Invisible <voi### [at] devnull> wrote:
> Tim Attwood wrote:
> > You can put isotopes in plastic to make self
> > powered lighting, governments just don't like the idea
> > of anything nuclear being used.
> > http://en.wikipedia.org/wiki/Tritium_illumination
> Interesting. I wonder what the half-life of tritium is? (You realise
> that once all of it decays, it stops glowing, right?)
Your google-fu fails you, once again.
Meh. Just over 12 years.
That *is* why it's fu, after all.
I like how you don't even have to hit "I'm feeling lucky" on that one. :-)
Forget "focus follows mouse." When do
I get "focus follows gaze"?
On 8-2-2010 5:54, Darren New wrote:
> andrel wrote:
>> Actually also that is partly true. If the cell did not maintain an
>> electric field over the membranes (both cell and SR) it would not
>> function.
> Yes, but I was under the impression that the depolarization happened
> across the cell membrane, rather than having ions or free electrons
> moving *along* the nerve like a wire.
They don't. Along the length of the axon ion channels are opening
causing ions to flow across the membrane. That in itself will trigger
the opening of channels close by and that will run as a bushfire over
the membrane.
> In other words, unlike a few messages up, it's not "electrical power"
> that's causing muscles to move and such. There's no electricity coming
> into or out of the nerve, but rather a change of potential across the
> membrane.
It is not electrical power, but more electronic signals. More ethernet
than power lines.
> andrel wrote:
>> No. It travels within a cell as an electrical signal.
> OK. I had thought it was ions moving, rather than free electrons.
It is ions. But there are no chemical reactions involved. Just charged
particles that move in space.
> the membrane.
Right. We're just arguing over what constitutes "electricity" now. Since it
was originally about supplying power to make illumination, I was assuming
the "electrons flowing thru a conductor" definition.
> than power lines.
Sure.
Interesting. Thank you.
>> the membrane.
> it was originally about supplying power to make illumination, I was
> assuming the "electrons flowing thru a conductor" definition.
For me electricity is a flow of charge. That includes holes in a
semiconductor. It may be that electrons are a required part of some
definition but not in physics or engineering.
