Stephen wrote:
> What about xyz = the ratio of any circle's circumference to its diameter?
Define "circle". Now define "distance". Now we're getting somewhere.
Forget "focus follows mouse." When do
I get "focus follows gaze"?
> Define "circle".
The set of all points at distance r from the point c.
I actually can't find a definition for how to do this in a non-Euclidean
space.
Well, yes... I'm sure somebody somewhere has long since worked all this
out in excruciating detail. ;-)
http://blog.orphi.me.uk/
Why?
No we are here ;)
“Here and Now!” Quoth the mynah bird.
Best Regards,
If it's in Euclidean space, then it's pi, else it isn't.
Would you run that past me again, in English? :-)
Best Regards,
>>> diameter?
>> Define "circle".
> space.
Oh, I forgot. Now you have to also define the length of a curved line with
no endpoints. :)
Well, yes.
The main problem here is that xyz is not a constant, but is rather a
function. In spherical and hyperbolic spaces it can be defined as a
function of the radius so you need to say something like:
xyz(r) = the ratio of the circumference to the diameter of a circle of
radius r
If your space doesn't have a constant curvature, then it's a function of
yet more parameters.
The main issue isn't only that pi has a pre-existing meaning, it's that
the value in these non-euclidean spaces isn't even a constant.
I thought the underlying assumption in this thread was that we're
dealing spaces equipped with a metric tensor, do you automatically get a
definition of distance in the standard manner. How does this require
extra care to define?
I suppose you could argue that circles are a bit trickier to define, but
I think the normal one will work well, and should even be well-behaved
on genus-0 manifolds, or locally on any smooth manifold (like spherical
or hyperbolic spaces).
I take that back, it's obviously not quite well behaved on a sphere
(under some definitions of well-behaved) since there are no circles of
sufficient large radii.
>> should even be well-behaved on genus-0 manifolds
Any possible line segment in elliptic geometry can be used as a circle
diammeter. (Since lines that are "too large" to define a circle won't
fit into the space in the first place.)
