POV-Ray : Newsgroups : povray.off-topic : Swell. Server Time
17 May 2026 23:37:03 EDT (-0400)
  Swell. (Message 33 to 42 of 312)
Subject: Re: Swell.
Date: 9 Nov 2009 10:56:11
Message: <4af83b9b$1@news.povray.org>
Stefan Viljoen wrote:
> Read a while ago that the RAF had to pay compensation to almost a hundred
> car owners - one of their air-defense "steerable-array" radars went haywire
> and scanned over a road - they burned out almost every vehicle's ignition
> and fuel injection microprocessors with the radar beam!
> The point being an old, mechanical vehicle ignition system (carburettors, a
> rotor and points) would have just driven on with no problems.
> Viz a viz mechanical against electrical failures...
It always amuses me how film writers seem to think that turning an
electronic device off makes it immune to an EMP... I thought the idea
was that an EMP will physically fry the thing like a microwave oven
fries CDs. :-P
Subject: Re: Swell.
Date: 9 Nov 2009 11:00:46
Message: <4af83cae@news.povray.org>
Invisible schrieb:
>> As for myself, I've never had much luck with optical media.  Trust
>> them way less than hard drives.
> Depends. We have a batch of archive CDs which have all gone unreadable.
> We have other, much older CDs (like ten years older) which are still
> readable to this day. Seems to depend on how cheap the disks are.
I must say that I wouldn't trust optical media any further than I can
throw them (which, of course, /can/ be quite far, but only in
non-turbulent air and if you know how... and if you're not out with a
dog who likes to play fetch...)
Subject: Re: Swell.
Date: 9 Nov 2009 11:15:20
Message: <4af84018$1@news.povray.org>
Stefan Viljoen schrieb:
> In the olden days on the Apple ][ with CP/M I had three - the grandfather,
> father and son (and holy ghost! :) - I still remember the stomach churning
> dread of those horribly loud floppy drives grinding and grinding and
> then "BDOS ERROR" on the monochrome green-screen... Those were the days!
That reminds me of those Iomega "jaz" drives that were all the rage 10
years ago. We had two or three "pools" (12 computers each) equipped with
those where I was studying back then, which were intended for the
Multimedia students to store their many hundreds of Megs on.
They seemed pretty fancy stuff - until it turned out that they could
contract a contagious disease, some hardware defect that would cause
them to screw up the storage media in just the right way to ruin the
next drive they'd be put into in just the same way...
Praise be to the inventor of the floppy disc that we didn't see /that/
in the days of the 3.5"-HD FDD!
>> If it's not...I dunno.  Data recovery places are expensive, and I don't
>> know if I can justify $1000+ even on the ~year's worth of data I had, at
>> the moment.  How time-critical are these kinds of things?  Can I just
>> keep it and when I have more money in a few months send it to a data
>> recovery place, if I can't get it working myself?
> Not sure, but I think the quicker you do it the better the results you might
> get?
I guess it depends. If the original fault would be a broken airseal,
you'd probably want to get the data out ASAP, before dirt can accumulate.
If the thing is still airtight, I don't think it makes any difference
whatsoever. In their all-metal casings, HDDs can keep their data for
quite a long time, and their only worthy adversary is particulate matter
of any size.
Subject: Re: Swell.
Date: 9 Nov 2009 11:18:39
Message: <4af840df@news.povray.org>
Invisible schrieb:
> Typically an external enclosure contains some kind of controller to
> convert from IDE/SATA/whatever to USB. This is a non-trivial piece of
> electronics, and it's not inconceivable that it could break.
> Seems kinda unlikely though...
Heh - believe it or not, but somme colleague of mine actually managed to
screw up a USB /stick/ just by accidently dropping it.
Subject: Re: Swell.
Date: 9 Nov 2009 11:29:01
Message: <4af8434d@news.povray.org>
You may recall that one of our BD people managed to damage a USB stick
somehow. When I did a block-level copy, I found that the first several
dozen blocks contained only zeros. I have *no idea* what the hell she
did to that thing... She's pretty ditzy though.
Subject: Re: Swell.
Date: 9 Nov 2009 11:33:06
Message: <4af84442$1@news.povray.org>
Invisible schrieb:
> I haven't seen any data about the reliability of SSD vs HD. Bare in mind
> that flash RAM has a theoretically limited number of write cycles.
I once read an article about that. Quintessence was that with a properly
  designed SSD, that does sophisticated "load balancing" of write cycles
across its memory blocks, it would take several /years/ of writing at
the maximum transfer rate to come anywhere close to the current limits...
And as storage capacity increases, so does the time it takes to screw up
any one block of a write-cycle-balancing SSD.
One caveat though, at least theoretically, is that the lifetime will
probably depend on how much data you store on the SSD. For instance, a
maxed-out drive doesn't have many spare blocks to balance write loads
on, so it might become technically possible to screw up a block by
repeatedly overwriting the same portion of a single file while leaving
all the other files unchanged.
Subject: Re: Swell.
Date: 9 Nov 2009 11:37:31
Message: <4af8454b$1@news.povray.org>
On Mon, 09 Nov 2009 06:52:54 -0500, Tim Cook wrote:
> You mean TB, mayhaps?
Yeah, that's what I meant.  Hey, it was 2:24 AM here when I posted
that. ;-)
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 11:38:29
Message: <4af84585@news.povray.org>
Invisible schrieb:
> Personally, I'd probably use SSD for my system partition (for the faster
> booting) and use cheap spinning disk for my POV-Ray renders. ;-)
How much storage capacity do you need for a Linux system partition?
They fit /entire/ Linux installations on a single CD, so...
Subject: Re: Swell.
Date: 9 Nov 2009 11:40:20
Message: <4af845f4$1@news.povray.org>
On Mon, 09 Nov 2009 16:32:33 +0100, clipka wrote:
> Jim Henderson schrieb:
>> Mirroring (or duplexing) provides a pretty good degree of data
>> protection because the odds of both drives dying at the same time are
>> pretty small.
> Yes. About the odds of your computer dying from a nearby lightning
> strike, drowning in water, or being consumed in a fire.
I've had a computer struck by lightning.  Thing is, anything plugged in
is likely to be affected by a lightning strike.
> Which /may/ be exactly one of the types of incidents one may want to
> protect against...
In which case you do the backup, break the mirror, and shut down the
extra drive, disconnecting it from the power and the system.
>> But I also back up directories from several systems to other systems
>> using rsync.
> Sounds more like it.
It's another option.
Jim
Subject: Re: Swell.
Date: 9 Nov 2009 11:43:11
Message: <4af8469f@news.povray.org>
On Mon, 09 Nov 2009 15:11:32 +0200, Stefan Viljoen wrote:
> Jim Henderson wrote:
>> On Mon, 09 Nov 2009 09:42:27 +0000, Invisible wrote:
>> See my anecdotal evidence in reply to Stefan.  Two identical units, one
>> powered on and off regularly, one that was left on 24x7.  Guess which
>> one failed?  Not the one that has been turned on and off regularly for
>> 5 years now.  The one that was plugged in and running for 3 years
>> solid.
> Hmm... well, no contest there. I guess there can be other factors
> involved besides on / off frequency then? My personal experience with
> server-grade hardware I've worked with differs though. It does seem (at
> least in my personal experience) that turning HDD's on and off less
> makes them last longer. But as you say, anecdotal. :)
Yeah, that's the problem with anecdotal evidence, of course.  Server
grade hardware that I've worked with has varied - I had a Compaq
Prosignia 4/66 with a RAID controller in it, and it had heat problems - I
occasionally would lose two drives in the array.  The system was used in
my home, so I didn't have the kind of cooling you'd have in a computer
room.
>>> PS. I've yet to find a consumer RAID controller which actually works
>>> properly. They all seem to be hopelessly unreliable. And most of them
>>> are software RAID anyway; the controller is a normal IDE or SATA
>>> controller, and the Windows driver does all the actual RAID functions
>>> in software. It seems that only the £££ server-grade controllers
>>> actually do the job properly.
>> Software raid exists for some platforms - and for mirroring for backup
>> purposes, that's really all you need.  Heck, you could do it over iSCSI
>> with a fast enough connection (I've seen that done as well).
> I've written a simple cronjob which uses bash scripting and some
> command-line PHP to automatically tar/7zip our primary server's vital
> sites and databases once every 24 hours, and then FTPs that over to our
> over server in a different datacenter automatically. Works fine too. The
> data centers are about 10km away from each other.
I operate a website for our local community council, and while the system
is hosted by a local ISP, I take a nightly backup as well - using sshfs
for the files and a cron job to dump the database.
> That way we can lose only one day's worth of changes, which (cause we're
> small!) usually isn't much. But I can see the point of some kind of
> "live" solution if you do a TB a day or whatever.
Yep.
Jim
