POV-Ray : Newsgroups : povray.off-topic : Locking references Server Time
13 Oct 2024 17:14:34 EDT (-0400)
  Locking references (Message 1 to 10 of 33)
Subject: Locking references
Date: 9 Nov 2009 05:43:30
Message: <4af7f252@news.povray.org>
I have heard it suggested that if every thread in a program takes
whatever locks it needs to take in sorted order, it is guaranteed that
deadlock can never occur.
Is this correct? And does anybody have a reference I can site?
Subject: Re: Locking references
Date: 9 Nov 2009 08:10:38
Message: <4af814ce$1@news.povray.org>
I'd think this is immediately obvious.
One issue is that a thread does not always know what locks it needs
before the fact.  And if you hold a lock and want to get another with a
lower key then you have to release the lock you hold then go back and
get them in the right order.
As to references, Wikipedia 'Deadlock' article is a decent starting
point.  Many more erudite references are given there.
Date: 9 Nov 2009 08:26:29
Message: <4af81885$1@news.povray.org>
Not to me. ;-)
> before the fact.
Yes, this is the killer. Often it's not possible to know what locks you
want until you read some data (which you have to lock first). And if you
release the locks, somebody else could come and change the data...
OK, I'll take a look.
Date: 9 Nov 2009 08:46:56
Message: <4af81d4f@news.povray.org>
Invisible wrote:
>> before the fact.
Isn't that the point? I've never worked with a low-level locking setup, but
I implemented a high-level one in the CMS I'm currently working on. If
somebody accesses a specific item, it is locked with a timeout. If he
doesn't commit changes within 15 minutes (or whatever is set), he "loses"
the lock, and somebody else can edit.
I.e. releasing a lock = it's ok for somebody else to change the data. You
have the lock = everybody else is blocked from changing the data?
Stefan Viljoen
Date: 9 Nov 2009 08:52:22
Message: <4af81e96$1@news.povray.org>
>>> before the fact.
My point is, you can't just go "I've got lock 7 and lock 13, and now I
need lock 2, so I'll just release lock 7 and lock 13, then take lock 2
and take back lock 7 and lock 13". In between releasing the locks and
taking them back, something could change. You need a better plan than that.
Date: 9 Nov 2009 09:19:30
Message: <4af824f1@news.povray.org>
> that.
Isn't this what a mutex (like it is implemented in the Linux kernel) is for?
Wik it a bit, I think it might be a partial answer to your original
question... :)
Stefan Viljoen
Date: 9 Nov 2009 09:36:13
Message: <4af828dd@news.povray.org>
Is this just theoretical interest or is there an actual problem that you
are trying to solve ?
In non-trivial cases like databases and operating systems the
possibility of deadlocks cannot be eliminated entirely.  The designers
seek to reduce the chances by good design but they also have to
implement 'deadlock detection' and 'deadlock resolution'.
Date: 9 Nov 2009 09:46:06
Message: <4af82b2e$1@news.povray.org>
I just saw this:
http://en.wikipedia.org/wiki/Gridlock
I can't help thinking that this should be an XKCD strip. I can just
imagine Black Hat Guy doing something to the timing of the traffic
signals to induce a mathematically indefinite deadly embrace. (And throw
in a pun or two in the process... Get it?... Process?)
Date: 9 Nov 2009 09:46:41
Message: <4af82b51$1@news.povray.org>
I've just implemented a solution; I'm trying to write it up. ;-)
Date: 9 Nov 2009 09:49:17
Message: <4af82bed@news.povray.org>
http://en.wikipedia.org/wiki/Deadlock_provision
...so, it's like the deadlock resolution algorithm where you randomly
terminate one process, except that you're terminating somebody's
*employment* instead?
Wow, that's pretty harsh. :-D
