POV-Ray : Newsgroups : povray.off-topic : Mysteries of the universe Server Time
21 Jun 2026 05:19:53 EDT (-0400)
  Mysteries of the universe (Message 94 to 103 of 223)
Subject: Re: Mysteries of the universe
Date: 3 Sep 2009 17:32:48
Message: <4aa03600$1@news.povray.org>
Orchid XP v8 wrote:
> ...with the disadvantage of having a maximum string size,
Every machine has a maximum string size. What you really mean is "a maximum
string size small enough I've bumped into it often enough to be annoying."
I knew a professor who taught "There's two kinds of programming languages.
Those that support bounds-checks on their fundamental data types, and those
that don't know they need to support bounds-checks on their fundamental data
types."  (Or something to that effect.)
Date: 3 Sep 2009 18:21:19
Message: <o9g0a5lg4dtr5vudl78nljlbslns66ppei@4ax.com>
On 3 Sep 2009 12:17:42 -0400, Jim Henderson <nos### [at] nospamcom> wrote:
>and software like Harvard Graphics
A rave from the grave :)
Regards
Date: 3 Sep 2009 18:23:33
Message: <fdg0a550066nhe0d5dt32s1dj0pcr2tiul@4ax.com>
On Thu, 03 Sep 2009 23:14:25 +0200, andrel <a_l### [at] hotmailcom> wrote:
>> Look at the insulators, they are a strange shape. That shape ensures that they
>> are not covered with a continuous layer of water. Magic, isn't it :)
>For some reason I saw nobody referring to these as 'magic mushrooms', I
>wonder why.
'Caus you'd be spaced out :)
Regards
Date: 3 Sep 2009 18:25:56
Message: <6gg0a51pqtdkiqlh5lbv7jh2sm6n5htjgt@4ax.com>
On 3 Sep 2009 11:54:01 -0400, Jim Henderson <nos### [at] nospamcom> wrote:
>On Thu, 03 Sep 2009 09:14:41 +0100, Invisible wrote:
>> Rain water isn't chemically pure. (Depending on pollution levels.) Once
>> the pylon gets wet, it's entire surface is covered in a continuous sheet
>> of water, which also covers all of the cables. So why don't they short
>> out?
>Because the bare wire isn't exposed, it's insulated.
Not on this side of the pond, Jim.
>And in order to
>short out, you have to have a path for electrons to flow.  Arguably it
>would take a pretty strong rainstorm to give the current someplace to go
>to.
I think he means jump or track to.
Regards
Date: 3 Sep 2009 18:27:59
Message: <6mg0a5l66q3doqp5allqor5c70bmgl9arn@4ax.com>
On 3 Sep 2009 11:58:49 -0400, Jim Henderson <nos### [at] nospamcom> wrote:
>On Thu, 03 Sep 2009 10:06:55 +0100, Stephen wrote:
>> So it is much simplier
>> and cheaper for overhead cables to be left bare and make sure that there
>> is a lot of space between them.
>Weird, over here, the power lines are insulated....
Yes but you Yanks have money to burn :P
Regards
Date: 3 Sep 2009 18:36:05
Message: <f2h0a55k8m88ftlt24nvv8p9rv3vemaolq@4ax.com>
On Thu, 03 Sep 2009 17:59:21 +0200, "Fredrik Eriksson"
<fe79}--at--{yahoo}--dot--{com> wrote:
>On Thu, 03 Sep 2009 17:37:20 +0200, Stephen <mcavoysAT@aoldotcom> wrote:
>> Actually it is quite hard to ignite petrol from a petrol pump with a
>> naked flame.
>That depends on the flame.
Yip! A thermite lance or a nova will do it ;)
>> Besides having a LEL (Lower Explosive Limit) petrol has an Upper
>> Explosive Limit (UEL) where above that level the gas/air mixture is
>> too rich to burn. In the open air the gas/air mixture goes from too
>> rich to too leen very quickly. I once saw a petrol pump attendant put
>> a lit cigarette into the mouth of a full petrol tank.
>http://www.intuitor.com/moviephysics/mpmain.html#cigarettes
That agrees with what I said, I think.
Regards
Date: 3 Sep 2009 18:55:20
Message: <op.uzpdykcg7bxctx@bigfrog.bredbandsbolaget.se>
>>> naked flame.
A match will do just as well.
Regarding cigarettes, yes.
FE
Date: 3 Sep 2009 20:56:26
Message: <4aa065ba@news.povray.org>
Indeed - I remember the classes on that (not that I took them, but I
worked in the computer lab so helped students who were having problems),
it was really interesting.
One of the things that made it interesting was that each table had two
printers on it that shared a print queue.  The way HG would print, you
could end up with half the graphic on one printer, and half on the
other. :-)
Jim
Date: 3 Sep 2009 20:58:25
Message: <4aa06631$1@news.povray.org>
>>> Once the pylon gets wet, it's entire surface is covered in a
>>> continuous sheet of water, which also covers all of the cables. So why
>>> don't they short out?
Interesting, I hadn't noticed that - but I hadn't really thought to
look. :-)
>>And in order to
>>to.
Yeah, but it still would want to go to ground, and the water doesn't
provide a grounding influence that's stronger than staying with the wire.
Jim
Date: 3 Sep 2009 20:58:45
Message: <4aa06645$1@news.povray.org>
>>> there is a lot of space between them.
Not any more we don't.  We're burning China's money. :P
Jim
