Invisible wrote:
> Heck, my Renault Megan holds 5 people and gets roughly 45 MPG.
OK, I misremembered. The official numbers are about 50MPG for the Prius, and
that's not even driving conservatively. In contrast, the same measurements
show the "smart twofour coupe" gets about 33 to 40 MPG.
The Megane seems to be a diesel car, which tends to get better mileage
anyway, and almost as good as a Prius running on gasoline.
Forget "focus follows mouse." When do
I get "focus follows gaze"?
Kevin Wampler <wam### [at] uwashingtonedu> wrote:
> Invisible wrote:
> > http://www.xkcd.com/687/
> > Interesting fact: In elliptic geometry, pi is less than arcsine 1. In
> > hyperbolic geometry, it's more than arcsine 1.
> I don't think this is true -- pi is defined in Euclidean space. Read
> the first sentence of the Wikipedia article on it.
Yeah. You can't say "pi is xyz" where xyz is something else than 3.1415...
because pi is *defined* as a *constant*, and constants don't change depending
on the situation. The definition of pi implies euclidean geometry.
Eero Ahonen wrote:
> - still having
> 150bhp/320Nm (upgradeable to 175bhp/370Nm with just a software) with
Let’s have an argument about the difference between hp and bhp, please. :-P
Best Regards,
What about xyz = the ratio of any circle's circumference to its diameter?
Best Regards,
OK, I rephrase: In non-Euclidian space, the ratio of a circle's
circumfirance to its diameter can be made arbitrarily large or small.
http://blog.orphi.me.uk/
Define "circle". Now define "distance". Now we're getting somewhere.
> Define "circle".
The set of all points at distance r from the point c.
I actually can't find a definition for how to do this in a non-Euclidean
space.
Well, yes... I'm sure somebody somewhere has long since worked all this
out in excruciating detail. ;-)
Why?
No we are here ;)
“Here and Now!” Quoth the mynah bird.
Best Regards,
If it's in Euclidean space, then it's pi, else it isn't.
Would you run that past me again, in English? :-)
Best Regards,
