POV-Ray : Newsgroups : povray.off-topic : Electronics research Server Time
16 Mar 2026 04:43:21 EDT (-0400)
  Electronics research (Message 25 to 34 of 104)
Subject: Re: Electronics research
Date: 19 May 2010 11:56:19
Message: <4bf40a23$1@news.povray.org>
On 5/19/2010 7:31 AM, scott wrote:
> Why is that weird? The LED doesn't care which leg is connected to the
> logic output pin, it's just a voltage. You could even connect the LED
> between two output pins*, then it would only turn on when one was high
> and the other was low.
There's even a name for that trick: Charlieplexing.
The 3 state had to be simulated by switched, but here's a circuit for
the Falstad simulator (http://www.falstad.com/circuit/):
$ 1 5.0E-6 10.20027730826997 50 5.0 50
L 224 176 176 176 0 1 false 5.0 0.0
L 224 224 176 224 0 1 false 5.0 0.0
162 352 176 352 224 1 2.1024259 1.0 0.0 0.0
162 384 224 384 176 1 2.1024259 1.0 0.0 0.0
w 352 176 336 176 0
w 384 176 368 176 0
w 352 224 336 224 0
w 384 224 352 224 0
w 368 176 352 176 0
L 224 272 176 272 0 1 false 5.0 0.0
w 384 272 352 272 0
162 416 176 416 272 1 2.1024259 1.0 0.0 0.0
w 416 272 448 272 0
w 416 176 448 176 0
162 448 272 448 176 1 2.1024259 1.0 0.0 0.0
w 416 176 384 176 0
w 352 272 336 272 0
162 384 272 384 224 1 2.1024259 1.0 0.0 0.0
s 272 176 336 176 0 0 false
s 272 224 336 224 0 0 false
s 272 272 336 272 0 0 false
w 384 272 416 272 0
162 352 224 352 272 1 2.1024259 1.0 0.0 0.0
r 272 176 224 176 0 100.0
r 272 224 224 224 0 100.0
r 272 272 224 272 0 100.0
~Mike
Date: 19 May 2010 12:03:30
Message: <4bf40bd2$1@news.povray.org>
On 5/19/2010 8:13 AM, clipka wrote:
> Texas Instruments has a nice collection of 74xx data sheets in a single
> proper PDF file at <http://focus.ti.com/lit/ug/scyd013b/scyd013b.pdf>
Ah, sweet! Thanks for that link! <Bookmarked>
~Mike
Date: 19 May 2010 12:58:13
Message: <4bf418a5$1@news.povray.org>
scott wrote:
> have several devices all with their outputs connected to a data bus,
> then only one device at a time must be driving the data lines to logic
> low/high, the rest must set their outputs to floating.
Yep. Indeed, there are a lot of busses that are organized such that you have
an output to it and an input, and you start putting your address on the bus
bit by bit until you see a bit different than your address. That means
someone else put on a 0 while you put on a 1 (assuming floating high). Every
packet gets delivered with no contention, with lower addresses getting
priority.  It's a kind of cool way to work it.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 19 May 2010 12:59:26
Message: <4bf418ee$1@news.povray.org>
Invisible wrote:
> that particular LED doesn't do anything now.
It's a DED component. It emits dark.
Date: 19 May 2010 13:00:58
Message: <4bf4194a$1@news.povray.org>
Cute. Is there a name for when you have a red LED in one direction and a
green LED in the other and you use AC to make it yellow? I want to use that
around my colleges and sound like I know what I'm talking about. ;-)
Date: 19 May 2010 13:07:50
Message: <4bf41ae6@news.povray.org>
Hey, so long as it doesn't start emitting negative light...
http://blog.orphi.me.uk/
Date: 19 May 2010 13:09:18
Message: <4bf41b3e$1@news.povray.org>
> that around my colleges and sound like I know what I'm talking about. ;-)
Most people call that a tri-colour LED - but sometimes that term is used
to refer to an LED with three different-coloured dies inside it (and
hence 3 pins). Which is obviously a different component.
Date: 19 May 2010 13:14:08
Message: <4bf41c60@news.povray.org>
scott wrote:
>> I always thought of it as logic high meaning "connected to the +V
>> rail" and logic low meaning "not connected to anything".
> Logic "high" and "low" are just names given to a certain agreed range of
> voltages.  The difference between "not connected to anything" (floating)
> and "logic low" is very important when working with data busses.  If you
OK, so if I'm understanding this right... The 74126 (go look it up)
contains 4 "buffers" - gates who's output is logically equal to their
input. But each gate also has an "enable" pin. When the enable pin is
high, the gate works like normal. When the enable pin goes low, it's
like the output pin isn't connected to anything any more.
And it seems that this allows you to connect several outputs together,
forming a kind of wired-OR configuration, provided that at all times
only one gate is "enabled".
Is that right?
Date: 19 May 2010 13:16:58
Message: <4bf41d0a$1@news.povray.org>
Am 19.05.2010 16:16, schrieb Invisible:
> While we're here, does anybody comprehend what VCC, VSS, VDD and related
> symbols mean?
According to JEDEC,
VBB = substrate power voltage (bias voltage), a voltage < VSS/GND.
VCC = logic power voltage, serving as a reference for high signal levels
(often sharing a common rail with VDD, in which case they may be used
interchangeably).
VCCQ = output stage logic power voltage, separate (positive) power rail
to drive output loads.
VDD = drain power voltage. separate (positive) power rail to drive the
chip's internals.
VDDQ = output stage drain power voltage. Effectively the same as VCCQ.
VEE = emitter power voltage. Only used for ECL devices.
VHH = special function enable voltage. An extra-high voltage to enable
certain special functions of a device.
VPP = programming voltage. An extra-high voltage to supply the power for
the programming function of a device (e.g. EPROM)
VREF = reference power supply, serving as a special reference voltage,
e.g. for ADC inputs.
VSS = GND = ground reference / source power voltage, serving as both
(negative) power rail and low signal level reference.
VSSQ = GNDQ = output stage source power voltage / ground reference,
serving as both a (negative) power rail and low signal level reference
specifically for output signals (should always be at the same level as
VSS=GND).
(This is just a subset of all the symbols used; for instance,
digital/analog devices such as programmable amplifiers or ADCs/DACs
often use separate voltage rails for the analog signals.)
Date: 19 May 2010 13:22:29
Message: <4bf41e55@news.povray.org>
clipka wrote:
> According to JEDEC,
> interchangeably).
> chip's internals.
> VSS=GND).
Suddenly the picture becomes even more complex than you feared...
Thank god I don't have to deal with anything analogue yet! ;-)
