POV-Ray : Newsgroups : povray.off-topic : How does Haskell work? Server Time
15 May 2026 00:05:53 EDT (-0400)
  How does Haskell work? (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: How does Haskell work?
Date: 17 Mar 2010 16:05:02
Message: <4ba135ee$1@news.povray.org>
Invisible wrote:
> At a simple level, you could just scan the source when you compile it,
> and replace any calls to the #ifTrue:ifFlase: method (and friends) with
> the appropriate machine instructions.
Internally, that's what it does. Of course, if you send that to something
that isn't a boolean, *then* you get an even bigger overhead.
> Then again, Smalltalk is an interpretted language. Speed is quite
> clearly *not* its main objective.
This is not something that noticably slows things down, tho. When
*everything* is a message dispatch, you can design your microcode to do that
efficiently.
   Yes, we're traveling togeher,
   but to different destinations.
Date: 17 Mar 2010 16:05:57
Message: <4ba13625$1@news.povray.org>
>> And then I learned Haskel, which is *completely different*. ;-)
> Try then APL, or LISP, or FORTH.
Tried Lisp, didn't like it. Too much backwards compatibility making it
way, way more complicated than it should be.
I guess that's one nice thing about Haskell's avoidance of success...
http://blog.orphi.me.uk/
Date: 17 Mar 2010 16:14:07
Message: <4ba1380f$1@news.povray.org>
>> with the appropriate machine instructions.
> something that isn't a boolean, *then* you get an even bigger overhead.
Sure. If you had static typing, you could statically guarantee that this
won't happen, and avoid handling it.
OTOH, Smalltalk basically allows you to define new flow control
constructs of your own, so...
> that efficiently.
Oh, sure. Simplicity can be a boon to efficiency. I'm just saying,
Smalltalk isn't targetted at scientific computing, realtime simulation,
DSP or high-end computer gaming. ;-)
Date: 18 Mar 2010 17:56:07
Message: <4ba2a177$1@news.povray.org>
If I ever did write a book on Haskell, would this make a good chapter?
Date: 19 Mar 2010 15:15:50
Message: <4ba3cd66@news.povray.org>
Well, you'd still have to handle it, but at compile time, yes.
Anything with lambdas does, really.  (Well, real lambdas, not just downward
funargs.)
I think it was actually a teaching language.
Date: 19 Mar 2010 15:17:27
Message: <4ba3cdc7@news.povray.org>
Indeed!  Actually, it should be near the front, I think. (But I'm a computer
language nerd, so maybe not.)
I'll second that you should write a Haskell book. I bet I know someone who
could tell you the right person to point you at at O'Reilly if you wanted to
see if it could go commercial, too.  I wouldn't give the rights away *too* fast.
Date: 21 Mar 2010 14:09:45
Message: <4ba660e9$1@news.povray.org>
> computer language nerd, so maybe not.)
This was my thinking also. A chapter with no code, just concepts.
I've tried writing Haskell tutorials before, and I always get stuck
here, because you need ADTs to explain pattern matching, but you need
pattern matching to explain ADTs. I think explaining how it all works
before trying to write code is probably the way forward. Indeed, I'm
thinking this might significantly simplify other aspects too - teach 'em
how it all works before you get into the details of syntax and so forth.
> who could tell you the right person to point you at at O'Reilly if you
> wanted to see if it could go commercial, too.  I wouldn't give the
Heh. O'Reilly just published one:
http://book.realworldhaskell.org/
It's written by three leading Haskell experts too.
Nice idea though. ;-)
Date: 21 Mar 2010 18:53:01
Message: <4ba6a34d$1@news.povray.org>
You don't need pattern matching to explain ADTs. Explain ADTs with math (and
textual substitutions, etc), then explain how pattern matching expressions
can help automate what to do.
Actually, Meyers did a really nice job of explaining ADTs to justify
object-oriented ideas in his Eiffel book.
Yes. Or intermix the two.
http://docs.eiffel.com/book/method/object-oriented-software-construction-2nd-edition
If you haven't read that, you should.
Oh. Try apress or something, then.
Haskell for Dummies.  I just don't know anyone at the other places.
Date: 22 Mar 2010 05:13:15
Message: <4ba734ab$1@news.povray.org>
> (and textual substitutions, etc), then explain how pattern matching
> expressions can help automate what to do.
Meyers explained ABSTRACT Data Types, not ALGEBRAIC Data Types.
Different ADT. ;-)
I'm pretty sure I have read it.
Date: 23 Mar 2010 17:13:03
Message: <4ba92edf$1@news.povray.org>
> Different ADT. ;-)
No, he explained algebraic data types, *then* abstract data types.
