POV-Ray : Newsgroups : povray.off-topic : Swell. Server Time
17 May 2026 08:03:09 EDT (-0400)
  Swell. (Message 171 to 180 of 312)
Subject: Re: Swell.
Date: 10 Nov 2009 14:42:47
Message: <4af9c237$1@news.povray.org>
Darren New schrieb:
> Steam needs to give you that option, yah. Did you ask them? :-) I don't
> remember if Steam asks where to install Steam when you install it. I
> don't see any obvious way to change it after the fact.
As I have Steam installed in "F:\Spiele\Steam", and the games it
installed are located in subdirectories thereof, it must be doing
/something/ right...
Subject: Re: Swell.
Date: 10 Nov 2009 16:59:41
Message: <4af9e24d$1@news.povray.org>
>> On unix, where even now it is still quite common to do stuff in some
>> command line shell, it is pretty uncommon to put blanks in filenames,
>> because it would be a hassle to even "cd" there.
> That used to be true back in the 1.x days of Linux (like, 10 years ago),
> but nowadays I haven't had much problem with spaces in file names,
> except in lazy scripts I've written myself using "$@" and such. (And
> that's more because it's easier for me to skip the one-line script than
> to look up the proper quoting mechanism to get that in.)
> Bash command-line completion, for example, will put quotes around names
> with spaces in them.  But yes, this wasn't always common, even long
> after Mac and Windows commonly used spaces in names.
Correct me - isn't Unix that OS that allows you to put *any* arbitrary
octet sequence into a filename so long as it doesn't contain NUL or "/"?
(E.g., you could name a file with ANSI escape sequences in it if you
felt especially vindictive.)
http://blog.orphi.me.uk/
Subject: Re: Swell.
Date: 10 Nov 2009 17:01:08
Message: <4af9e2a4@news.povray.org>
>> The Steam installer allows you to choose where to install it.
> Cool. I'll remember that.
> Of course, with Steam, you can just uninstall everything, reinstall to a
> different drive, and then re-download the games, not losing anything at
> all.
Not quite true: You lose any saved games, for example. And you have to
re-download several GB of data, which could take several days.
What you can do instead is do a "game backup", and then later a "game
restore". This is officially supported, and there are instructions
somewhere...
Subject: Re: Swell.
Date: 10 Nov 2009 17:02:10
Message: <4af9e2e2$1@news.povray.org>
>> Maybe not, that's sounds like a good idea! If you can aim and modulate it
>> right a one-second high intensity burst might do the job on a
>> computerised
>> injection and ignition system...
> And your brain. You realize it's basically microwaves, right? Like from
> your oven?
Didn't the USA come up with a crowd dispersal device which *actually
does this*??
Subject: Re: Swell.
Date: 10 Nov 2009 17:05:23
Message: <4af9e3a3@news.povray.org>
>> Actually, from what I remember of the Technical Manual, it's not a 1:1
>> multiplicative correlation between warp speed and c, more like
>> exponential.  Warp 1 *is* c, but warp 10 is 'occupies every point in
>> universe simultaneously' and requires theoretically infinite
>> energy...warp 9 is Really Really fast.  Because just 10x the speed of
>> light still leaves months, if not *years* between most stars.
> ... and it tears holes into the subspace, though they kept that secret
> until some seasons into TNG. What was the speed limit after that? Warp
> 5? Or was it Warp 3?
> But then again, Warp isn't a multiple of c anyway, it's a level of
> distortion of spacetime (hey, it messes seriously with /normal space/,
> so how could they possibly expect to not affect /subspace/?) while you'd
> still travel sub-lightspeed, possess a finite real mass, and just need
> to travel a significantly shorter distance.
Until they invented the Trans-Warp Drive...
Subject: Re: Swell.
Date: 10 Nov 2009 17:07:25
Message: <4af9e41d$1@news.povray.org>
>> Really? I would have thought running around requires *lots* of muscle
>> power. (That's why I can't do it, for example...)
> Comparatively speaking.  Running doesn't take unusual amounts of muscle
> power. Running when three 300-pound linebackers are holding you down
> takes unusual amounts of muscle power.
Compared to sitting still watching the game on TV, it involves *a lot*
of muscle. ;-) And I can't really imagine that baseball requires less
muscle power than football...
> If you can't run fast, it's because you're doing it wrong. Don't think
> about your legs. Start running, then move your arms as fast as you can.
> Running is in the arms, not the legs. (Hence the "runs like a girl"
> concept.)
I rephrase: I can run very, very fast indeed. I can't do this for more
than a few seconds, however.
Subject: Re: Swell.
Date: 10 Nov 2009 17:10:50
Message: <4af9e4ea@news.povray.org>
>> After about 4 years the tape would wear out, but that's hardly a big
>> deal assuming you notice this and replace the tape.
> And if you replace the disk drive on the same basis, you'll have better
> reliability. :-)
Doubt it, but I don't have any numbers to prove anything either way, so
it's an empty argument.
>> I *have*, however, had endless issues with BackupExec not actually
>> ****ing working properly! >_<
> That's the other problem. When's the last time you copied a file, then
> went to open it and found it wasn't there?
The problems were more that you'd configure BE to perform a backup, and
then next day it has crashed rather than perform a backup. VERY helpful.
In fairness, when was the last time you tried copying a file that
somebody else was still using? Not so easy, is it?
Subject: Re: Swell.
Date: 10 Nov 2009 18:30:02
Message: <4af9f77a$1@news.povray.org>
Trivial on Linux.  And on NetWare under the right conditions - file
flagged shareable, no op-locks in use...
Jim
Subject: Re: Swell.
Date: 10 Nov 2009 18:54:58
Message: <4af9fd52$1@news.povray.org>
Yes. This is what makes getting real production scripts really working a
living hell on UNIX. :-)  Try to delete files more than a week old out of
/tmp without ever giving anyone the opportunity to delete /etc/passwd, for
example.
Subject: Re: Swell.
Date: 10 Nov 2009 18:55:46
Message: <4af9fd82$1@news.povray.org>
> does this*??
Something like that, yes. Actually, it was for the military. The civilian
police use the one that's just loud. :-)
