On Tue, 11 May 2010 15:53:14 -0400, Jim Henderson wrote:
> On Tue, 11 May 2010 20:42:43 +0100, Orchid XP v8 wrote:
>>>> Carl Sagan and Dr. Hubble are alive?
>>> Technically not.
>> FEYNMAN ZOMBIE!!!
> Here's a published list of famous scientists who are still alive:
> http://blogs.chron.com/sciguy/archives/2009/10/
> the_top_five_most_famous_living_scientists.html
> That provides a pretty good start; I note that Dawkins, Goodall, and
> deGrasse Tyson are mentioned in the article.
> Stephen Chu would be well known now to the general public in the US
> because he's part of the Obama administration.
Larry Page and Sergey Brin come to mind now as well.
Jim
>> Perhaps you would have enjoyed a visit to Stoney Stratford telephone
>> exchange. It's a sprawling building, filled with rack after rack after
>> rack of cases, each case filled with dozens of relays. And they're not
>> in cases or anything, just "naked", so you can see (and if you desire,
>> move) the working components. There is also several tonnes of wire
>> overhead feeding this equipment. And all of it is as silent as death.
>> It's like a museum or something.
> Some time ago I was reading a Wikipedia entry about some of the relays
> in a central office. Someone described the sound as deafening back when
> everything was electromechanical. Especially on heavy phone traffic days.
Looking at this cavernous, echoing building stuffed *litterally* to the
roof with densly-packed racks of switches... Christ, it must have been
like hell on Earth! Deafening would be an understatement!!
>> Myself, I visualised a computer made of pressurised water fed through a
>> series of simple mechanical valves. Sadly, I fear that for reliable
>> operation, you would need inside water pressure. And if you wanted a
>> clock speed of more than about 0.02 Hz, you would have to use steel
>> piping and pyrotechnics to sustain the necessary pressure! It would be a
>> very "kinetic" experience though.
> Hmm. Water hammer. I can't imagine it working purely on water pressure
> alone, though. I keep thinking solenoids to control the valves. Would
> that be cheating?
Think about how a transistor works: You have one circuit that controls
another. So how hard would it be to rig up a valve where pressure from
one pipe moves the valve allowing (or blocking) water from flowing
through a seperate circuit? In principle it ought to be pretty trivial.
(Of course, making a valve that actually works well in practise probably
requires far more equipment than I personally have...)
The problem is going to be that once you have more than a few of these
linked together, effects like gravity and insertia become significant.
These don't affect electronics, for some reason...
>> Also... when I tried to build my own machine out of 7400s, I quickly
>> discovered that the gates don't appear to function as their truth table
>> indicates that they should. (!) I also looked into playing with FPGAs,
>> but the cost is prohibitive. (And, knowing me, I'd just make something
>> that doesn't even work, and then spend months trying to find out why!)
>> Plus, Xilinix (?) have a free simulation tool available, and it's just
>> painful to use. I dred to think what actually synthesizing with it would
>> be like...
> They do. If, however you have the gate connected to a switch, and the
> switch opens the circuit, you'd better have a pull-down resistor, or the
> gate will float. TTL is rather forgiving of this, the input will float
> high (e.g. it will be interpreted as a 1) CMOS, on the other hand, can
> potentially self-destruct if an input is left floating ;)
Maybe that's what I did wrong... I was expecting an open TTL input to
float low. Anyway, I don't think I shall go down the FPGA route. (!)
>> In solomn truth, it's probably simpler and easier to code a small peice
>> of JavaScript that controls a little Flash animation on a computer
>> screen. But there's something impressive about being able to pick up a
>> physical object in your hands and see that there really are no tricks...
> Yes, but, as you say ... there is something impressive about a physical
> object. :)
Indeed.
Another thing I thought about was a lego-style kit where you have lumps
of plastic in the shape of logic gates, with nice connectors for the
inputs and outputs, and LEDs in each input and output to indicate which
logic state it's at. The trick, of course, is power routing. ;-)
http://blog.orphi.me.uk/
>> 5 amps?!
> 5 amps per PCB. If IIRC TTL uses 250 ma per chip and there were 20 chips
> per PCB and 6 PCBs. Include the losses in the PS and it was just less
> than a Kw. It glowed <joke>
I've *seen* solid-state equipment glow. It's not funny. o_O
But anyway... 250 mA per chip? I thought it would be more like 0.5 mA
per chip?
>> How thick was the damned wire??
> Standard for the time. ;-)
Are we talking about the days when wires came insulated with fabric
rather than plastic? :-P
Mike Raiford wrote:
> 30 AMPS? O_o
My kettle draws less than that.
(Still, it does operate at a drastically higher voltage...)
>> Does your wife know about this ?
> She does. She's surprisingly tolerant of my antics. ;)
Damn, nice job!
>>> The TTL version should be fun, too. I plan to have lots of LEDs to show
>>> what's happening inside the machine.
>> I hope that you have comprehensive fire insurance :-P
> We do! I think ... I better read my policy closer... I expect the relays
> will use quite a bit of current, which is why I want to be able to keep
> the thing as small as possible in the number of relays.
The nice thing about relays is that they're (usually) double-throw. That
means you need fewer relays than you would, say, transistors.
>>> Still more complicated than my own 1984 design. ;)
>> Anybody else attempted this crazy task?
> In the mid sixties I built a binary adder using a couple of relays and a
> uniselector (from the GPO).
Not the GPO!! >_<
>> What the heck did you search for?! It's kind of a rather specific
>> question...
> I searched for "newton apple myth". First hit took me to a page that
> linked to this.
And that WORKED??
>>> You might refute it, a straw poll might be a start, but a poll of 20
>>> people isn't a particularly statistically valid poll.
>> Well it would be more valid than a straw poll of *one* wouldn't it? :-P
> I don't think statistically it would be. A sample size that's too small
> is too small.
I don't think stats works like that. You get a number which indicates
how accurate your estimate is. You them apply some arbitrary threshold
to decide what is "valid" and "invalid". Choose the right threshold and
anything can be "valid". My point is that a larger sample size will give
a better result (assuming reasonable sampling).
> Still, you might give it a go anyways, if anything it'll
> get you talking to people in meatspace. ;-)
In other news, I just spent an hour and a half in a pub.
>> Still, I guess this is going to be one of those things where no matter
>> how much evidence I produce that nobody has heard of these people,
>> everybody will continue to assert that my statistics are just wrong...
> That's because you don't *have* statistics. You have a guess. You say
> "nobody", but to prove that, you have to prove that *everybody* hasn't
> heard of them. That's pretty easy to disprove.
Clearly I meant "nobody" in the sense of "a very small fraction of the
population" rather than "zero people in the entire world". :-P
>> Quite a few of the names look hard to pronounce, but we'll see...
> Such as?
Sagan?
Rechecking the list, it doesn't look so bad...
>>> Ah, this would be the perfect time to mention Dijkstra.
>> Oh I am *so* not pronouncing that! :-P
>> I would also suggest that he is famous only to computer experts.
> I am afraid so. Though he could (and possibly should) have been a
> celebrity for the common man also.
Hey, I never said these people weren't important, I said they're not
well-known. ;-) Whether this is justified is an entire *other* question...
andrel wrote:
> I'd say that using a speech synthesizer to sing is a bit cheating.
[insert witty remark here about mass-produced electronically engineered
pop vocals]
>>> You would probably find QI interesting, not always about sciencey
>>> stuff, but a good programme to watch.
>> I do sometimes watch that, yes. Although it's not especially easy
>> figuring out when it's actually on TV. But if somebody else discovers
>> that it's on, I'll sometimes sit and watch it.
> http://bbc.co.uk/qi seems to be a pretty definitive source for that
> information. But googling "qi schedule" turns up some good hints as
> well. ;-)
Yes, obviously it hadn't occurred to me that these days the data is
probably online.
>> I think meeting Mr Fry might possibly be almost as interesting as
>> meeting Einstein. ;-)
> I'm quite sure he'd be more interesting. :-)
I'm not so sure... but neither claim is falsifiable, so...
>> You could live in a dark hole under a rock somewhere and you'd still
>> know who Einstein is. ;-)
> Have you talked to someone who lives in a dark hole under a rock
> somewhere and asked them? ;-)
Well... not literally, but I've come close. ;-)
> I could argue that you could live in a dark hole under a rock somewhere
> and still know who Jane Goodall or Richard Dawkins was, too.
Good luck with that. Dawkins I've heard of, Goodall I haven't.
I remember talking to someone who worked in a CO when Kennedy was shot. He
said they thought something was wrong because everything went really quiet
for about 20 minutes, and then it went completely nuts, beyond the capacity
of the system to switch.
Altho this might have been with a #5 crossbar. I'm not sure the relays were
around at the time.
Ada - the programming language trying to avoid
you literally shooting yourself in the foot.
>> Do you know what the likes of Einstein command? ;-)
> He was a patent clerk. I'd venture to say at the time he was living his
> salary was not above 5 digits...
Emphasis *was*. ;-)
>> You've got to admit, though, that mathematics and science are not
>> spectator sports. It can be very interesting to do yourself, but
>> watching the greats of the day doing it isn't particularly interesting.
> True ... but seeing what they discover is very interesting :)
Sure, *after* they've discovered it. ;-)
> Tomorrow 10PM friday BBC2, 8.30 PM BBC1
So it's on the two nights of the week I have something better to do? :-)
Oh well, I have a fix for that...
> My guess it that you already heard of Einstein before you retreated to
> your place under that rock.
Pfff, whatever.
"Jim Henderson" <nos### [at] nospam com> a écrit dans le message de groupe de
discussion : 4be9b5aa$1@news.povray.org...
Reading this list I realise that "famous living scientists" are probably
more "locally" famous than world-famous. Of the 5 scientists cited in the
blog, only Hawking is something of a star in France. The others are just
unknown outside scientific circles. The French never hear about Dawkins
because evolution and atheism are non-issues here. Climate change was not
controversial until last year so we didn't hear about Hansen (and the
controversy is mostly reduced to a couple of loudmouths). Watson & Crick
were always overshadowed by Monod. Goodall got a couple of medals here but
she isn't well known here either. On the other hand, local scientists or
French-speaking ones like Trinh Xuan Thuan (US) or Hubert Reeves (Canadian)
are popular figures, mostly due to media exposure.
G.
>> well. ;-)
> probably online.
Indeed, there are quite a few things online that answer the sorts of
questions you're prone to asking. ;-)
It depends on the person. Did you know that Stephen Fry writes about
open source software?
Does such a place exist in the UK?
Well, now you've heard of both of them. ;-)
Jim
> the blog, only Hawking is something of a star in France. The others are
> just unknown outside scientific circles. The French never hear about
> Dawkins because evolution and atheism are non-issues here. Climate
> change was not controversial until last year so we didn't hear about
> Hansen (and the controversy is mostly reduced to a couple of
> loudmouths). Watson & Crick were always overshadowed by Monod. Goodall
> got a couple of medals here but she isn't well known here either. On the
> other hand, local scientists or French-speaking ones like Trinh Xuan
> Thuan (US) or Hubert Reeves (Canadian) are popular figures, mostly due
> to media exposure.
> G.
Quite possibly true, though Dawkins is also known for his work in
genetics, so not just relating to evolution and atheism.
Jim
>>> question...
>> linked to this.
> And that WORKED??
Absolutely. Try it.
>>> :-P
>> small is too small.
Below a certain threshold, a sample holds no statistical validity. At
work we use statistical analysis on exam items, and if we have less than
50 samples or so to work with, we can't get any useful statistics; 1
result is no more statistically valid than 20 in such a case, because in
order to do the analysis, a sample size of 50 or more gives us what we
need for the analysis.
Statisticians I've talked to over the years have confirmed that - and I
work with a few on a somewhat regular basis in my work (analysing survey
results and the like, as well as indirectly working with people who are
professional psychometricians).
>> Still, you might give it a go anyways, if anything it'll get you
Also not a bad thing - humans are - by our very nature - generally social
creatures.
Ah, hyperbole. ;-) Still, you don't have statistics, you have a logical
argument that starts with what I believe is a false premise.
>> Such as?
> Sagan?
Just like it's spelt: Say-gan
I didn't think it was, hence the question.
Jim
>>> interesting.
In a recent interview, Mario Batali was quoted as saying:
"On any level to watch someone else do something they're good at is
entertaining, whether it's playing violin, cooking or playing baseball."
(This in the context of watching cooking shows). I think it could apply
here as well.
Jim
On 11/05/2010 10:35 PM, Orchid XP v8 wrote:
>>> 5 amps?!
>> chips per PCB and 6 PCBs. Include the losses in the PS and it was just
>> less than a Kw. It glowed <joke>
One of our fault finding techniques was to pass circuit boards close to
the lower lip to detect the heat given off by faulty chips.
> per chip?
My memory may have failed but it is what I remember.
No, varnish. :-P
Best Regards,
On 11/05/2010 10:00 PM, Mike Raiford wrote:
> On 5/11/2010 2:31 PM, Stephen wrote:
>> Feck! About 35 years ago I built a digital clock out of TTL. It used 30
>> amps at 5 volts Vcc. The power supply was bigger than a modern PC.
> 30 AMPS? O_o
> Umm, you sure that's not 30mA? I mean... for a digital clock 30 amps
> seems like an unreasonably huge power draw! Were you using nixie tubes
> for the display?
Definitely not 30 mA and yes nixie tubes, retro even in 1975 :-)
At the time I was working for Burroughs and components were not a
problem. We were encouraged to do “home projects” to build up our
skills. IIRC it used “classic” 7400 series logic gates, D type flip
flops etc. It had an alarm function and you set the time/alarm by
dialling in the time using rotary switches. A couple of years later I
worked for Motorola and made a clock from CMOS. That ran on a pp3 battery.
> From this data sheet:
> http://www.jameco.com/Jameco/Products/ProdDS/48119.pdf
> A max if 15mA for a decade counter. 66 of these would draw one amp of
> current. To draw 30 amps you'd need:
> ~2000 chips.
> Of course, if a classic 7400 series, it's a different story:
> http://www.jameco.com/Jameco/Products/ProdDS/50690.pdf
File not found. :-(
>> You are mad, you know ;-)
> Yeah, I know ;)
I suppose it keeps you off the streets. :-)
Good luck and photos are required. :-)
I suppose if you use reed relays it will keep the power and noise levels
down.
Best Regards,
You probably want a three port shuttle valve. Did you know that using
pneumatics you can make amplifiers, integrators, switches etc.?
Best Regards,
>> a uniselector (from the GPO).
> Not the GPO!! >_<
Yes, the GPO.
Best Regards,
On 11/05/2010 9:13 PM, andrel wrote:
>> I've seen him twice at the ROH (Royal Opera House, London)
LOL
Best Regards,
That sounds about right.
I don't see why not... although I would imagine achieving good linearity
might be tricky.
Pictures or it didn't happen. ;-)
>> probably online.
Back when I used to watch TV, nobody had Internet access yet. To find
out if there was anything on, you switch the TV through all 6 channels
and see if you see anything good. It hadn't occurred to me that times
have changed since then.
I imagine Mr Fry writes about quite a few things.
> here as well.
Well, I don't know. Watching somebody staring at a piece of paper and
thinking really hard doesn't sound entertaining to me, but then again I
haven't tried it with somebody who's really awesome at thinking...
>> Did you know that using pneumatics you can make amplifiers, integrators,
>> switches etc.?
> might be tricky.
Just use plain mechanisms (rotational/linear motion) then, no need for any
not-very-linear fluid to transmit the data :-)
> I do sometimes watch that, yes. Although it's not especially easy figuring
> out when it's actually on TV. But if somebody else discovers that it's on,
I find Sky's TV guide best (even if you don't have Sky). You search for
programs by typing the name into the search box. It also shows times in
your local time zone (rather than UK time like most others) which is useful
if you are watching from abroad...
http://tv.sky.com/tvlistings
The awesome bit is when they finish thinking and write something down.
>> linearity might be tricky.
> any not-very-linear fluid to transmit the data :-)
Well yes, this is the other possibility: Instead of flowing liquid (or
gas), use rotating beams. If the beam is being driven to rotate, that's
1. If it's being held still, that's 0.
Only problem is... what sort of clutch do you use to enguage a gear if a
beam is rotating above a certain speed? ._.
>> I haven't tried it with somebody who's really awesome at thinking...
Typically when they write it down, they write it in a way that makes
absolutely no sense to you or I.
The awesome bit, for me, is when they explain what it means, and why it
works, and you look at it and go "ah... neat!"
> gas), use rotating beams. If the beam is being driven to rotate, that's 1.
There are several options to choose from. First one that comes into my mind
is to have some weights (small ball bearings) that move outwards from the
rotation axis as speed increases due to the centripetal force. This linear
motion outwards can be used to engage a clutch between two other shafts.
Similar concept is used to govern the speed on some engines:
http://en.wikipedia.org/wiki/Centrifugal_governor
Another option (simpler but not as long lasting) could be to have a simple
frictional contact with another shaft that is constrained to rotate by a
torsional spring. As the input shaft speeds up the 2nd shaft will reach
some static equilibrium position, again this could be used to move another
clutch that connects two different shafts.
It depends on whether you were following along with what they were doing
before. Obviously if you turn up to see the one-liner written down it's not
going to be awesome at all if you don't understand it.
Seems similar to if you've never watched a sport before and switch on the TV
to see the best "goal" ever - it's not going to be awesome for you.
>> a beam is rotating above a certain speed? ._.
> mind is to have some weights (small ball bearings) that move outwards
> from the rotation axis as speed increases due to the centripetal force.
> This linear motion outwards can be used to engage a clutch between two
> other shafts. Similar concept is used to govern the speed on some engines:
> simple frictional contact with another shaft that is constrained to
> rotate by a torsional spring. As the input shaft speeds up the 2nd
> shaft will reach some static equilibrium position, again this could be
> used to move another clutch that connects two different shafts.
Yeah, this sounds like the two options I came up with.
I was wondering if something like the "Bendix drive" used in a starter
motor might work, but looking at how it operates, it seems unsuitable.
> might be tricky.
Not after negative feedback (called reset) was used in the late 1920’s.
Best Regards,
You have a different meaning for hail than we do in the States, but it
was described as sounding like hail on a tin roof. (In U.S. vernacular
hail is large ice balls from about 5mm all the way to 20cm or more.) So,
yeah. a little loud.
Right OK, just like all of the analogies. The gates would be controlled
by current, then. I suppose you could control them by voltage (pressure)
as well, but the valve would need to be easily actuated by pressure.
Hmm, the analogy holds well.
Well, water molecules are several orders of magnitude larger and more
massive than electrons... so it makes sense. Though, I suppose it could
be said a coil imparts a certain inertia to the motion of electrons.
I realize I'm stretching the analogy with that, but you'll see the point.
Yep. That got me when I fist started playing with TTL gates.
Here's and FPGA with 3000 cells for around US$18 ... Expensive in terms
of a single IC, but not too terribly bad.
However they can also run as high as US$6,485.79 (!!) Oh, and good luck
soldering that one to a board at home (Though, I've heard you can
actually attach a BGA to a circuit board using a toaster oven, but very
hard to verify that no pins are bridged or poorly connected.
Meh, that should be too hard to do. Either you have a substrate that you
drop the blocks on, or the power routes through additional pins. I've
seen a lot of electronics kits for kids that use lego-like blocks to
connect components together, rather than the old spring terminals that
my kit had when I was a kid.
~Mike
Yep. Surprisingly easy to construct AND, OR and even XOR gates with
relays. ;)
~Mike
Haha... Ohh boy. Maybe now I'll have something to post to my blog. Yeah,
I'll share pictures when I get to building it.
I'm still in the design phase. Maybe this evening I'll print up some
screen captures of the layout in the sim.
~Mike
On 5/12/2010 12:24 AM, Stephen wrote:
> Yes, the GPO.
pardon my ignorance, but what is a GPO?
~Mike
The analogy is pretty perfect. Electrical current = water current.
(Litres per second rather than Columbs per second.) Electrical potential
(i.e., voltage) = water pressure. Resistance = ...well, resistence.
Wikipedia even has a name for it:
http://en.wikipedia.org/wiki/Hydraulic_analogy
An electric circuit is just like a water circuit, but pushing water
around instead of electrons. All the same things like flow-rate,
density, pressure, etc all make sense.
I envisiged pressure-actuated valves. (I.e., pressure on the input
channel slides a valve, revealing an outlet. A spring slides the valve
back again when the input pressure drops. The slilding of the valve
opens or closes a channel for another water circuit.) If you wanted
current-actuated, you'd need a turbine or something to measure flow-rate
rather than pressure.
Even so, you would have thought starting and stopping the motion of
several hundred trillion electrons would take more energy than just
keeping them flowing.
Hmm, interesting.
I was looking at the price of a "kit", which contains not only the FPGA
chip itself, but also the [expensive] gizmo for programming it. The chip
also comes ready-mounted on a board with a USB interface and there's
driver software so you can control the thing from your PC. But yes, the
cost is far, far more than the piffling price of one little chip. (And
then there's the version of the simulator software which can actually
*program* the physical chip, not just simulate what it would do...)
Yeah, the substrate is probably the way to go. It draws attention from
the ubiquitous power lines and focuses it on the routine of the signal
lines.
> I've
Hell, I've still *got* the spring-terminal kit. ;-)
Yes, today you could make some cool stuff. Trouble is, kids today don't
have the patience for it, it seems. Why spend hours wiring up a circuit
so that a few LEDs twinkle when you can sit in front of a PS3?
> relays. ;)
Almost every house I've ever been in has an XOR gate wired up out of
light switches. ;-)
Mike Raiford wrote:
> Haha... Ohh boy.
The reality of the situation sinks in. ;-)
I got as far as buying about 20x 7400s before I realised I couldn't make
them do anything.
Good luck. 0;-)
>> Yes, the GPO.
What, couldn't Google it? >;-)
http://en.wikipedia.org/wiki/General_Post_Office
Did you have to wait several minutes for the tubes to warm up? Turn on the
TV five minutes before the hour or risk missing the opening minutes of the show?
No. I'm not *that* old. :-P
Although, come to think of it... when you turn the TV off, it makes a
weird crackling noise, and the whole screen is now covered in static. I
never did understand why. Modern CRTs don't seem to do that...
>>> probably online.
So now you know. ;-)
He sure does, quite the "Renaissance Man".
Jim
>> baseball."
>> apply here as well.
When you get to the level of a Hawking or similar, it's not necessarily
staring at a piece of paper, it's working through things on the
whiteboard. That can be fun to watch - people at that level tend to
think out loud.
Jim
> them do anything.
> Good luck. 0;-)
Hehe ... I've actually got the gates to do things. Not very interesting
things, but things. Its nice when you get the expected result.
~Mike
On 5/12/2010 7:57 AM, Invisible wrote:
>>> Yes, the GPO.
I saw that, but I didn't think it had any relevance to the conversation.
You mean to tell me the post office controls the phone system?
~Mike
>>>> Yes, the GPO.
In the good old days :-)
Best Regards,
