POV-Ray : Newsgroups : povray.off-topic : Modern Linux desktops suck Server Time
3 Jul 2026 02:47:00 EDT (-0400)
  Modern Linux desktops suck (Message 111 to 120 of 127)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Modern Linux desktops suck
Date: 23 Nov 2009 19:45:31
Message: <4b0b2cab$1@news.povray.org>
On 11/23/09 12:15, Jim Henderson wrote:
>> http://www.xkcd.com/619/
> Full-screen flash video support has been around for a while.
	Not really on Linux. It eats up the CPU, and doesn't seem to utilize
many capabilities of the graphics card - which the Windows plugins do.
"Graphic Artist seeks Boss with vision impairment."
Date: 23 Nov 2009 22:38:08
Message: <4b0b5520$1@news.povray.org>
utilize
I use it quite frequently, and while it does suck CPU, it does run full
screen, which is what the claim there was....
"Works for me"....
Jim
Date: 24 Nov 2009 04:23:41
Message: <4b0ba61d$1@news.povray.org>
>> Windows, on the other hand, has always been designed around the idea
>> that the user doesn't know anything about computers and needs to be
>> shielded from anything more complicated than a lightswitch. Which is
>> sometimes quite frustrating, in a different way...
> What that really means is that there are GUIs for all the n00b-level
> options and if there isn't, the Windows n00b will have to mess around
> with the arcane registry or RTFM for the first time in his life.
The things that require you to touch the registry are so arcane that
your average n00b wouldn't even comprehend what you're talking about.
Stuff like changing the network MTU, or the order in which IRQs are
assigned to PnP devices, or other such obscure stuff like that.
Usually the challenge is just figuring out which sub-sub-menu M$ has
hidden the setting you want under. (Or just which combination of options
makes the program behave correctly.)
> I like configuration files better than GUIs for no other reason that I
> can simply grep it for whatever I'm looking for or remotely related --
> direct to the point.
I'd be surprised if that actually works.
The option you want to change might be at default, and thus there's no
entry for it in the config file. It might have a highly non-obvious
name. Or it might be configured from a totally different file. (E.g.,
there is [presumably] a file somewhere which configures your network
interfaces. But the DNS configuration is in an entirely unrelated file.)
> In GUIs I have to go through a multitude of
> recursive menus or tabs hidden well underneath other options etc...
M$ does have an annoying habit of hiding absolutely every configuration
setting under an "advanced" tab...
Date: 24 Nov 2009 10:25:29
Message: <4b0bfae9$1@news.povray.org>
> utilize
> "Works for me"....
	Ah. You have a fast CPU.
	It's like saying "X works", when you don't have 3-D working. A major
"feature" of the plugin fails to work. From my perspective, that means
it *doesn't* work.
	Anyway, on many computers, including mine, playing HD videos full
screen on Flash gets jerky. CPU can't handle it, and the CPU isn't
supposed to handle it - the video card is.
Date: 24 Nov 2009 11:27:08
Message: <4b0c095c$1@news.povray.org>
> it *doesn't* work.
I have this persistent problem with my co-workers. Everyone was telling me
"yes, that works" and I'm saying "I'm getting no output" and they mean "it
compiled without errors."  Sheesh.
   You know the kamikaze monsters in Serious Sam
     with the bombs for hands, that go AAAAAHHHHHHHH!
   I want that for a ring tone.
Date: 24 Nov 2009 11:29:12
Message: <4b0c09d8$1@news.povray.org>
In particular, in a file that says nothing about DNS in the name or
contents. And even if you knew it was called the "resolver", they spell the
name of the configuration file *wrong*, so you can't even find it with 'find'.
Only the advanced ones you shouldn't screw with without knowing what you're
doing. :-)
Date: 24 Nov 2009 13:41:31
Message: <4b0c28db$1@news.povray.org>
The Linux Flash is still a crappy piece of shit. It's a resource hog and
still it's amazingly stupid (eg. won't handle second soundcard, even
though it supports ALSA).
-Aero
Date: 24 Nov 2009 14:06:16
Message: <4b0c2ea8@news.povray.org>
  Hardly Linux's own fault given that Flash is, at least in principle,
a proprietary format owned by Adobe, who also makes the Linux Flash plugin.
Date: 24 Nov 2009 14:27:51
Message: <4b0c33b7@news.povray.org>
I fully agree, the fault is on Adobe, which doesn't seem to be keen to
allocate resources to get the freaking thing to work. But still it's the
Linux version that's ultimately crappy, AFAIK Windows-Flash works much
better.
-Aero
Date: 24 Nov 2009 15:16:16
Message: <4b0c3f10@news.povray.org>
> better.
  But you can't blame Linux for that.
  OTOH the current plugin can be used for basically any Flash app out
there, so it's better than nothing.
