POV-Ray : Newsgroups : povray.off-topic : Miracle products Server Time
5 Jul 2026 03:30:49 EDT (-0400)
  Miracle products (Message 5 to 14 of 114)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Miracle products
Date: 26 Nov 2009 07:46:38
Message: <4b0e78ae@news.povray.org>
Warp wrote:
>   You wouldn't believe how easily scientists themselves are fooled by
> magicians and tricksters because they, for whatever reason, don't understand
> the importance of some of the most basic scientifical testing, such as
> double-blind controlled tests.
>   The "double" there is quite important. Many scientists are way too
> confident on their own capacity to not to influence the test results and
> to interpret the results impartially.
It does happen. For example, some scientist designs a chemical that's
supposed to interact with a naturally occuring molecule in the human
body. They mix the chemicals in the lab, and it does what it's supposed
to. They pour the chemical onto a cell culture, and it does what it's
supposed to. They inject it into a mouse and it does what it's supposed
to. They inject the stuff into a human and... well, the effect smaller
than we expected, but it is still there.
Except that no, no it isn't. You're just *expecting* it to be there.
Confirmation bais.
In this instance, however, it seems unavoidable that the creators are
fully aware that their device is completely useless, and are simply out
to make a quick buck. The device has no remotely plausible mechanism of
action, and a trivial test quickly demonstrates that it is ineffective.
As an aside, I saw some physicist has built a flying machine that defies
current understanding. The device really does fly. And the scientists
really have no clue why it flies. (As best as I can tell, the device is
some sticks of wood with wires strapped to it, and you pump very high
voltage, high frequency electricity through it, and this makes it
levitate for some reason...)
Date: 26 Nov 2009 08:26:21
Message: <4b0e81fd$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4b0e6a77@news.povray.org...
> somebody wrote:
> And then, half way through, you see the manufacturer's claims. And it
> suddenly snaps into painfully sharp focus that this is pure fairy dust.
> 'The device can find guns, ammunition, drugs, truffles, human bodies and
> even contraband ivory at distances up to a kilometer, underground,
> through walls, underwater or even from airplanes three miles high. The
> Hah. Pull the other one, it's got bells on.
> Seriously. If they printed this nearer the top of the article, it would
> become more immediately clear that we're talking about utter nonesense.
One has to but marvel at the gutsiness of the scammers, not just at the
claims, but at the price tag of $15,000 to $60,000. But maybe that's the
trick, the more outlandish the claims and the higher the price, the easier
it's to reel in the suckers.
Subject: Re: Let's call Stockholm!
Date: 26 Nov 2009 08:28:20
Message: <4b0e8274$1@news.povray.org>
"TC" <do-not-reply@i-do get-enough-spam-already-2498.com> wrote in message
news:4b0e75a2@news.povray.org...
> The guys should be granted the Nobel Price, for sure.
> To be able to create an electrical field strong enough to attract ions
over
> a distance of 5000 m from a plane: respect!
And it doesn't even need batteries.
Date: 26 Nov 2009 08:33:48
Message: <4b0e83bc$1@news.povray.org>
I think I have seen that. Doesn't seem too difficult, if the wire and
sticks are light weight. A high voltage  would create some ionization
which would direct the air to flow around the wires. If everything is
small enough then that air flow, and the turbulence from the air hitting
the surface under the device, should be enough to lift it.
Look up negative ion generators, or build one yourself they are rather
easy. A bunch of capacitors and diodes in a ladder like arrangement.
"Capacitor diode ladder" being a good phrase to start googling from. Or
to just see it in action, and explained, check the Mythbusters
http://www.youtube.com/watch?v=Jk2GGoMJ7NU
Date: 26 Nov 2009 08:34:45
Message: <4b0e83f5$1@news.povray.org>
Indeed. Price it high enough and people will believe that it *must*
work, otherwise they wouldn't be able to sell it for that price.
It's a bit like the way MS sells Office for several hundred pounds,
convincing people that "it must be good if it's that expensive. Nobody
would buy it otherwise."
Date: 26 Nov 2009 08:36:27
Message: <4b0e845b$1@news.povray.org>
Well, the PhD who built it said he had no idea how it works, and none of
hsi collegues could figure it out either.
(One wonders though... If you don't know how it works, how did you make
it??)
Then again, this was on TV, so...
Date: 26 Nov 2009 09:41:26
Message: <4b0e9396@news.povray.org>
4b0e83f5$1@news.povray.org...
> Indeed. Price it high enough and people will believe that it *must* work,
http://en.wikipedia.org/wiki/Great_Oil_Sniffer_Hoax
Marc
Date: 26 Nov 2009 09:53:35
Message: <4b0e966f@news.povray.org>
There is a phrase that is somewhat over-used on the Internet which none
the less seems to fit this perfectly.
Truly Epic Failure.
Date: 26 Nov 2009 11:02:32
Message: <4b0ea698@news.povray.org>
Warp wrote:
> somebody <x### [at] ycom> wrote:
>> Just when I thought my opinion of humanity could not get any lower:
>> http://www.nytimes.com/2009/11/04/world/middleeast/04sensors.html
>> http://en.wikipedia.org/wiki/ADE_651
>> http://www.ade651.com/ade651in.html
> understand the importance of some of the most basic scientifical testing,
> such as double-blind controlled tests.
Didn't both the CIA and the KGB at a stage seriously study psychokinesis,
"reading" and other types of "extrasensory" phenomena for possible military
applications?
Stefan Viljoen
Date: 26 Nov 2009 11:06:14
Message: <4b0ea776@news.povray.org>
> applications?
Hey, studying things is a valid way to determine whether there's any
truth to them - provided you do the studying correctly and don't just
try to dream up data that supports the conclusion you want to reach. ;-)
