POV-Ray : Newsgroups : povray.off-topic : All bow to the mighty Python Server Time
30 Nov 2026 08:58:46 EST (-0500)
  All bow to the mighty Python (Message 45 to 84 of 84)
<<< Previous 44 Messages Goto Initial 50 Messages
Subject: Re: All bow to the mighty Python
Date: 21 Apr 2010 12:49:22
Message: <4bcf2c92@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> If existing lines are indented incorrectly, then your code is broken. The
> reason that "auto indenting" is not possible in Python is the same reason
> that "auto bracing" isn't possible in C.
  Actually, I can't think why "auto-bracing" wouldn't be possible in C,
at least if you don't mind having braces even around single-statement blocks
(something which many programming guides actually recommend).
  Every time you write a statement which is followed by a code block (even
if it's an empty one in rare cases), such as a for-loop, the editor could
automatically add the '{' and '}' characters and indent the code such that
you can just keep typing the contents of the loop. (The only think which
would slightly interrupt the flow would be that when you end writing the
code block you need to exit it by pressing the down cursor a couple of
times...)
  Hmm, maybe I'll try to make emacs do exactly that. At least by binding
that functionality to some key...
  A lesser variation of that would be that every time you write a '{' the
editor automatically adds (and indents) a '}'. The editor could actually
constantly keep matching braces auto-indented, even if one of the pair is
changed somehow (most editors, including emacs, can highlight matching
braces, so it shouldn't be a problem to auto-indent them as well).
Date: 21 Apr 2010 13:01:42
Message: <4bcf2f76$1@news.povray.org>
Warp wrote:
> nemesis <nam### [at] gmailcom> wrote:
>> http://www.itworld.com/government/105031/will-wall-street-require-python
>   Python must have the most idiotic block delimiter in the history of
> programming languages: Whitespace indentation.
>   Why is it idiotic? Because whitespace is the one thing which gets most
> easily and regularly lost in communication.
>   For example, someone might ask some question about Python in a forum or
> blog post, and then someone might answer it with some Python code... and
> the blog/forum software removes whitespaces from the beginning of lines,
> completely changing the meaning of the program and making it inoperable.
> There are also many other situations where whitespaces at the beginning
> of lines might not be preserved (or might be changed somehow).
>   Also autoindentation of Python code is a physical impossibility.
>   The person who thought that it's a good idea to have indentation as
> block delimiters should be shot.
So you are saying that the programming language is no good unless it
allows production code to be floated around on blogs?
Date: 21 Apr 2010 13:16:39
Message: <4bcf32f7@news.povray.org>
  No, I'm saying that using whitespace as syntax is a bad idea.
Date: 21 Apr 2010 13:25:00
Message: <4bcf34ec$1@news.povray.org>
This is why:  Take all the braces out of a C program. Now put them back in
the right place.  That's what you're asking.
Distinguish between "indent Python not knowing how much it should be
indented" and "indent changing python when the program is already correctly
indented so far."
Your editor can indent when necessary, and unindent with a keystroke, as you
type. This is the equivalent of your "you write a statement which is
followed by a code block" statement. Cut and paste can automatically put
things as the right indent level (with a python-aware editor, of course). Etc.
Statements that should be aligned that aren't can be fixed. If you have four
lines under your "if" with slightly varying indents but all indented
relative to the "if", then this is trivial to fix. (Python might already be
happy with that one, actually.)
The only failure is when you have something that should be indented relative
to a line above it somewhere but it isn't. This is precisely analogous to
having the wrong number of closing braces. Asking for this to be fixed
automatically is identical to asking for C code with too many closing braces
to get fixed automatically. You can't do it, because you don't know how
indented it is *supposed* to be, just like you don't know which closing
brace is the one that ought be removed.  (I'm sure you've encountered this
at least once. :-)
Indeed, I wouldn't be surprised if it was trivial to program a python editor
that } at the start of a line translates to a dedent. :-)
Lots of HTML editors do this too.
Yep. Visual Studio does this.
Python doesn't need to. ;-)
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 21 Apr 2010 13:25:38
Message: <4bcf3512@news.povray.org>
So is lower case letters, because EBCDIC doesn't support that. :-)
Date: 21 Apr 2010 13:49:22
Message: <4bcf3aa1@news.povray.org>
  Yeah, I see how EBCDIC is as popular as html.
  (Besides, EBCDIC does support lowercase letters.)
Date: 21 Apr 2010 13:55:01
Message: <web.4bcf3ad2de6f369169ec4e2a0@news.povray.org>
Actually EBCDIC does support lower case.
a thru i is x'81' to x'89'
j thru r is x'91' to x'99'
s thru z is x'a2' to x'a9'
I once had a case where I had to deal with lower case numbers.
0 thru 9 were encoded as x'b0' to x'b9'
To change to uppercase just 'or' with a blank (x'40').
To change uppercase to lowercase xor with x'bf'
There is even a valid card punch for lower case letters.
An a is a 12-0-1 punch,
A  b is a 12-0-2 punch,
etc.
Isaac
Date: 21 Apr 2010 14:11:02
Message: <4bcf3fb6@news.povray.org>
>>> Plus, as you're typing the arguments, it gives you help for each
>>> argument.
>>> I.e., so you know whether it's radians or degrees expected.
>> Or find out what the hell the order of the argument is...
> Yep. Even better than type signatures, when you have three floats in a row.
Yeah, that one's fun. Haskellers tend to define aliases or new types
quite a lot. For example, Filepath is an alias to String, but
   writeFile :: Filepath -> String -> IO ()
is more illuminating than just
   writeFile :: String -> String -> IO ()
Even so, you do still find type signatures where it's not really obvious
what's what without some real documentation.
The *other* problem is that Haskell libraries tend not to be very
documented. :-(
http://blog.orphi.me.uk/
Date: 21 Apr 2010 14:11:39
Message: <4bcf3fdb$1@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> As documented, VS doesn't indent things the way *I* like. ;-)
> Did you ever adjust it to your liking? There's a bunch of knobs to
> tweak, you know.
When last I looked at it, no amount of combinations would make it behave
the way I wanted. Maybe it's improved since then...
Date: 21 Apr 2010 14:13:05
Message: <4bcf4031$1@news.povray.org>
Why...why do you know this? o_O
Date: 21 Apr 2010 14:23:45
Message: <4bcf42b1$1@news.povray.org>
I'm *far* more concerned that people are proposing to write financial
contracts in an ad hoc language like Python, rather than a more formally
rigoruous language...
Date: 21 Apr 2010 14:35:00
Message: <web.4bcf453dde6f369169ec4e2a0@news.povray.org>
Because unlike most of the people in this forum,
I live in an IBM mainframe world and need to
know this information.
Isaac
Date: 21 Apr 2010 15:16:05
Message: <4bcf4ef5$1@news.povray.org>
Obviously I was exagerating. The point is that it used to be you couldn't
paste javascript into a web page, because the < and > and such would get
corrupted. (Indeed, you still have to specially escape embedded javascript
sometimes in HTML markup.)
You're blaming the wrong tool.
Date: 21 Apr 2010 15:17:07
Message: <4bcf4f33$1@news.povray.org>
Whatever. The point is it isn't the language that's broken, but the tools to
display it.
Date: 21 Apr 2010 15:24:39
Message: <4bcf50f7$1@news.povray.org>
> couldn't paste javascript into a web page, because the < and > and such
> would get corrupted. (Indeed, you still have to specially escape
> embedded javascript sometimes in HTML markup.)
Who is the right tool to blame? ;-)
Best Regards,
Date: 21 Apr 2010 16:11:53
Message: <4bcf5c09$1@news.povray.org>
IBM still make mainframes?
Date: 21 Apr 2010 17:25:00
Message: <web.4bcf6d28de6f3691f0b197720@news.povray.org>
Yes, they still make mainframes. Most large corporations
still use them. It is a very profitable business for IBM.
Isaac
Date: 22 Apr 2010 01:00:53
Message: <4bcfd805$1@news.povray.org>
On 04/21/10 09:09, Warp wrote:
>> What you're saying is "Python using whitespace is stupid because a lot of
>> web sites don't treat whitespace as significant."  Sure, OK, that's an opinion.
>   I think it's a very valid opinion taking into account the amount of
> programming forums and blogs out there.
	If the point of your whole thread was that Python is a poor language to
post on many online forums and blogs, I won't argue. Seems a minor point
against it, though.
To call a man an ass is to insult the jackass.  M.Twain
Date: 22 Apr 2010 01:08:46
Message: <4bcfd9de$1@news.povray.org>
On 04/20/10 13:31, Warp wrote:
> Neeum Zawan <m.n### [at] ieeeorg> wrote:
>>         Well, OK - occasionally had issues with people mixing tabs with spaces,
>> but then I learned to use a proper editor.<G>
>   How does the Python interpreter/compiler even work with different types of
> whitespace? If, for example, one line as 4 spaces at the beginning and the
> next line has one tab character (which many editors will show as wide as
> 8 spaces, and in fact some editors will convert groups of 8 spaces into
> tabs), how does the interpreter interpret that? And what happens if you
> change the tab width in your editor settings?
	Mixing tabs and spaces is the only whitespace error I've come across in
Python. And I can count on one hand how often it's happened to me. And
as I said, the solution was simple: Use a proper editor that'll convert
the tabs to spaces.
>   I bet it can become pretty confusing when the interpreter is giving you
> error messages or, much worse, it will parse ok but run complately wrongly,
> even though it *looks* to be ok.
	If you mix tabs and spaces within an intended block, the program won't
run. If they're in separate blocks, it will run (properly).
>   Relying on the use of whitespace for actual syntax is idiotic (with the
> exception of separating tokens with at least one whitespace character,
> while not being important how many).
	Merely an opinion.
>>         Know how often I've had issues compiling because of a missing brace or
>> semicolon? Orders of magnitude more frequently than whitespace issues in
>> Python.
>   I'm not concerned about typos. I'm concerned about whitespaces being lost
> in transfer and different types of whitespace (spaces, different types of
> tab characters..) being interpreted differently by different programs (the
> text editor might be showing you something completely different than what
> the Python interpreter is seeing).
	Seems like a minor concern to me. As you're a professional programmer,
I suppose you often have to go to poorly coded forums. The ones I go to
allow you to post code that the software won't reformat. The only
exception being blog comments - and I rarely need to post code in a blog
comment.
>   Whitespace at the beginning of lines should be purely aesthetical, not
> integral part of the syntax.
	And a semicolon at the end shouldn't be mandatory, and should only be
needed if you want more than one statement per line. If you seriously
think about it, a huge percentage of semicolons in code are merely
wasted characters that just don't need to be there. It's easier to have
a syntax where you *explicitly* specify that the statement is longer
than one line, because those are the *exceptions*.
>>         Once I had spent just a short amount of time in the Python world, I
>> really hated semicolons in whatever other language I was coding in. A
>> royal pain to have to enter a mostly pointless character after each
>> statement.
>   You seem to assume that statements never get longer than a certain length,
> so that they will all nicely fit in one line. Sometimes it's useful to be
> able to split statements into several lines.
	Python has no problem dealing with statements that are on multiple
lines, as long as you write them properly. The "benefit" of semicolons
is quite the opposite - it allows multiple statements per line.
>>         Most online forums have a [code] tag or something similar to ensure
>> nothing gets formatted.
>   Except that many don't.
	And why would I try to post code to one that didn't? I wouldn't do it
even if whitespace was not a syntactical feature.
>> Otherwise, use a pasting service.
>   Why should I have to use such things just because the language has a
> braindead idea of using whitespace as syntax?
	Designing a language because of poorly written forum software is a bit
more braindead. Seriously, can you imagine this as being an issue the
C++ standards committee should bother looking into at all? How to make
code appear properly online?
>>         Why would this be a concern?
>   Because when your editor can autoindent your code, it makes programming
> enormously easier (similarly to how syntax highlighting does).
	I simply don't see a need for this in Python. If the code has wrong
indentation, then it's not merely indentation that is wrong. The code is
wrong. You can't autoindent incorrect code.
	In fact - one of the benefits of Python *is* that this is not an issue.
The need to autoindent arises because a language allows its users to be
sloppy while writing it.
Date: 22 Apr 2010 01:11:20
Message: <4bcfda78@news.povray.org>
	If popularity's a criterion, then mixed case sensitive file names are a
poor idea because Windows may have trouble with them.
Date: 22 Apr 2010 03:05:55
Message: <4bcff553$1@news.povray.org>
> documented. :-(
As Darren said, even if you add no documentation to your code at all, you
still get to see the parameter type and name that the library programmer
used in the pop-up help, which usually is enough to figure out what to do -
unless they did something stupid like "float Rotate(float a, float b)" :-)
Adding documentation to your code is really easy too, you can just type
"///" before a function definition and it will automatically insert a
template for you to add some text to say what the function does and add some
help text for each parameter.  Obviously this then shows up in the
auto-complete pop-up when you use that function.
There are also documentation builder programs that will scan all your code
source files for these special "///" comments and automatically build one of
the MS Help files for you.  I have never done this, but it if I was to
release some library it would be a matter of seconds to generate the
documentation file.
Date: 22 Apr 2010 03:25:15
Message: <4bcff9db$1@news.povray.org>
>> opinion.
FWIW I've read and posted to loads of C++/C# blogs and forums, and I don't
ever recall seeing the whitespace getting messed up (it would make C+/C#
code look horrible).
Date: 22 Apr 2010 04:01:49
Message: <4bd0026d@news.povray.org>
>> documented. :-(
> you still get to see the parameter type and name that the library
> programmer used in the pop-up help, which usually is enough to figure
> out what to do - unless they did something stupid like "float
> some help text for each parameter.  Obviously this then shows up in the
> code source files for these special "///" comments and automatically
> build one of the MS Help files for you.  I have never done this, but it
> if I was to release some library it would be a matter of seconds to
> generate the documentation file.
Haskell too has a document autogen tool. Unfortunately, if the
programmer didn't bother to write any comments, all you'll get is a list
of function names and type signatures. Sometimes that really is all you
need - but sometimes it isn't...
Also, all too often when trying to use a complex library, what you need
is a high-level overview of the library's design before you start
reading low-level documentation for individual functions. This is almost
never available.
Date: 22 Apr 2010 04:03:03
Message: <4bd002b7$1@news.povray.org>
Really? Wow. I thought people stopped making and using mainframes about
20 years ago...
Date: 22 Apr 2010 11:37:32
Message: <4bd06d3c@news.povray.org>
And this, ladies and gentlemen, is why we have textbooks about libraries.
Date: 22 Apr 2010 11:38:38
Message: <4bd06d7e$1@news.povray.org>
> 20 years ago...
Actually, they're suing open source mainframe emulator authors lately.
Date: 22 Apr 2010 11:52:45
Message: <4bd070cd$1@news.povray.org>
That and the fact that, like I said, sometimes you need an overview to
describe how the pieces fit together before you can properly understand
the nitty gritty of individual function descriptions and so on.
Date: 22 Apr 2010 11:53:18
Message: <4bd070ee@news.povray.org>
>> about 20 years ago...
OK, wow. I had no idea that such things even existed. o_O
Date: 22 Apr 2010 12:45:21
Message: <4bd07d21$1@news.povray.org>
That's exactly what I was referring to. :-)
Date: 22 Apr 2010 13:33:47
Message: <4bd0887b@news.povray.org>
  On what grounds?
Date: 22 Apr 2010 13:59:05
Message: <4bd08e69$1@news.povray.org>
>   On what grounds?
"You're losing us money", I would imagine...
(No, that's [apparently] not a criminal offence. But if you have enough
money, you can construct an argument that *is* a valid legal charge.
After all, matters of law are always decided by money, not rules.)
Date: 22 Apr 2010 14:08:38
Message: <4bd090a6$1@news.povray.org>
>   On what grounds?
Patents on the instruction sets.  TurboHercules is the particular company
I'm thinking of.  Of course, the europeans are slapping IBM around with
anti-trust suits for not letting IBM zOS run on anything but the mainframes
it was written for.
Date: 22 Apr 2010 14:12:08
Message: <4bd09178@news.povray.org>
> >   On what grounds?
  It sounds like the stalinist principle: "We have the culprit. Now we only
have to come up with the crime."
Date: 22 Apr 2010 15:36:16
Message: <4bd0a530$1@news.povray.org>
	Yup. Never happened before Stalin came around.
Sign on ZIP file : CAUTION! Contents under pressure!
Date: 22 Apr 2010 15:56:56
Message: <4bd0aa08$1@news.povray.org>
> around with anti-trust suits for not letting IBM zOS run on anything but
> the mainframes it was written for.
Wuh? How does *that* work?! o_O
Date: 22 Apr 2010 16:27:18
Message: <4bd0b126$1@news.povray.org>
Orchid XP v8 wrote:
> Darren New wrote:
>> Of course, the europeans are slapping IBM around with anti-trust suits
>> for not letting IBM zOS run on anything but the mainframes it was
>> written for.
GIYF.
Date: 22 Apr 2010 17:25:01
Message: <web.4bd0be45de6f3691f0b197720@news.povray.org>
Hercules is an open source product that emulates the IBM mainframe instruction
set.  You can find it here:
http://www.hercules-390.org/
It will run all of IBM's operating systems from the original DOS and OS/360 to
the
current z/OS, z/VM, z/VSE and zLinux.  As I understand it all the OS's up to
MVS 3.8 are in public domain and you can run them without a license.
Everything since requires a license to use.  As long as Hercules remained a
essentially a hobbyist program IBM didn't pay much attention to it.
TurboHercules, a commercial firm, started promoting Herules as a way
for companys to offload some work from their mainframe.
http://www.turbohercules.com/
Since this could impact IBM revenues, they are using patent infringement
arguments to stop the use of the Hercules software in a commercial environment.
Isaac
Date: 22 Apr 2010 17:36:29
Message: <4bd0c15d@news.povray.org>
On Thu, 22 Apr 2010 13:27:18 -0700, Darren New wrote:
>>> written for.
> GIYF.
Is this the thing with the mainframe emulator?  Or something else?
Jim
Date: 23 Apr 2010 04:09:38
Message: <4bd155c2$1@news.povray.org>
>>> libraries.
>> understand the nitty gritty of individual function descriptions and so
>> on.
Oh, right. I thought you meant the ease with which somebody can drop an
1-line comment into a source file, autogenerate some documentation and
claim that the library is now "documented".
Date: 23 Apr 2010 12:09:43
Message: <4bd1c647$1@news.povray.org>
In most cases, you can take out the "one line comment" and have a more
accurate statement.
