POV-Ray : Newsgroups : povray.off-topic : All bow to the mighty Python Server Time
3 Jun 2026 12:24:16 EDT (-0400)
  All bow to the mighty Python (Message 65 to 74 of 84)
Subject: Re: All bow to the mighty Python
Date: 22 Apr 2010 03:05:55
Message: <4bcff553$1@news.povray.org>
> The *other* problem is that Haskell libraries tend not to be very
> documented. :-(
As Darren said, even if you add no documentation to your code at all, you
still get to see the parameter type and name that the library programmer
used in the pop-up help, which usually is enough to figure out what to do -
unless they did something stupid like "float Rotate(float a, float b)" :-)
Adding documentation to your code is really easy too, you can just type
"///" before a function definition and it will automatically insert a
template for you to add some text to say what the function does and add some
help text for each parameter.  Obviously this then shows up in the
auto-complete pop-up when you use that function.
There are also documentation builder programs that will scan all your code
source files for these special "///" comments and automatically build one of
the MS Help files for you.  I have never done this, but it if I was to
release some library it would be a matter of seconds to generate the
documentation file.
Date: 22 Apr 2010 03:25:15
Message: <4bcff9db$1@news.povray.org>
>> What you're saying is "Python using whitespace is stupid because a lot of
>> web sites don't treat whitespace as significant."  Sure, OK, that's an
>> opinion.
>  I think it's a very valid opinion taking into account the amount of
> programming forums and blogs out there.
FWIW I've read and posted to loads of C++/C# blogs and forums, and I don't
ever recall seeing the whitespace getting messed up (it would make C+/C#
code look horrible).
Date: 22 Apr 2010 04:01:49
Message: <4bd0026d@news.povray.org>
>> documented. :-(
> you still get to see the parameter type and name that the library
> programmer used in the pop-up help, which usually is enough to figure
> out what to do - unless they did something stupid like "float
> some help text for each parameter.  Obviously this then shows up in the
> code source files for these special "///" comments and automatically
> build one of the MS Help files for you.  I have never done this, but it
> if I was to release some library it would be a matter of seconds to
> generate the documentation file.
Haskell too has a document autogen tool. Unfortunately, if the
programmer didn't bother to write any comments, all you'll get is a list
of function names and type signatures. Sometimes that really is all you
need - but sometimes it isn't...
Also, all too often when trying to use a complex library, what you need
is a high-level overview of the library's design before you start
reading low-level documentation for individual functions. This is almost
never available.
Date: 22 Apr 2010 04:03:03
Message: <4bd002b7$1@news.povray.org>
>> IBM still make mainframes?
> Yes, they still make mainframes. Most large corporations
> still use them. It is a very profitable business for IBM.
Really? Wow. I thought people stopped making and using mainframes about
20 years ago...
Date: 22 Apr 2010 11:37:32
Message: <4bd06d3c@news.povray.org>
And this, ladies and gentlemen, is why we have textbooks about libraries.
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 22 Apr 2010 11:38:38
Message: <4bd06d7e$1@news.povray.org>
> 20 years ago...
Actually, they're suing open source mainframe emulator authors lately.
Date: 22 Apr 2010 11:52:45
Message: <4bd070cd$1@news.povray.org>
That and the fact that, like I said, sometimes you need an overview to
describe how the pieces fit together before you can properly understand
the nitty gritty of individual function descriptions and so on.
Date: 22 Apr 2010 11:53:18
Message: <4bd070ee@news.povray.org>
>> about 20 years ago...
OK, wow. I had no idea that such things even existed. o_O
Date: 22 Apr 2010 12:45:21
Message: <4bd07d21$1@news.povray.org>
That's exactly what I was referring to. :-)
Date: 22 Apr 2010 13:33:47
Message: <4bd0887b@news.povray.org>
  On what grounds?
