POV-Ray : Newsgroups : povray.off-topic : Coding in ___ is like ___ Server Time
16 Jul 2026 09:34:27 EDT (-0400)
  Coding in ___ is like ___ (Message 31 to 40 of 66)
Subject: Re: Coding in ___ is like ___
Date: 26 Feb 2010 11:40:43
Message: <4b87f98b@news.povray.org>
>>> Still, at least it's better than C.
>> Well, it's better than C for experts. For newbies, I think C is probably
>> easier, since there's less magic going on you need to know.
>   You mean newbies don't need to handle dynamically allocated memory?
>   Exactly which part of C is simpler for newbies than C++?
Simpler /= easier. ;-)
(If anybody out there still thinks simple and easy are in any way
correlated, try learning the Waltz. It has THREE STEPS IN IT, and yet
nobody can do it right for at least the first 20 minutes.)
Date: 26 Feb 2010 12:19:45
Message: <4b8802b1@news.povray.org>
Kevin Wampler wrote:
>>> Makes sense.  I think the runtime code generation was what I was
>>> particularly interested in,
>> Huh. That's one part I don't think changed that much.
> It's also entirely possible that I'm remembering
> incorrectly/incompletely here.
It *is* relatively primitive. But then, you *are* creating essentially
machine code. :-)  I just don't remember hearing of any significant changes.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 26 Feb 2010 12:21:03
Message: <4b8802ff$1@news.povray.org>
You don't have to deal with constructors, destructors, exceptions, the
difference between casing classes and casting pointers to classes, etc.
It's simpler *because* it's less powerful, in the same way that using an axe
is simpler for newbies than using a chainsaw.
Date: 26 Feb 2010 12:22:06
Message: <4b88033e$1@news.povray.org>
> One of these days I'm going to learn it just because I'm curious about
> it, but I haven't gotten around to it yet.
It's sort of like Perl, only more ... tabular, somehow. People don't use it
any more because computers are powerful enough to run things like Perl now.
Date: 26 Feb 2010 12:35:13
Message: <4b880650@news.povray.org>
  Why would a beginner need to deal with constructors, destructors,
exceptions and the like?
  No, C is a lot more complicated for the beginner precisely because it's
less powerful.
  In C++ the beginner can write things like this:
std::string concatenate(const std::vector<std::string>& strings)
    std::string result:
    for(int i = 0; i < strings.size(); ++i)
        result += strings[i];
    return result;
  Show me the same function implemented in C and explain how it would be
easier for a beginner (especially without any danger of memory leaks).
  And here I didn't even get to the things that the C standard library
doesn't support.
Date: 26 Feb 2010 12:37:45
Message: <4b8806e9$1@news.povray.org>
> it any more because computers are powerful enough to run things like
> Perl now.
As I understand it's pattern matching uses a recursive backtracking
algorithm, which should give it a bit of a Prolog flavor too.  This
seems distinct from the Perl way of doing things (although historically
the latter seems to won out as being more useful in practice).
Not that I know SNOBOL or Perl mind you, so I'm talking based mostly on
my impressions of Icon and Ruby respectively plus a bit of extra reading.
Date: 26 Feb 2010 12:52:44
Message: <4b880a6c$1@news.povray.org>
On Thu, 25 Feb 2010 23:11:33 -0800, Kevin Wampler wrote:
> Jim Henderson wrote:
>> On Thu, 25 Feb 2010 19:15:40 -0800, Kevin Wampler wrote:
>>> On 02/25/2010 05:20 PM, Jim Henderson wrote:
>>>>> http://web.mit.edu/~axch/www/writing_rant.html
>>>> He missed "Pseudocode", which I'd write as:
>>>> Coding in pseudocode is like a metaphor.
>>> I like it! (although given your sentence construction shouldn't that
>>> be "simile", or alternatively "Coding in pseudocode is a metaphor"?)
>> Technically, I guess "simile" would be correct there - I always get the
>> two mixed up.  :-)
> At least I have something to show for all the effort my teachers spent
> hammering the difference into my head!
LOL
Date: 26 Feb 2010 13:08:26
Message: <4b880e1a$1@news.povray.org>
Because they'll be using libraries that require such.  Even in your example,
you'd have to talk about the std::string constructor and how it creates an
empty string if you don't pass it arguments. As opposed to (say) integers,
that don't get initialized to zero. And what happens if you run out of
memory in your concatenate function.
> less powerful.
I disagree. It's more complicated to get things done, but easier to understand.
>     std::string result:
>     return result;
It would be easier to explain what's happening. I don't have to explain the
syntax for method invocation, const, references, the difference between
references and pointers, the differences between method invocations on
references and pointers, overloaded operators, or what namespaces are. The
function will be longer and more dangerous, but the only "unusual" things to
be explained are pointers and strings. Basically, in the C equivalent, the
only *confusing* part is that C doesn't allocate multi-word objects for you.
I take it you've never actually taught beginner computer programming
classes, yes?
It's not "how much power do you have."  It's "how much do you have to
dismiss as magic before you have a full understanding of the entire language."
Date: 26 Feb 2010 13:59:50
Message: <4b881a25@news.povray.org>
  You don't have to deal with constructors. You can simply say "if you create
a string without initializing it, it defaults to an empty string".
  As opposed to char*, which defaults to... what?
> As opposed to (say) integers, that don't get initialized to zero.
  Well, in C++ they decided that if you don't initialize an integer, its
value is not guaranteed. Bummer, but nothing to do with constructors.
  Your program will be ended because it ran out of memory.
> > less powerful.
  You seriously claim that eg. pointer arithmetic, null-terminated strings
and the standard C string manipulation functions are easier for a beginner
to understand than C++'s std::string? (And that's just one example.)
  Does the beginner really need to know what the compiler is doing under
the hood in this case?
> I don't have to explain the syntax for method invocation
  There was no method invocation in my example. (Ok, operator+() *is* a
method, and it's being called, but the beginner doesn't need to know that
in order to use string concatenation.)
> const, references
  The C version will also have a const (the function should take a const
pointer) if it's well written. So it's not all that different.
  If you really want to avoid the reference in the C++ version, you can:
    std::string concatenate(std::vector<string> strings)
  It will still work (although will probably be less efficient). No such
luck in C, though. You can't pass an array of strings by value. You'll
have to have a pointer (a const one, preferably).
> the difference between references and pointers
  You don't need to know the difference between references and pointers in
order to implement the "concatenate" function in my example. (And as
mentioned, you don't *necessarily* even need references at all if you
really want to avoid them.)
  My example didn't need any such thing.
  The beginner doesn't need to know that to implement that example.
  Is it really a bad thing that the beginner is introduced to namespaces
from the very beginning? It's not like they are very hard to understand.
> The
  No. The C version would require explaining lots of things about how C
null-terminated strings work internally (which you don't have to with
std::string), how you allocate space for them in your code (which you don't
have to with std::string), how you make sure you have allocated enough space
for the result (again, no need with std::string) and how you concatenate
the strings with strcat (the only thing more or less equivalent to the
+ operator of std::string).
  You would also need to explain that if the function returns a pointer to
a new C string it allocated itself, how the calling code needs to make sure
that it's not leaked. (Again, no such need with std::string.)
  So the C++ version is enormously simpler than the C version in all possible
regards. The newbie needs to learn a lot less and can start doing some
practical (and safer) code much more quickly.
  No, it isn't. You have to understand null-terminated strings, how to
calculate the length of strings, and how to manually manage the memory
for the strings before you could write such a function in C.
Date: 26 Feb 2010 14:09:44
Message: <4b881c78$1@news.povray.org>
> algorithm,
Now that you mention it, yes, I remmber that.
