![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> And not because, oh, I don't know, it's 100x smaller mass has
> significantly lower inertia to overcome in the first place?
That's only important once you get up to a high enough speed that you can't
overcome friction (about 10-20 mph in road cars, 60 mph in fast cars, up to
100 mph in racing cars). Before that coefficient of friction is the only
thing that matters.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> can't overcome friction (about 10-20 mph in road cars, 60 mph in fast
> cars, up to 100 mph in racing cars). Before that coefficient of
> friction is the only thing that matters.
My point being that a smaller mass requires a smaller force to
accelerate it, and thus less traction.
A cheetah's legs don't need to generate 500 BPH to get it from 0 to 60
in 4 seconds. Because a cheetah doesn't weigh a quarter of a ton...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> My point being that a smaller mass requires a smaller force to accelerate
Actually exactly the same traction. If you accelerate an object at 10 m/s^2
then it will need a coeffcient of friction of about 1.0 no matter what the
mass is. This is the point I was trying to make.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> m/s^2 then it will need a coeffcient of friction of about 1.0 no matter
> what the mass is. This is the point I was trying to make.
So a force of 1N and a force of 1,000N both require the same amount of
traction?
How does *that* work?!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> traction?
If the 1000 N force is on an object weighing 1000 kg, and the 1 N force is
on an object weighting 1 kg, then yes, they both require the same amount of
friction and will result in the same acceleration.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> traction?
> is on an object weighting 1 kg, then yes, they both require the same
> amount of friction and will result in the same acceleration.
This must truly be the definition of "counter-intuitive". I cannot begin
to imagine how this can be true. It is surely self-evident that applying
a large force requires better grip than does applying a small force.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> to imagine how this can be true. It is surely self-evident that applying a
Not if the contact force is proportionally higher.
Press your thumb and finger together very lightly and see how much sideways
force you need to slide them across each other. Now press them together
much harder and you'll find you need a much bigger sideways force to
overcome the friction.
It's the same with a 1000 kg car and a 10 kg animal, because the car is
pushing down on the road 100 times more than the animal it can generate 100
times more forward force before slipping.
http://en.wikipedia.org/wiki/Friction
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> force is on an object weighting 1 kg, then yes, they both require the
>>> same amount of friction and will result in the same acceleration.
>> begin to imagine how this can be true. It is surely self-evident that
>> applying a large force requires better grip than does applying a small
>> force.
I had assumed that the "amount of friction" already takes into account
the contact force, along with the surface roughness, deformability and
all the other things that affect friction.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Stephen wrote:
> Do you call that an argument? LOL
No, I call that a partly definition.
> From my memory of mechanics at school, hp was more an advertising unit ;)
> Bloody farmers couldn’t tell an erg from an egg :-)
Hp can be misleading, since it can mean lots of different hp's. It can
be either SAE or DIN and from the crankshaft or from the tires etc.
-Aero
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> traction?
In other news, both feathers and hammers fall at the same speed in airless
conditions.
Forget "focus follows mouse." When do
I get "focus follows gaze"?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
