POV-Ray : Newsgroups : povray.off-topic : 99 lines of C++ for an unbiased ray tracer Server Time
4 Jul 2026 14:43:34 EDT (-0400)
  99 lines of C++ for an unbiased ray tracer (Message 41 to 50 of 65)
Subject: Re: 99 lines of C++ for an unbiased ray tracer
Date: 14 Jan 2010 17:51:23
Message: <4b4f9feb$1@news.povray.org>
Warp wrote:
> Orchid XP v8 <voi### [at] devnull> wrote:
>>>>>   Since sizeof() of an array returns the total amount of bytes taken by
>>>>> an array, if you divide it by the amount of bytes of one element, you get
>>>>> the total number of elements.
>>>> This is plain. What surprises me is that sizeof() can give you an
>>>> accurate size in the first place.
>>>   Why wouldn't it? The compiler has to know the size of the array if it
>>> wants to allocate it in memory.
>> All that stuff about "C does not know the size of an array at run-time,
>> and does not check array bounds".
>   That talks about dynamically allocated arrays, not statically allocated
> ones. They are different.
He's right, tho. C doesn't know the size of an array at run time. sizeof()
is a compile-time operator.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 14 Jan 2010 17:51:59
Message: <4b4fa00f$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Warp wrote:
>>>   Also the syntax of indexing an array and indexing memory using a pointer
>>> is identical, adding to the confusion.
>> Plus, you can't pass an array to a function, at least in C.
>   Not directly, but you can do it indirectly if you enclose the array inside
> a struct (in that case the array (inside the struct) is truly passed by
> value rather than by-pointer).
And in the original versions of C, you couldn't pass a struct by value
either. :-)
But yah, that's a good point I hadn't considered.
Date: 14 Jan 2010 18:18:49
Message: <4b4fa659@news.povray.org>
  If it knows it at compile time, it knows it at runtime. It's not like
it forgets somewhere in between... :P
Date: 14 Jan 2010 18:19:41
Message: <4b4fa68c@news.povray.org>
Out of curiosity I changed the location of the light to see that it really
renders it properly:
http://warp.povusers.org/images/smallpt.jpg
Date: 14 Jan 2010 23:50:25
Message: <4b4ff411@news.povray.org>
Well, no, I disagree. How do you find the size of an array at runtime?
That's exactly why you have to pass it around along with the pointer.
OK, I'll grant you that the generated code has that available, in the sense
that the loader avoids overwriting that space with other stuff, but it's not
available to the C-level program in any way at runtime.
You can take sizeof(x) at compile time, and store that somewhere that
runtime can find it, but there's nothing like Ada's myvariable'size
expression that would tell you at runtime what the size is for an arbitrary
array. There's no way to apply sizeof() to a non-array-name and find out the
size of an array (i.e., no way to say "what's the size of the array this
pointer points to").
Hmmm... If you put an array in a struct, can you ask
"sizeof(myrecord.thearray)" and get an appropriate size? I suppose you
could, but still I wouldn't count that as such.
Date: 15 Jan 2010 07:00:28
Message: <4b5058db@news.povray.org>
  It's a constant integral value, hence known at runtime.
  Now you are confusing dynamically allocated arrays with static arrays.
They are not the same thing.
  The size of dynamically allocated arrays cannot be resolved either at
runtime nor at compile time (eg. you cannot use the size of a dynamically
allocated array somewhere where a compile-time constant is expected).
  Yes, actually.
> I suppose you
  "As such"? What? Runtime? sizeof() always works at compile time.
Date: 15 Jan 2010 09:48:31
Message: <4b50803f@news.povray.org>
Warp escreveu:
did you make it coincident with the surface?
a game sig: http://tinyurl.com/d3rxz9
Date: 15 Jan 2010 11:08:26
Message: <4b5092fa@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> Warp escreveu:
  I have hard time deciding whether that was humorous or a serious question.
Date: 15 Jan 2010 11:20:32
Message: <4b5095d0@news.povray.org>
Warp escreveu:
>> Warp escreveu:
serious.  Did you put right where the left sphere surface would hit?
Date: 15 Jan 2010 11:44:07
Message: <4b509b56@news.povray.org>
> Warp escreveu:
> >> Warp escreveu:
  Unbiased monte-carlo rendering sends rays in a random fashion. It starts
extremely grainy, but the graininess gets reduced over time as the number
of samples gets increased. That image is the result of 30 minutes of
rendering in my computer (a virtually grainless result would have taken
days).
