POV-Ray : Newsgroups : povray.off-topic : Electronics activity Server Time
1 Apr 2026 15:01:02 EDT (-0400)
  Electronics activity (Message 46 to 55 of 65)
Subject: Re: Electronics activity
Date: 25 May 2010 09:23:38
Message: <4bfbcf5a$1@news.povray.org>
On 25/05/2010 1:07 PM, Mike Raiford wrote:
> It's more about the relay's coil being an inductor. Once the IC
> switches, it will send a high voltage pulse back through the IC, frying
> it nicely. There are ways to get around that, but I'll leave that as an
> exercise to the reader to figure that out.
As Scott said, if you knew more about electronics then you would know
that a back emf diode is an integral part of these circuits and relays
used in process control come with the diodes fitted.
Best Regards,
Date: 25 May 2010 11:55:06
Message: <4bfbf2da@news.povray.org>
Invisible wrote:
> those tiny 1-hole
> wide wire loops are excruciatingly hard to manipulate.
Needle-nose pliers.
And I don't think you're supposed to use that wire for the battery.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 25 May 2010 12:28:28
Message: <4bfbfaac$1@news.povray.org>
On 5/25/2010 2:55 AM, Invisible wrote:
> Darren New wrote:
>> http://www.robotroom.com/Pumpkin/LEDPulsingBreadboard.jpg
>> See how the black cable goes from C1 to C2?
>> Or how the purple cable goes "around the corner"?
> I see...
> Makes it kinda hard to rest the ends of the wires on both battery
> terminals simultaneously when they're utterly rigid though. Similarly,
Seriously, go down to the local electronics supply store and buy a
packet of 9-volt battery clips. It makes life much easier!
~Mike
Date: 25 May 2010 12:37:24
Message: <4bfbfcc4@news.povray.org>
On 5/25/2010 7:08 AM, Invisible wrote:
> I guess it's the way most books refer to circuits as "on" or "off".
> Usually if something is "on" it means it's connected to a power source,
> and if it's "off" then it isn't connected. That's how, e.g., a light
> switch works. It doesn't connect the output to the other pole when you
> turn it off, it just doesn't connect it to *anything*.
Strange... Here's how my mind worked when I encountered the floating
gate = high issue, and not truly realizing logic zero really needs to be
tied to ground:
First I checked the data sheet, and found the information that a
floating input would be interpreted as high. Then I stared at my dip
switch and lamented the fact that it wasn't a SPDT switch. The I
searched the electronics websites for SPDT dip switches, and came up
frustratingly empty. Then started thinking to myself, "How can I make
this work if I only have a SPDT switch" after staring at the circuit I
thought to myself, well, if I connect it to ground with a suitable
resistor, then that should allow the chip to see ground without dumping
tons of current through the switch when its in the on position.
I tried it, and with some trepidation flipped the tiny switch to the on
position and ... it worked just as it was supposed to!
Then I go an research after the fact, playing with the circuit
simulator, and prodding various things in it to find out that yes,
indeed, it does do what I thought it would do. and it makes sense. With
no current from the positive rail, the gate's input can source to
ground. While a voltage is on the positive rail, the gate sinks some of
the current. Exactly what I needed.
A bit more research later and I discovered if I had read a tutorial on
working with logic gates, I would have known about this solution, and
it's called a pull-down or pull-up resistor, depending on which rail it
hooks to.
~Mike
Date: 25 May 2010 12:52:57
Message: <4bfc0069@news.povray.org>
Mike Raiford wrote:
> f I had read a tutorial on working with logic gates,
Heck, if you've ever used a SCSI device you know *that* much. :-)
Date: 26 May 2010 03:53:42
Message: <4bfcd386$1@news.povray.org>
I've *got* a battery holder. But I still need to connect the terminals
of the battery holder to the beadboard.
Date: 26 May 2010 03:55:24
Message: <4bfcd3ec$1@news.povray.org>
I've used several SCSI devices. Your point?
Date: 26 May 2010 04:02:56
Message: <4bfcd5b0$1@news.povray.org>
> I've *got* a battery holder. But I still need to connect the terminals of
Solder one of your single-core breadboard wires to each wire of the battery
holder.
Date: 26 May 2010 04:10:00
Message: <4bfcd758$1@news.povray.org>
> battery holder.
That's what I did - except, as noted, I went for multistrand wire that I
can actually bend so that I can route it to anywhere on the breadboard.
Indeed, since I went with multistrand, everything has become a lot
easier. (Except stripping the wires. I suck at that!)
Date: 26 May 2010 04:35:52
Message: <4bfcdd68@news.povray.org>
Get a pair of wire strippers!
