POV-Ray : Newsgroups : povray.off-topic : Why is Haskell interesting? Server Time
26 Jun 2026 09:05:14 EDT (-0400)
  Why is Haskell interesting? (Message 81 to 87 of 87)
Subject: Re: Why is Haskell interesting?
Date: 2 Mar 2010 19:06:36
Message: <4b8da80c$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Darren New wrote:
>>> Really, Python isn't noticeably less private than C++. C++ shows you
>>> everything. The compiler says "don't reference that by name", instead of
>>> the IDE doing it.
>> Or, to phrase it a different way, I've never had a problem caused by someone
>> intentionally accessing a private member in a Python-like environment that
>> would have been solved by making the code not compile when that happens.
>   And I have never had a problem with a wild pointer modifying the private
> members of a class either.
>   Is your anecdotal evidence better than mine?
No. That's why it's a matter of opinion.
>> Have you ever known someone to accidentally name a C function __XYZ__ and
>> not be aware they might be stepping on the compiler's namespace?
>   Actually it's quite common in C and C++ out there to have names starting
> with underscore even though the standard says it shouldn't be done.
>> Is it
>> really a problem that the compiler doesn't prevent you from using names like
>> that?
>   Well, it is quite a common objection in C++ groups when people post code.
Really? I'm quite surprised.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 2 Mar 2010 19:06:59
Message: <4b8da823$1@news.povray.org>
>> Warp wrote:
>>>   (That doesn't mean you can't have a pointer pointing to a member of an
>>> object, in a portable way. However, that requires either for the member
>>> to be public or for the object to give you the pointer.)
>> Actually, just thinking about it a bit more, if the class returns a pointer
>> to a member variable, and you can look in the header and see that pointer is
>> in an array, then you have a well-defined way of accessing the other private
>> data in the same array.
>   Only if you also know which array element it's pointing to. (If you know,
> then the class is, effectively, exposing the entire array.)
That's true.
Date: 2 Mar 2010 19:50:04
Message: <4b8db23c@news.povray.org>
> *I* just don't see any practical advantage of having the compiler enforce
> that. You gave an example from your function library. I contend that the
> same thing could have been done with Python's level of encapsulation. It
> would be no more of an error for me (say) to change how variables that start
> with "_" work than it would be for you to change the size of the class you
> wrote.
  Oh, but access rights go beyond simply restricting access from the outside.
  For example, in C++ a base class can have a private member with a certain
name, and a class derived from that base class can have a private member
with the same name. There's no clash. Each class unambiguously accesses its
own member without having to explicitly specify which one with a class prefix.
The private part of the base class really is private: It doesn't even
interfere with a derived class's scope, which might have members with same
names as the base class without problems.
  Also, what naming convention is used in Python for a protected member
variable or function? (In other words, a variable or function which is
accessible by a derived class but not from the outside.)
  Private inheritance is not an extremely common technique in C++, but it
sometimes has its uses (one could think of private inheritance as a kind
of composition where the object itself can act as an object of either the
base or derived class). I suppose there's no such a thing as private
inheritance in Python.
> *Correct* Python code doesn't rely on "_" members remaining the same from
> one release of code to the next. Just because the compiler doesn't enforce
> it doesn't mean it's "correct".
  Does the Python standard explicitly state this?
> No. Merely noting a trend. You don't always say precisely and clearly what
> you mean, and when I give counter-examples, you clarify and then act
> indignant that I addressed what you said instead of what you meant.
  There's this thing called reading comprehension. Understanding what the
other wrote, in its context, rather than nitpicking on words.
> >>>   So you said that "a given type, all by itself, will require sizeof(type)
> >>> bytes of memory". Well, duh, that's how sizeof() is defined, after all.
> >> You said "there are no guarantees".
> >   I was talking about the memory layout of an object. There *are* no
> > guarantees about it.
> Yes, there are. There's even one I pointed out to which you said "Well, duh,
> that's the definition."  Remember?
  The size of an object says nothing about its layout.
  You could as well claim that sizeof(double) tells you something about
how the different parts of a base-2 floating point value are laid out
inside the variable. Of course it doesn't. It just tells how much memory
the type takes, not its internal layout.
  Making a guarantee about the layout of a double would be, for example,
"the most significant bit is always the sign bit".
> I do. Do you seriously tell me that knowing there isn't data from another
> object between the lowest-addressed private member and the highest-addresses
> private member isn't a guarantee about the layout of the data of a class?
  Actually there's no such guarantee. If you use virtual inheritance in a
diamond inheritance situation, the common base will be shared among the
classes which were multiple-inherited from. This means that the layout
of the objects inside the most derived class will be split, rather than
being at contiguous memory locations.
> If I take the sizeof a child class, it's always going to be at least as
> large as the sizeof a parent class. If I have a class with two members of
> class X, it's going to be at least twice as large as class X, even if that
> means there are two vtable entries where one would be enough.
  Sizes say nothing about the layout any more then sizeof(double) says
anything about the internal layout of a floating point number.
> If I have
> class X that inherits multiply from class A and class B, I know that I can
> take a pointer to class B and not worry that there are bits of A mixed up
> inside.
  But you have no way of knowing the internal layout of B, especially if
A and B have a common base class from which they inherit virtually.
> >   You don't use a debugger to resolve where the crash happens?
> That's the thing, see. When someone comes along and stomps all over the
> stack, you can't really prove what's happening very easily, even with a
> debugger.
  Depends on the debugger. For example programs like valgrind and AQtime
are quite good at catching out-of-bounds accesses, memory leaks and such.
(Of course they can't catch every possible bug, but quite many.)
Date: 2 Mar 2010 20:45:04
Message: <4b8dbf20$1@news.povray.org>
That's cool. I imagine that helps with maintaining large code bases that
other people are inheriting from.
I'm not sure, honestly.
Given there's no "private", no, I don't think you'd have "private
inheritance." :-)
Yeah, let's both try to improve that. :-)
It does. And I've given you multiple examples where it does. The very fact
that "sizeof" is defined tells you something about how you have to implement
things.
Really? OK.
Yeah. Now, get them to run while the graphics chips are expecting you to
respond promptly to interrupts, and without taking up more than another 3K
of memory. :-)
True.  Of course, I'd argue that the existence of such tools show that such
bugs are not so uncommon that they're worth disregarding. :-)
Date: 28 Mar 2010 20:31:32
Message: <4baff4e4$1@news.povray.org>
Invisible wrote:
> C has cpp, which (as far as I know) is very primitive and not
> Turing-complete.
It's not turing complete, but if you run it multiple times, it may be:
http://www.ioccc.org/2001/herrmann1.hint
http://www.ioccc.org/2001/herrmann1.c
Date: 30 Mar 2010 21:24:56
Message: <4bb2a468@news.povray.org>
Darren New wrote:
>>> Bzzzt. You just don't know javascript very well. What object do you
>>> get when  foo or bar references "this"?
>> I have no idea. (And no obvious way of finding out...)
> Hint: It's called "window".
> function foo() {...}
> is the same as
> window["foo"] = Function(){...}
More precisely, a 'foo' property is added to the global object, which
happens to be "window" when the JS interpreter is hosted in a web browser.
Date: 30 Mar 2010 21:30:02
Message: <4bb2a59a@news.povray.org>
>> OK. So in what way does this mean that "functions are not first-class"?
> I didn't say it did. I said that everything in Javascript is an object.
Correct, including functions themselves.
> There are no functions unassociated with a corresponding instance.
Functions are not associated with an instance when they are created, the
"association" is at call time.
var f = function (x) { return x; };
What instance is f associated to?
If you call f(4), 'this' inside the function body will be the global object
because of the way you *called* it. However:
var o = {};
o.f = f;
o.f(4);
This time, 'this' inside the function will be set to 'o'.
You can also do this:
var o = {};
f.call(o, 4);
