POV-Ray : Newsgroups : povray.off-topic : Electronics activity Server Time
23 Mar 2026 03:59:29 EDT (-0400)
  Electronics activity (Message 36 to 45 of 65)
Subject: Re: Electronics activity
Date: 25 May 2010 07:04:33
Message: <4bfbaec1$1@news.povray.org>
>> Dude, really, you are going to fall over yourself over and over again if
>> you refuse to learn at least some basic analogue circuit electronics.
>> You must have realised by now that even to implement the simplest logic
>> circuits you absolutely must have some basic level of understanding.
> So what you're saying is that there is basically no way I will ever get
> this to work, and I should just give up now?
No, you can probably get this circuit to work by experimenting yourself,
asking here and googling.  Some people might even be nice enough to give
some detailed explanations, and you might learn some stuff.  You might even
be able to get a slightly more complex circuit to work ok.
But in the end you're doing things backwards, learn the basics *first*, it
will make your life so much easier, and you won't get stuck at every point
when things don't work as expected.  You will be able to answer your own
questions if you have the knowledge of how basic electronic circuits work.
For example the next thing will be relays to control things that need higher
power or voltage, you're going to connect one of your outputs to a relay
coil and then wonder why it's not working, and then complain that the relay
is destroying all your ICs :-)
Date: 25 May 2010 07:15:46
Message: <4bfbb162$1@news.povray.org>
> it will make your life so much easier, and you won't get stuck at every
> point when things don't work as expected.  You will be able to answer
> your own questions if you have the knowledge of how basic electronic
> circuits work.
Funny, I thought I *already* had a basic knowledge of how circuits work...
I guess what's throwing me is this new "logic low = negative" thing. I'm
used to thinking of logic low as "nothing connected here". If you were
making a bunch of logic out of switches with either connect or don't
connect a wire to the positive rail, everything would be quite a bit
simpler. (E.g., connecting the output of two gates together couldn't
possibly create a short-circuit condition, since each output is
connected to the same battery terminal or to nothing at all.)
I guess I'm still trying to get my head around all the consequences of
that. For one thing, it looks like every single [external] input and
output is going to end up needing a resistor on it. Yay. :-/
> higher power or voltage, you're going to connect one of your outputs to
> a relay coil and then wonder why it's not working, and then complain
> that the relay is destroying all your ICs :-)
Uh, no, even I'm not crazy enough to want to do that. :-P
1. I'm turning LEDs on and off. What the hell do I need relays for?
2. Relays are comparatively expensive.
3. Relays presumably use about 100x the current that an IC can supply.
4. PROFIT!
5. Relays move vastly slower than even the slowest electronic logic
gate. Why bother?
Date: 25 May 2010 07:33:41
Message: <4bfbb595$1@news.povray.org>
The circuit diagram you posted here makes it look like you don't.
OOC why are you used to thinking that?
> If you were making a bunch of logic out of switches with either connect or
> don't connect a wire to the positive rail, everything would be quite a bit
> possibly create a short-circuit condition, since each output is connected
This doesn't work, because as soon as you connect a "not connected" output
to something, it becomes "connected" and will have a specific voltage.  The
severely limits how many things you can connect to a single output.
It was just an example, you might one day want to control a motor, a
brighter lamp or a heater or something.
Hehe no, I've got a tiny surface mount IC here that is driving 6W of LEDs
directly.
> 4. PROFIT!
Huh, what are you planning to sell? No more free advice :-)
Date: 25 May 2010 08:08:40
Message: <4bfbbdc8$1@news.povray.org>
>> work...
Well, I noticed it wasn't going to work *before* I assembled it, right? ;-)
>> I'm used to thinking of logic low as "nothing connected here".
I guess it's the way most books refer to circuits as "on" or "off".
Usually if something is "on" it means it's connected to a power source,
and if it's "off" then it isn't connected. That's how, e.g., a light
switch works. It doesn't connect the output to the other pole when you
turn it off, it just doesn't connect it to *anything*.
Of course, strictly speaking, logic high and logic low can be
_anything_. So long as it's documented what they are and all the
circuitry is expecting the same thing, it'll work. But still, most
people casually refer to "on" and "off".
Fair enough. But my immediate plans only run to wiring up lots and lots
of logic gates, and observing their output.
> LEDs directly.
Sure. But I'll bet it isn't a general-purpose logic gate. It'll be some
special driver IC or something.
>> 4. PROFIT!
OOC, what's your hourly rate?
Date: 25 May 2010 08:09:14
Message: <4bfbbdea$1@news.povray.org>
> LEDs directly.
It's more about the relay's coil being an inductor. Once the IC
switches, it will send a high voltage pulse back through the IC, frying
it nicely. There are ways to get around that, but I'll leave that as an
exercise to the reader to figure that out.
Hint: The circuit simulator has an example of this. :)
~Mike
Date: 25 May 2010 08:18:50
Message: <4bfbc02a@news.povray.org>
This was exactly the point I was trying to make, that wiring up a relay
would "seem" to work (assuming your IC could source enough current) but then
in reality it's going to blow the IC :-D
Date: 25 May 2010 08:19:38
Message: <4bfbc05a$1@news.povray.org>
More importantly, if the *whole* circuit is relays, there's nothing to
fry. ;-)
(Other than your electricity bill, anyway...)
Date: 25 May 2010 08:24:31
Message: <4bfbc17f@news.povray.org>
Of course, same as your hex buffer you mentioned.  But you still can't
connect a relay directly to it without risking damage to the IC (as Mike
explained).
How much you got?
Date: 25 May 2010 08:37:03
Message: <4bfbc46f$1@news.povray.org>
>> some special driver IC or something.
> explained).
And I still wouldn't try it in the first place. ;-)
> How much you got?
I think we can take it as read that it's peanuts compared to what you
usually make. ;-)
Date: 25 May 2010 08:53:10
Message: <4bfbc836$1@news.povray.org>
>> How much you got?
> usually make. ;-)
So?  Depends how fun it is.  If you wanted me to test drive Ferraris then
you needn't pay me very much :-)
