POV-Ray : Newsgroups : povray.off-topic : Bounding circle intersection Server Time
21 Mar 2026 23:38:58 EDT (-0400)
  Bounding circle intersection (Message 31 to 40 of 43)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Bounding circle intersection
Date: 11 Dec 2009 08:29:36
Message: <4b224940$1@news.povray.org>
> Because you can use it to determine which side of the line a point is on?
How?
Example: Line through (0,0) and (0,1), and points either side of the line at
(1,0) and (-1,0)
Date: 11 Dec 2009 08:47:00
Message: <4b224d54$1@news.povray.org>
> How?
> line at (1,0) and (-1,0)
Suppose you have a line from point A to point B. Compute the vector AB,
the dot product V . A and call it k.
Which side of the line is point X on? Well, take the dot product V . X,
and subtract k. The result is negative on one side, positive on the
other, and zero if X is on the line itself (or at least, parallel to it).
...so basically, it's a ray/plane intersection test, except the "plane"
is a 2D slide - a line.
A = (0,0)
B = (0,1)
AB = (0,1) - (0,0) = (0,1) [already unital]
V = (0,1) * {(0,-1), (1,0)} = (-1,0)
k = (0,0) . (-1,0) = 0
X = (1,0)
X . V - k = (1,0) . (-1,0) - 0 = -1
Y = (-1,0)
Y . V - k = (-1,0) . (-1,0) - 0 = +1
QED.
Date: 11 Dec 2009 10:35:25
Message: <4b2266bd$1@news.povray.org>
> and subtract k. The result is negative on one side, positive on the other,
> ...so basically, it's a ray/plane intersection test, except the "plane" is
Sorry, but that seems much more complicated and using up more instructions
compared to the cross product:
> A = (0,0)
> B = (0,1)
No need to make AB unital for the cross product method (saves a square root
and divide).
No need to calculate V or k for the cross product method (saves some
multiplies and adds).
> X = (1,0)
X cross AB = (1,0) x (0,1) = (1)(1) - (0)(0) = 1
(saves one subtraction compared to your method)
> Y = (-1,0)
Y cross AB = (-1,0) x (0,1) = (-1)(1) - (0)(0) = -1
Date: 11 Dec 2009 10:44:12
Message: <4b2268cc@news.povray.org>
> root and divide).
Actually, thinking about it, you wouldn't need to for the dot product
either. I should have seen that...
>> X = (1,0)
Oh, I see. You're only computing the Z ordinate of the cross product?
Well, I guess that could be quicker, yes...
Date: 11 Dec 2009 10:49:26
Message: <4b226a06$1@news.povray.org>
Well the other 2 ordinates are always zero, so there seems little point :-)
Date: 11 Dec 2009 10:53:37
Message: <4b226b01$1@news.povray.org>
...that's true, of course. I had it in my head that you would only
compute the X and Y ordinates (which would take *more* effort than a
simple dot product). But, of course, that would be pointless.
I should go sit in the corner now. :'{
Date: 11 Dec 2009 12:25:51
Message: <4b22809f$1@news.povray.org>
On 12/11/2009 02:43 AM, Slime wrote:
>> Have you tried this condition?
>> ((distSq<  (radius1Sq+radius2Sq))
>> or (4*radius1Sq*radius2Sq>  (distSq - (radius1Sq+radius2Sq))^2))
> Smart. I feel stupid now! =) I see the equivalence, but I'm curious how long
> you took to come up with that. Was it obvious?
>   - Slime
>   [ http://www.slimeland.com/ ]
Well, it comes naturally from
distSq < radius1Sq + radius2Sq + 2 * radius1 * radius2
distSq - (radius1Sq + radius2Sq ) <  2 * radius1 * radius2
(distSq - (radius1Sq + radius2Sq ))^2 <  4 * radius1Sq * radius2Sq,
but the downside is that you have an overflow risk here to check
Date: 11 Dec 2009 13:23:06
Message: <4b228e0a@news.povray.org>
> ((distSq < (radius1Sq+radius2Sq))
> or (4*radius1Sq*radius2Sq > (distSq - (radius1Sq+radius2Sq))^2))
  I was curious to see how much of a difference sqrt() really makes compared
to avoiding it, so I made this C++ file:
#include <cmath>
#include <algorithm>
bool circlesCollide1(double cx1, double cy1, double rs1,
                     double cx2, double cy2, double rs2)
    const double vx = cx2 - cx1, vy = cy2 - cy1;
    return std::sqrt(vx*vx + vy*vy) < std::sqrt(rs1) + std::sqrt(rs2);
bool circlesCollide2(double cx1, double cy1, double rs1,
    const double dist2 = vx*vx + vy*vy;
    const double tmp = dist2 - (rs1 + rs2);
    return dist2 < rs1 + rs2 || 4.0*rs1*rs1 > tmp*tmp;
and then a main program to test the speed:
#include <iostream>
#include <ctime>
                     double cx2, double cy2, double rx2);
int main()
    double cx1 = -10.0, cy1 = -5.0, rs1_1 = 2.0*2.0, rs1_2 = 16.0*16.0;
    double cx2 = 5.0, cy2 = 10.0, rs2_1 = 2.5*2.5, rs2_2 = 18.0*18.0;
    const int iterations = 200000000;
    std::clock_t iClock = std::clock();
    for(int i = 0; i < iterations; ++i)
        circlesCollide1(cx1, cy1, rs1_1, cx2, cy2, rs2_1);
        circlesCollide1(cx1, cy1, rs1_2, cx2, cy2, rs2_2);
    std::clock_t eClock = std::clock();
    std::cout << "circlesCollide1: " << iterations << " iterations took "
              << double(eClock-iClock) / CLOCKS_PER_SEC << " seconds."
              << std::endl;
        circlesCollide2(cx1, cy1, rs1_1, cx2, cy2, rs2_1);
        circlesCollide2(cx1, cy1, rs1_2, cx2, cy2, rs2_2);
    std::cout << "circlesCollide2: " << iterations << " iterations took "
              << std::endl;
  I compiled with "-O3 -march=native" and got this result:
circlesCollide1: 200000000 iterations took 16.23 seconds.
circlesCollide2: 200000000 iterations took 5.42 seconds.
  (I didn't test that the functions give the correct result, though.)
Date: 11 Dec 2009 18:00:58
Message: <4b22cf2a$1@news.povray.org>
hmm, it looks that this sqrt-free test
will equally work in 3D for sphere-sphere intersection test.
Date: 11 Dec 2009 19:15:59
Message: <4b22e0bf$1@news.povray.org>
If you do this in 2D, minus the unnecessary normalization, the math is
equivalent to doing the 3D cross product while ignoring the components you
know to be 0.
inline vec_t Vec2Cross( const vec2_t v1, const vec2_t v2 )
 return v1[0] * v2[1] - v1[1] * v2[0];
If the result is positive, v2 points to the "left" of v1, otherwise it
points to the "right".
 - Slime
