POV-Ray : Newsgroups : povray.off-topic : All about presentation Server Time
9 Apr 2026 00:12:53 EDT (-0400)
  All about presentation (Message 31 to 40 of 82)
Subject: Re: All about presentation
Date: 16 Apr 2010 06:28:20
Message: <4bc83bc3@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Warp wrote:
> >   There's this thing called learning and...
> Out of curiosity, how does one "learn" Photoshop anyway?
  You use it. You read tutorials on the internet (do you really think there
aren't any?) You read books. You ask colleagues.
Date: 16 Apr 2010 06:32:29
Message: <4bc83cbd$1@news.povray.org>
TC wrote:
>> Last time I checked, there are two ways to put an image into a web page.
>> You can use the IMG tag, which inserts an image in amoungst the text.
> You have to use CSS.
Yeah, one way is to use IMG tags in the HTML, the other way is the
background property in CSS.
Besides, ideally your HTML should contain *only* the text you're trying
to display, and CSS should do all the styling. A while back I found this:
http://www.csszengarden.com/
Just by changing the CSS, it completely rearranges the entire contents
of the page. And I thought CSS was just for changing colours...
> There is a css-property called z-index, allowing you to
> stack elements that have this property.
Yeah, I remember reading about that. I didn't think any known browser
supported it though?
Oh, mind you, I guess that was a while ago...
> There are "left", "right", "top",
> "bottom" properties, allowing you to position elements with pixel-precision.
Yeah, I've played with them, but I could never think of any useful
purpose for them.
> Note the "position" properties. They are important - read up on them.
Yeah, you can set the position relative to the rest of the flow, or
absolute relative to the page, or relative to the browser frame, or...
> Then you have a several css-properties for background: you can layer
> div-elements one upon the other, and overlap them using "left", "top",
> etc. - and each div-element can have a seperate background. The background
> for each and every element can be aligned ("background-align" property) and
> you can decide whether you want to repeat it or not. So you can position an
> image within a div-element and have a backgound for this element. If the
> background is a transparent image, the images and text below will show
> through.
Now, see, I was under the impression that setting a background
completely overrides any previous setting. And yet here we have a page
with a stipey background, and then a glow background on top of that. Or
DIV boxes with a transparent background so what's below shows through
(rather than being replaced).
> There are pitfalls, though. Not every browser supports css properly and you
> have to make sure the browser is in the right mode.
Sure, you need to avoid quirks mode and stuff, and as soon as you use
CSS it's 100% guaranteed that it will only ever work in the one version
of the one browser you tested with. I get that.
> It can be very hard to debug a style.
Hell yeah. Almost as hard as trying to debug JavaScript...
> If you really want to dig into this, you have to learn how css works.
I already know how CSS works. What I seem to be missing is that since I
last looked at it, they've added some new features.
> For a background that goes from one colour to another you can use your
> paint-program, create a line with fill-properties starting at blue and
> ending at white. Then put this 1-pixel line in the background property of
> your [whatever div or document part you want it to be].
Sure. I get that. (Although I don't possess a "paint program" to create
this image with in the first place... I'd have to write a custom program
to generate the pixels and write them to file, which is a little tedious.)
Date: 16 Apr 2010 06:34:22
Message: <4bc83d2e$1@news.povray.org>
In my experience, most Internet tutorials aren't very useful. (Although
there are always exceptions.) And since povray.off-topic is the only
"colleagues" I have, asking here is only going to give me "dude, GIYF!"
Books are similarly hit-and-miss, but I'm sure there's some good ones
out there. The tricky part is finding them. ;-)
Date: 16 Apr 2010 06:39:29
Message: <4bc83e61@news.povray.org>
  That's because you don't try them. When you read a tutorial you have to
actually *do* what the tutorial is saying, step by step. Just reading it
is not enough. You learn by doing.
Date: 16 Apr 2010 06:41:51
Message: <4bc83eef@news.povray.org>
If the tutorial doesn't make sense, it's not a good tutorial.
If the tutorial doesn't explain the part I'm trying to learn, it's not a
good tutorial.
Most tutorials I've seen fall into one or other of these categories. (As
I say, there are always exceptions...)
Date: 16 Apr 2010 11:03:15
Message: <4bc87c33@news.povray.org>
3 hours and 190 lines of source code later and I have... well, this.
Ugly, isn't it?
Let's face it, I'm no graphic designer, and I never will be. :-(
Download 'website11.png' (22 KB)
Preview of image 'website11.png'
Date: 16 Apr 2010 11:21:54
Message: <4bc88092$1@news.povray.org>
Invisible wrote:
> Yes, that's right. Somehow they put text ON TOP OF an image. Not only
> that, but somehow they put one image ON TOP OF another image, WITH
> TRANSPARENCY. I have no idea how that's possible.
That has been possible since forever. Except in IE which didn't support
alpha channel on PNGs.
http://www-archive.mozilla.org/start/1.0/demos/eagle-sun.html
> (But you cannot put anything over the top of this image.) Alternatively,
> you can set the page background image, which is obviously behind
> *everything*. That means you can put things over the top of it.
You can put an image as a background on ANY element.
<div style="background-image: url(foo.png)">hello <img src="bar.png"></div>
Date: 16 Apr 2010 11:44:08
Message: <4bc885c8$1@news.povray.org>
If you don't use any paint program yet, try the GIMP. It is free, can do
much, and is available for almost any OS I know.
www.gimp.org
It is not my first choice because I do not like the interface. Since you
don't use a paint program yet, this will be no problem. The GIMP should come
in handy when post-processing povray images, too. ;-)
With the right plugins GIMP can do many interesting things to a picture...
so sometimes I use it in spite of the interface. ;-)
If you want vector-images then inkscape looks promising. Not yet commercial
grade stuff, mainly because it has not many export formats, but it is free
and it imports PDF nicely. I think this is a program to watch.
BTW: if you want a >really< interesting background, then use an animated gif
(but keep down the loops to a few, else the text becomes unreadable)
Date: 16 Apr 2010 11:56:57
Message: <4bc888c9@news.povray.org>
TC <do-not-reply@i-do get-enough-spam-already-2498.com> wrote:
> www.gimp.org
  If he is unwilling to learn to use a program like Photoshop, I doubt he
will be willing to learn to use the Gimp.
  Uh, what?
Date: 16 Apr 2010 12:28:46
Message: <4bc8903e$1@news.povray.org>
You go to Amazon and read which books sell best, and look at the reviews.
When you get stuck, you ask someone you know who is already experienced with
photoshop.
 > Just reading it is not enough.
Seconded. The game programming tutorials I was reading often had bugs in
them - stuff that basically wouldn't compile, due to sloppily changing one
part but not the other, for example.  Figuring out what was broken was very
informative.
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
