![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> Warp wrote:
>> The size of a font refers to its height, not its width.
> I had a vague recollection this might be the case.
>> (And the "height" is that between two baselines in the font. The font
>> graphics themselves can go over those lines.)
> That at least makes some kind of sense...
And there is 72 points to the inch.
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Depending on who you ask. ;-)
(PostScript assigns 72 points to the inch, TeX assigns 72.72, and
apparently other systems assign yet other values.)
Fortunately, in this instance I'm only interested in PS.
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
True ask me, I worked in printing just after hot metal went out of
fashion. LOL
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> fashion. LOL
Ok: how many points in an inch?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 3-11-2009 11:49, Invisible wrote:
> Does *anybody* here know what the hell the width of each character in a
> Courier 10pt typeface is?! (Apparently it isn't 10pt.)
I did a simple test: I used Open Office writer. Selected Courier New and
type as many spaces as I could fit on a line. There were 66, the ruler
showed that that was in approximately 16.8 cm. So we have
66/(16.8/2.54) characters per inch. Or about 9.9786.
Great. Minor detail, the font size is 12.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> fashion. LOL
72 LOL
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> In other words, given a 10pt font, there is no way to determine how tall
> or wide any of the letters are. (E.g., they could be 10pt, 1pt,
> 1000pt...) This is very helpful. :-/
Look in the font file. It can be converted to human readable with
probably several things. I use fontforge.
> As I say, it appears to be exactly 6pt. But I have no idea why...
Correct.
-Shay
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> tall or wide any of the letters are. (E.g., they could be 10pt, 1pt,
The PostScript Courier font is hard-wired into the printer. I have no
idea how to get at it.
> Correct.
Much experimentation and many trees later... ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible schrieb:
>>> Well, by a series of experiments, I have discovered that the neither
>>> the character width or character hight of Courier 10pt is actually
>>> 10pt. The distance from the baseline to the capline is more like
>>> 5.5pt or something, and the distance between characters appears to be
>>> exactly 6pt...
>> Yes, the "pt" in fonts is a rather arbitrary measurement. I guess in
>> traditional typesetting it would refer to the height of the metal
>> "block" from which the letters were cut, so even there it would be
>> only indirectly related to the actual glyph dimensions.
> Well, the glyph will be smaller than the metal block to allow some
> whitespace around the glyph. But you'd think 10pt would be either the
> width or the hieght of the block... Apparently it is neither.
Note that the block had to accomodate not only capital letters, but also
underliners, as well as accent symbols above capital letters; so if the
capital letters are 5.5 pt in height, a block height of 10 pt appears
realistic to me.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Exactly.
There's some meta-information in font files though.
> Still doesn't help me figure out how wide the letters of Courier 10pt
> are. (Being a monospace font, all the letters should be the same width...)
Typewriters typically used a spacing of 10 or (less commonly) 12
characters per inch, i.e. a character width of 7.2 pt (10 cpi) or 6.0 pt
(12 cpi).
With 10 pt and 12 pt being the most common nominal font sizes on
computers, it makes sense to design a pixed-pitch font to match the
common typewriter pitch of 7.2 pt (to be able to print on forms
originally designed for typewriters) at a nominal font size of 12 pt, as
this also allows to emulate the 6.0 pt pitch by simply changing the
nominal font size to 10 pt.
Hence the exact 6 pt pitch of the Courier font at a nominal font size of
10 pt.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
