POV-Ray : Newsgroups : povray.off-topic : Programming langauges Server Time
9 Jul 2026 02:38:35 EDT (-0400)
  Programming langauges (Message 61 to 70 of 114)
Subject: Re: Programming langauges
Date: 26 Oct 2009 10:59:01
Message: <4ae5b935$1@news.povray.org>
Invisible schrieb:
> Captain Jack wrote:
>> I remember having written a game on a portable Unix machine (with a
>> Motorala 68010 processor) and being amazed at what happened with my
>> save files when I moved to my first DOS machine (with an 80386
>> processor); I hadn't ever had to deal with byte order before that. In
>> that case, the save data was relatively small, so I re-wrote it to
>> save in ASCII printable characters, which solved that problem. :)
> It still makes me sad that Intel chose to store bytes in the wrong order
> all those years ago...
Define "wrong" in this context...
As a matter of fact, the only situation where byte ordering can be
defined as "right" or "wrong" with irrefutable arguments is in serial
transmission, dependent on the native bit ordering of the physical
layer: If the physical layer sends each byte starting with the least
significant bit, then consistency would demand to send multi-byte values
starting with the least significant byte, so that all in all the least
significant bit of the multi-byte value is sent first; on the other
hand, if the physical layer transmits the most significant bit of each
byte first, the same reasoning would mandate sending the most
significant byte first. There are other arguments pro and contra both
little and big endian, but none as compelling as serial transmission.
It so happens that Intel format is actually doing it "right" in this
respect: AFAIK two of the most important serial interfaces - RS232 and
Ethernet - both transmit each byte starting with the least significant
bit first.
So in this sense the "network byte ordering" used for multy-octet data
in most Internet standards is actually a crappy convention, as the bits
of multi-byte data will be transmitted in an inconsistent order.
BTW, Intel is not the only company that preferred little-endian convention.
Date: 26 Oct 2009 11:16:05
Message: <4ae5bd35$1@news.povray.org>
>> order all those years ago...
When you read data from a first, you read the first byte first, and the
last byte last. Therefore, the first byte should be the MSB. But no,
Intel decided that this would be too easy. And now we have the spectacle
of cryptosystems and so forth designed with each data block being split
into octets and reversed before you can process it...
> bit first.
Well then that would be pretty dubious as well. (AFAIK, MIDI does it the
correct way around.)
Indeed, the 6502 did it decades ago. Still doesn't make it right.
Date: 26 Oct 2009 11:33:36
Message: <4ae5c150$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4ae5bd35$1@news.povray.org...
> last byte last. Therefore, the first byte should be the MSB. But no, Intel
> decided that this would be too easy. And now we have the spectacle of
> cryptosystems and so forth designed with each data block being split into
That kinda sounds like saying that the only correct way to read a human
language is left to right.
.ti ot desu t'nera yeht fi neve ,enif tsuj tfel ot thgir daer nac elpoeP
:D
Date: 26 Oct 2009 11:43:47
Message: <4ae5c3b3$1@news.povray.org>
As far as I know, even in languages that are usually written from right
to left, the most significant digit is still written "first" and the
least written "last".
But hey, why worry? I'm communicating with you right now using a code
that still has codepoints resurved for obsolete control signals like
BEL, RS, SYN and EOT...
(Don't get me started on the whole EOL marker thing!)
Date: 26 Oct 2009 11:55:08
Message: <4ae5c65c$1@news.povray.org>
> last byte last.
OK...
That's not a very good argument.
Little-endian rulez!
It just seems way more natural if you are writing any sort of processing
with bits/bytes etc that array index zero should be the LSB.
Date: 26 Oct 2009 11:59:14
Message: <4ae5c752$1@news.povray.org>
Seriously: Why? Just because us Westerners writing numbers this way round?
Note that this digit ordering has its drawbacks; as a practical example,
have a look at any data table: While all the text columns are usually,
left-adjusted, numbers are always right-adjusted, because otherwise they
wouldn't line up.
 > But no, Intel decided that this would be too easy.
It wasn't Intel who made that decision. As mentioned before, they were
not the only ones to follow this path.
That is not because little-endian would be wrong, but because the
cryptosystems usually happen to be specified to use big-endian in- and
output (owing to the fact that big-endian has become quasi-standard in
Internet protocols). They would work just as well with little-endian
values - but then the big-endians would have to do the byte reversal, or
the algorithms would simply be incompatible.
So you can just as well blame this problem on the people who kept
insisting on big-endian byte ordering.
>> bit first.
Again: Why would that be dubious? The only reason I can think of is the
convention how we write numbers, but that's just a convention, and - as
shown above - not even an ideal one.
Wouldn't it be more convenient to start with the least significant
digit, and stop the transmission once you have transmitted the most
significant nonzero digit? If you did that the other way round, you'd
have no way to know how long the number will be, and won't be able to
determine the actual value of each individual digit until after the
transmission.
>> convention.
And your arguments so far don't make it wrong. Unconventional maybe (in
the most literal sense) - but not wrong.
I think the terms "little-endians" and "big-endians" for adherents of
each philosophy are pretty suitably chosen (see "Gulliver's Travels" by
Jonathan Swift).
Date: 26 Oct 2009 12:03:16
Message: <4ae5c844$1@news.povray.org>
...and this *is* a good argument??
Think about it. If you store the textural representation of a number in
ASCII, the most significant digit comes first. But if Intel has their
way, the most significant byte comes... last? And if you have to split a
large number into several machine words, unless you number those words
backwards, you get monstrosities such as
   04 03 02 01 08 07 06 05 0C 0B 0A 09
instead of
   01 02 03 04 05 06 07 08 09 0A 0B 0C
as it should be.
There's no two ways about it. Little endian = backwards.
Date: 26 Oct 2009 12:10:47
Message: <4ae5ca07$1@news.povray.org>
>> the last byte last. Therefore, the first byte should be the MSB.
Because the most significant digit is the most important piece of
information. It's "most significant".
>> split into octets and reversed before you can process it...
> output.
Erm, NO.
This happens because most cryptosystems are (IMHO incorrectly) specified
to *not* use big-endian encoding.
This means that if I want to implement such a system, I have to waste
time and effort turning all the numbers backwards before I can process
them, and turning them back the right way around again afterwards. It
also means that when a paper says 0x3847275F, I can't tell whether they
actually mean 3847275F hex, or whether they really mean 5F274738 hex,
which is a completely different number.
> transmission.
If you start from the least digit, you *still* can't determine the final
size of the number until all digits are received.
Date: 26 Oct 2009 12:14:26
Message: <4ae5cae2$1@news.povray.org>
I must say that I see benefits in both conventions.
For instance, the arbitration scheme used on a CAN bus mandates that
bits are sent highest bit first, so that the numerical value of the data
identifier directly governs the message priority (lower data ID = higher
message priority).
Date: 26 Oct 2009 12:17:56
Message: <4ae5cbb4$1@news.povray.org>
I'm pretty sure that in arabic, where numbers come from, the LSB is written
first (i.e., arabic, right-to-left, writes digits in the same order as we do).
The benefit of MSB first is that it's in "readable" order. The benefit of
LSB first is that you can easily find the LSB in case you want to move the
bytes from a long to a short, for example.
I saw one discussion that printed hex dumps with the addresses incrementing
for the ASCII part and decrementing for the numeric part, with the address
in a column down the middle, which made reading little endian numbers trivial.
And since it's all imaginary anyway, and there is *NO ORDER* to bytes in a
computer, it's all just mathematical relationships between powers of a
polynomial and addresses, any argument you make against LSB vs MSB you can
also make against writing polynomials one way or the other.
