POV-Ray : Newsgroups : povray.off-topic : Scientific Faith Server Time
4 Jun 2026 12:40:25 EDT (-0400)
  Scientific Faith (Message 61 to 64 of 64)
Subject: Re: Scientific Faith
Date: 2 Apr 2010 11:50:40
Message: <4BB6124F.40109@gmail.com>
On 2-4-2010 0:21, Nicolas Alvarez wrote:
> andrel wrote:
>>> Is that realistic to expect?
>> If you really want to broadcast a message anything is realistic.
> And what if they aim the message directly at us? I assume they can use less
> power if they are pointing exactly at the Earth.
Then they know we are here which implies that they noticed our radio or
television broadcasts. So, the answer to your question will not be
relevant within the next 3 centuries.
Date: 6 Apr 2010 03:03:44
Message: <4bbadcd0$1@news.povray.org>
>> Extrapolating from the Voyager power levels and distance, I make it that
>> we need a 350 GW signal to be transmitted from 200 ly away.
> The SETI equipment might even be somewhat more sensitive because they are
> using larger disks. Then again they don't know what exact frequency to
> tune into.
> BTW I arrive at something more like 47 MW if the voyager is transmitting
> all its power, which is unlikely, so the number could even be much lower.
I assumed that the power needed goes up with the square of distance, so used
Google to calculate:
"(200 light years / 16.8e9 km)^2 * 23 W"
which actually gives 300 GW, but I think that's a big underestimate, as
presumably Voyager is directing its 23 W directly at Earth, and not
radiating out in a sphere.  If an alien world 200 ly away is radiating in
all directions equally, it would need to be outputting much more than 300 GW
in total.
Date: 6 Apr 2010 03:08:10
Message: <4bbaddda$1@news.povray.org>
>>> What if it's not directional but broadcast? How much power do the
>>> 200ly-far aliens need to send a radio signal covering an entire
>>> hemisphere*, so that a reasonable amount still reaches us (or rather
>>> SETI's antenna)?
>> That would be 7 TW. Which is the amount of power you can generate with a
>> solar array 150 km x 150 km* in size (assuming 24% efficiency). That
>> would
>> be a bit more than our society could afford to spend on trying to
>> broadcast our position.
Good info, thanks!
Date: 9 Apr 2010 08:37:24
Message: <4BBF1F81.50902@gmail.com>
>>> that we need a 350 GW signal to be transmitted from 200 ly away.
>> are using larger disks. Then again they don't know what exact
>> frequency to tune into.
>> transmitting all its power, which is unlikely, so the number could
>> even be much lower.
> used Google to calculate:
You are absolutely correct of course, I seem to have forgotten the
square. :(
> in all directions equally, it would need to be outputting much more than
> 300 GW in total.
That too. Probably the most efficient way to do it is by modulating the
output of a star. Either directly (controlled starquakes?) or by putting
things in front of it (jupiter sized arrays of shutters?).
Only, SETI isn't looking for that.
