POV-Ray : Newsgroups : povray.off-topic : All about presentation Server Time
15 May 2026 07:09:43 EDT (-0400)
  All about presentation (Message 23 to 32 of 82)
Subject: Re: All about presentation
Date: 16 Apr 2010 01:19:41
Message: <4bc7f36d@news.povray.org>
Neeum Zawan wrote:
> On 04/15/10 10:13, Orchid XP v8 wrote:
>> background. Goodness only knows how you do the curved corners, the
> Javascript.
>> delicious drop shadows, the glow effect at the top of the page, and so
> Shadows is either CSS or Javascript. No idea what you mean by glow.
Why would you need scripting for that?
Date: 16 Apr 2010 04:02:35
Message: <4bc8199b$1@news.povray.org>
Gilles Tran wrote:
> I've been using Artisteer for a while now. It's a (commercial) theme
> generator for a variety of popular CMS. It's really a useful program it
> you need a nice-looking website and don't have the time to learn how
> theming is done in the CMS you're using. I've been using it for Joomla
> and Drupal but it does Wordpress too. It does not replace a true web
> designer, but it's faster than endlessly tweaking the CSS of existing
> themes.
Mmm, interesting. Of course, since I won't be using a CMS, I'm not sure
it helps, but it's interesting to know that such things exist.
I think my basic problem is that I'm not a graphic designer. When I look
at a blank screen, I can't imagine what I might put onto it that would
look cool...
Date: 16 Apr 2010 04:06:49
Message: <4bc81a99$1@news.povray.org>
>> ...and using Photoshop, I wouldn't even know how to create the stripy
> 	Fairly easy.
Sure. If you somehow know how to use Photoshop.
> 	Javascript.
Actually it's part of the various bitmaps.
If you look at the theme demo (not my cut up image), you'll see that the
top of the page has a subtle blue glow to it.
Date: 16 Apr 2010 04:15:31
Message: <4bc81ca3@news.povray.org>
4bc8199b$1@news.povray.org...
> Mmm, interesting. Of course, since I won't be using a CMS, I'm not sure it
Your blog is running on Wordpress, which is a CMS.
G.
Date: 16 Apr 2010 04:20:48
Message: <4bc81de0$1@news.povray.org>
Orchid XP v8 wrote:
> http://wordpress.org/extend/themes/piano-black
> Now, if I can just figure out how it works...
The way it works is rather surprising.
There's a 5x5 pixel image that consists of grey with a black stripe
across it. This is tiled to form the stripey background.
There is an image named "top". This is the black slab with the rounded
corners and the drop shadow. The bit that the page title appears on top of.
Yes, that's right. Somehow they put text ON TOP OF an image. Not only
that, but somehow they put one image ON TOP OF another image, WITH
TRANSPARENCY. I have no idea how that's possible.
There's also an image that's blue in the center, and fades to
transparent towards the edges. This is somehow displayed ON TOP OF the
background image to generate the blue glow at the top of the page.
Then there's an image that's 2 pixels tall, just consisting of various
shades of grey. This is what generates the two-tone grey for the body
text and the sidebar. But it's TRANSPARENT, showing the stripe texture
through from below. (And also the blue glow.) And it has a drop shadow
at each end, which also blends through.
Finally, there's a "bottom" image, which implements the semicircular
bottom of the page. (You can just about make out where the edge of the
sidebar doesn't line up perfectly.)
In a similar way, there are a pair of "top" and "bottom" images
containing a black bar with a curved end; this is what implements the
black markers at the bottom of each post, where it tells you the number
of comments, etc. (This also explains why the curve isn't quite right.
You can also see a glitch in the dotted line where the two halves of the
image meet.)
Last time I checked, there are two ways to put an image into a web page.
You can use the IMG tag, which inserts an image in amoungst the text.
(But you cannot put anything over the top of this image.) Alternatively,
you can set the page background image, which is obviously behind
*everything*. That means you can put things over the top of it.
That gives you two ways to build a page like this:
1. Draw the entire page, with all the borders and lines you want, and
then use CSS to position the text into the spaces in the graphic. (This
means the page must be a fixed size, since the background graphics have
been drawn at a fixed size.)
2. Draw the entire page, and chop it into pieces. Use IMG tags to insert
each piece of the frame around the outside of the text, keeping the text
inside the frames. If you want the text itself to have a background,
things get tricky. But by using a repeating pattern, you might be able
to make the page semi-resizable.
This theme uses neither approach. Somehow it manages to combine multiple
layers of semitransparent images *at the client end* to produce the
final page. I have still to discover how that's possible. (Not to
mention how the hell you line all the text up nicely...) The fact that
the CSS code is litered with properties I've never even heard of is
probably the first clue. Unfortunately, it's not very readable in there...
(I have to find out what tags and classes exist in the HTML and what
they contain, then see where they end up on the rendered page, and then
see what CSS is applied to them, and lookup what images are being
referenced, and then see the JavaScript that's manipulating them, and...)
Date: 16 Apr 2010 04:21:32
Message: <4bc81e0c@news.povray.org>
My blog does not allow you to use any themes except the ones provided by
the hosting company.
Date: 16 Apr 2010 05:35:49
Message: <4bc82f75@news.povray.org>
Warp wrote:
>   There's this thing called learning and...
Out of curiosity, how does one "learn" Photoshop anyway?
Presumably it doesn't come with a manual - or if it does, it only covers
what each button and menu item does (which isn't the same as knowing how
to *use* these tools to achieve a particular goal).
don't have.
Date: 16 Apr 2010 06:14:34
Message: <4bc8388a@news.povray.org>
You have to use CSS. There is a css-property called z-index, allowing you to
stack elements that have this property. There are "left", "right", "top",
"bottom" properties, allowing you to position elements with pixel-precision:
add style="position: absolute; left: 10px ; top: 10px; z-index: 2;" and
style="position: absolute; left: 20px; top: 20px; z-index: 3;" to a
div-element containg pictures and see what happens.
Note the "position" properties. They are important - read up on them.
Then you have a several css-properties for background: you can layer
div-elements one upon the other, and overlap them using "left", "top",
etc. - and each div-element can have a seperate background. The background
for each and every element can be aligned ("background-align" property) and
you can decide whether you want to repeat it or not. So you can position an
image within a div-element and have a backgound for this element. If the
background is a transparent image, the images and text below will show
through. Or, with IE, there are things called filters - neat things can be
done with them - but they are something only supported by IE, so best keep
away from them).
There are pitfalls, though. Not every browser supports css properly and you
have to make sure the browser is in the right mode. Mode is set by
HTML-DOCTYPE, I'd advise
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
It can be very hard to debug a style. Firefox with the Firebug-Extension is
your friend.
If you really want to dig into this, you have to learn how css works. And
how to circumnavigate the various browser-bugs.
For a background that goes from one colour to another you can use your
paint-program, create a line with fill-properties starting at blue and
ending at white. Then put this 1-pixel line in the background property of
your [whatever div or document part you want it to be]. Set style=
"background-repeat: none; background-position: top; background-align: left;"
and you have got what you want. Of course there are pitfalls here, too.
To explain all this properly is like asking somebody how to do a macro with
sphere-sweep in povray - and why it sometimes gives rather unexpected
results and in which cases it does and what to use as remedy. Or lecture on
the finer points of photons in povray. Not easy, for obvious reasons.
Date: 16 Apr 2010 06:28:20
Message: <4bc83bc3@news.povray.org>
  You use it. You read tutorials on the internet (do you really think there
aren't any?) You read books. You ask colleagues.
Date: 16 Apr 2010 06:32:29
Message: <4bc83cbd$1@news.povray.org>
Yeah, one way is to use IMG tags in the HTML, the other way is the
background property in CSS.
Besides, ideally your HTML should contain *only* the text you're trying
to display, and CSS should do all the styling. A while back I found this:
http://www.csszengarden.com/
Just by changing the CSS, it completely rearranges the entire contents
of the page. And I thought CSS was just for changing colours...
Yeah, I remember reading about that. I didn't think any known browser
supported it though?
Oh, mind you, I guess that was a while ago...
> "bottom" properties, allowing you to position elements with pixel-precision.
Yeah, I've played with them, but I could never think of any useful
purpose for them.
Yeah, you can set the position relative to the rest of the flow, or
absolute relative to the page, or relative to the browser frame, or...
> through.
Now, see, I was under the impression that setting a background
completely overrides any previous setting. And yet here we have a page
with a stipey background, and then a glow background on top of that. Or
DIV boxes with a transparent background so what's below shows through
(rather than being replaced).
Sure, you need to avoid quirks mode and stuff, and as soon as you use
CSS it's 100% guaranteed that it will only ever work in the one version
of the one browser you tested with. I get that.
Hell yeah. Almost as hard as trying to debug JavaScript...
I already know how CSS works. What I seem to be missing is that since I
last looked at it, they've added some new features.
Sure. I get that. (Although I don't possess a "paint program" to create
this image with in the first place... I'd have to write a custom program
to generate the pixels and write them to file, which is a little tedious.)
