POV-Ray : Newsgroups : povray.off-topic : Electronics activity Server Time
17 Mar 2026 02:44:43 EDT (-0400)
  Electronics activity (Message 26 to 35 of 65)
Subject: Re: Electronics activity
Date: 24 May 2010 09:58:38
Message: <4bfa860e$1@news.povray.org>
On 5/24/2010 8:38 AM, Invisible wrote:
> And 10 m of wire weighs, what, about 10 grams?
> Oddly, both the single-strand and multi-strand cables appear to contain
> some kind of white metal, not copper.
tin-plated copper.
~Mike
Date: 24 May 2010 10:13:41
Message: <4bfa8995$1@news.povray.org>
On 24/05/2010 2:23 PM, Mike Raiford wrote:
> On 5/23/2010 9:50 AM, Stephen wrote:
>> LOL, They get them from work ;-)
> For a minute there I thought you were going to say you picked them off
> of discarded electronics.
Lordy, no. Nothing but the best for the maintenance department. :-)
Best Regards,
Date: 24 May 2010 11:29:40
Message: <4bfa9b64$1@news.povray.org>
Invisible wrote:
> I have now cut some flexible wire, and it works quite well. (In
> particular, it can go around corners...)
You're not supposed to run breadboard wires around corners. You're supposed
to plug it into a hole and run a connected wire at an angle if you need angles.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 24 May 2010 11:31:46
Message: <4bfa9be2$1@news.povray.org>
> supposed to plug it into a hole and run a connected wire at an angle if
> you need angles.
I don't follow.
Date: 24 May 2010 17:59:36
Message: <4bfaf6c8$1@news.povray.org>
Invisible wrote:
> I don't follow.
http://www.robotroom.com/Pumpkin/LEDPulsingBreadboard.jpg
See how the black cable goes from C1 to C2?
Or how the purple cable goes "around the corner"?
Date: 25 May 2010 03:55:05
Message: <4bfb8259$1@news.povray.org>
I see...
Makes it kinda hard to rest the ends of the wires on both battery
terminals simultaneously when they're utterly rigid though. Similarly,
if you've got one wire that's 4 holes wide and another that's 6 holes
wide, you have to systematically design your circuits to not need any
connections 5 holes wide. Routing becomes formally equivilent to solving
the Zero Sum problem. (!) Not to mention the fact that those tiny 1-hole
wide wire loops are excruciatingly hard to manipulate.
By contrast, if you have some flexible wire, you can make a loop of any
size you desire, and it's very easy to work with.
Date: 25 May 2010 04:09:48
Message: <4bfb85cc@news.povray.org>
Invisible wrote:
> Hmm, this isn't going to work at all, is it?
Would it work if each switch had a seperate resistor? Or does that not
fix it?
Date: 25 May 2010 06:26:58
Message: <4bfba5f2$1@news.povray.org>
Depends what you mean by "work".  Seems like the two input pins on the IC
are actually tied together (to the top side of the resistor), so it's just
going to work like a NOT gate.
Did you also do the calculations to check that it's ok to use a single 360
Ohm resistor with those two LEDs for every combination of output states?
> Would it work if each switch had a seperate resistor? Or does that not fix
> it?
Dude, really, you are going to fall over yourself over and over again if you
refuse to learn at least some basic analogue circuit electronics.  You must
have realised by now that even to implement the simplest logic circuits you
absolutely must have some basic level of understanding.
Also try to draw your circuit schematics the same way as others do (you will
pick this up automatically whilst you learn about them, eg ICs like this are
usually drawn vertically, not horizontally).  Others will be more likely to
help you if they don't have to spend time deciphering which wires are
connected to what.
Date: 25 May 2010 06:31:29
Message: <4bfba701@news.povray.org>
> Ironically, the biggest problem was actually *wires*. I bought a box of
> nice compartmental box and there's quite a lot of wire in it, each length
> in a different colour, with the ends neatly bent to a right-angle.)
> Unfortunately, the wire is so utterly stiff and unbendable that I had a
> lot of trouble using it.
It is meant to be like that, so you can plug it straight into the
breadboard.  If you really need to bend it then get a pair of needle nose
pliers and make a neat bend.  Those pliers are also very useful for plugging
in and removing the very shortest wires.
That's what battery holders are for.
Date: 25 May 2010 06:46:18
Message: <4bfbaa7a$1@news.povray.org>
> you refuse to learn at least some basic analogue circuit electronics.
> You must have realised by now that even to implement the simplest logic
> circuits you absolutely must have some basic level of understanding.
So what you're saying is that there is basically no way I will ever get
this to work, and I should just give up now?
