image,System.Drawing.Rectangle,int,int,int,int,System.Drawing.GraphicsUnit,System.Drawing.Imaging.ImageAttributes)
>> Okay, maybe not :)
> What is your execution environment? If you're trying to run it under
> mono, I'm pretty sure it won't work. I haven't had any chance to port it
> to mono, and it looks like it's missing a few things.
I'm on Debian Linux, 64-bit; with Mono 2.4.4.
Date: 30 May 2010 00:06:10
Message: <4c01e432@news.povray.org>
Do you know if Mono will run projects with Linq?
I'd like to be able to port this to mono when it's done. I use some Linq
features on the collections (mostly just a couple of the extension
methods (such as Select and Where) as a convenience)
It looks like a few of the GDI+ things I may have to look out for, I
might recode a few portions of the code that's relying on custom end
caps, since that seems to be a problem.
Date: 30 May 2010 01:21:55
Message: <4c01f5f3@news.povray.org>
I wrote 200 lines of C# in my life, and it didn't involve Linq or graphics.
Just an HTTP request and some XML parsing :)
I barely know what Linq *is* :)
Date: 2 Jun 2010 12:04:53
Message: <4c068125$1@news.povray.org>
On 5/28/2010 11:00 AM, Mike Raiford wrote:
> New thread at Andrew's request:
> Download Location:
> http://sourceforge.net/projects/logicsim/files/
I've updated the files online. Now contains a toolbar, menu bar,
selection and dragging works, and the properties list populates with
some basic information (And a small amount of stray data that needs to
be hidden from the property list)
Release note contains more information on hotkeys and such.
~Mike
Date: 2 Jun 2010 12:11:42
Message: <4c0682be$1@news.povray.org>
You might wanna start putting version numbers on this stuff, so people
can tell what version they have / what's on SF.
Just a friendly suggestion. ;-)
http://blog.orphi.me.uk/
Date: 2 Jun 2010 17:08:30
Message: <4c06c84e$1@news.povray.org>
Sure, but not right now. It's not even a usable application at this
point. It's basically a release to test and get feedback.
Maybe I'll start giving it version strings like "ui-test-0.0.02-06-2010"
Seems a bit silly, though.
~Mike
Date: 3 Jun 2010 07:47:40
Message: <4c07965c$1@news.povray.org>
I usually just assign a unique number to each one I release. Like, the
first one is Test01.exe, the next one is Test02.exe, and so on. Just a
small thing.
Date: 3 Jun 2010 07:52:21
Message: <4c079775@news.povray.org>
I especially like how labels are hidden by default. Select something add
a label, watch it not appear, and then realise you have to also set it
to visible. ;-)
Still, you've got a mile further than me, so who am I to criticise?
What the...? Oh, wait, you're American. That explains it.
Date: 3 Jun 2010 10:04:53
Message: <4c07b685$1@news.povray.org>
> to visible. ;-)
Yeah, Inputs/Outputs will likely start with the label on by default.
Wires and such will probably have the label hidden by default.
Pah. I need the perspective of someone who is not writing the program. :)
Explains what?
~Mike
Date: 3 Jun 2010 10:05:44
Message: <4c07b6b8$1@news.povray.org>
> small thing.
Ah. I might do that... or something similar.
~Mike
