POV-Ray : Newsgroups : povray.off-topic : An explanation of what next_permutation does Server Time
20 Dec 2025 06:17:33 EST (-0500)
  An explanation of what next_permutation does (Message 1 to 10 of 32)
Subject: An explanation of what next_permutation does
Date: 3 Dec 2009 02:21:54
Message: <4b176712$1@news.povray.org>
next_permutation being a subroutine in the C++ standard library that gives
you the lexographically next permutation of an array.
http://wordaligned.org/articles/next-permutation?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+wordaligned+(Word+Aligned)
Interesting. :-)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Subject: Re: An explanation of what next_permutation does
Date: 3 Dec 2009 09:08:38
Message: <4b17c666$1@news.povray.org>
Darren New wrote:
> Interesting. :-)
"while (!(*i < *--j)) {}"
Um, yeah, "interesting" would be the term I'd use. WTF? o_O
Personally, I'd do it this way:
nextP :: Ord x => [x] -> Maybe [x]
nextP []  = Nothing
nextP [x] = Nothing
nextP xs  =
   case split (reverse xs) of
     ([] , _  ) -> Nothing
     (ss', ps') ->
       let
         p0         = head ps'
         (ss0, ss1) = span (p0 >=) ss'
         s0         = head ss1
         ps         = reverse (s0 : tail ps')
         ss         = ss0 ++ [p0] ++ tail ss1
       in Just (ps ++ ss)
split :: Ord x => [x] -> ([x], [x])
split [] = ([], [])
split (x:xs) = work x xs
   where
     work x0 [] = ([x0], [])
     work x0 (x:xs)
       | x >= x0   = let (ys,zs) = work x xs in (x0:ys, zs)
       | otherwise = ([x0], x:xs)
Date: 3 Dec 2009 12:34:20
Message: <4b17f69c$1@news.povray.org>
C has always advocated piling up a bunch of side effects inside
conditionals.   Even to the point where Google's go has completely useless
syntax for doing so.
In go, you can write
   if x := y + 1; x > 5 { ... }
Which is always exactly precisely the same as
   x := y + 1;
   if x > 5 { ... }
Since you *always* need braces, and the result of evaluating the assignment
isn't ever used as the conditional, it's just a way of embedding
side-effects into a part of a statement that should be side-effect free,
apparently because the people designing go are so used to C's actually
*useful* side effects that they missed the result.
The above line could also be
   do { j -= 1; } while (*j <= *i);
(or maybe while *i < *j. I don't care to work it out for sure)
So, yeah, it's opaque C++ code there.
The algorithm is interesting, not the implementation.
Date: 3 Dec 2009 14:04:44
Message: <4b180bcc@news.povray.org>
> conditionals.
  OTOH, once you learn to read it, it's not that bad.
  It's a bit like using "++i" instead of "i = i + 1". The latter might be
clearer at first, but once you understand what "++i" means, not really.
Date: 3 Dec 2009 15:00:13
Message: <4b1818cd$1@news.povray.org>
>> conditionals.
Not in moderation. If something in the condition can't easily be expressed
outside the condition, it's helpful. For example,
   while (EOF != (c = getchar())) { ... }
You can't really put the assignment outside the condition without
duplicating that code, and it's kind of an accident of the design of the
libraries that means you can't find out the result from getchar without
invoking undesirable side-effect.[1] But convolving the comparison and the
decrement in this case was unnecessary, I think. Doing the decrement in the
body would say "keep decrementing until the condition is satisfied", which
doesn't really come across in the way it's written.
You definitely have to look at that expression to figure out what it's
doing. Of course, they could have reversed the letters and made it a little
clearer, too.
[1] You don't have this problem with iterators, for example, as you can just
as for "*j" as often as you want without changing "j".  Eiffel and Ada solve
it by requiring/suggesting that anything that has side effects doesn't
return a value. So in Eiffel, there's a (void) procedure to read the next
character into a buffer inside the object, and a function to get whatever
character was most recently read, so you don't need to do the assignment
inside the condition to save the character it returned, the way you need to
in non-OO C.
Date: 4 Dec 2009 10:53:15
Message: <4b19306b@news.povray.org>
Yeh, it's really clear what this line does to a non-Haskeller :-)
Date: 4 Dec 2009 10:57:47
Message: <4b19317b$1@news.povray.org>
I'll tell you what it does: It makes the function crash. o_O
It *should* in fact be
    (_  , [] ) -> Nothing
It seems I got my arguments the wrong way around. :-/
As for what it *means*, it means that if the prefix is empty ("[]"),
there is no next permutation ("Nothing"). The "_" simply means that it
doesn't matter what the suffix part is.
Date: 4 Dec 2009 11:19:16
Message: <4b193684@news.povray.org>
  After this you should really stop picking on C variants (or at the very
least, not immediately compare them to Haskell). ;)
Date: 4 Dec 2009 11:28:02
Message: <4b193892$1@news.povray.org>
Why? Because I wrote some code with a small typo?
Date: 4 Dec 2009 11:51:32
Message: <4b193e14$1@news.povray.org>
It's pretty standard notation for functional languages. Erlang uses the same
notation. If you get a two-element tuple with the first element being an
empty list, the result is an arbitrary atomic value (not unlike an "enum")
called "Nothing".
It's no less clear than function calls or array indexes if you've ever used
that operation before in a programming language. It's about as complex as a
case statement.
