POV-Ray : Newsgroups : povray.off-topic : Mysteries of the universe Server Time
20 Jun 2026 20:35:01 EDT (-0400)
  Mysteries of the universe (Message 91 to 100 of 223)
Subject: Re: Mysteries of the universe
Date: 3 Sep 2009 16:14:20
Message: <4aa0239c$1@news.povray.org>
>> IIRC, in Turbo Pascal, position 0 is the length. (And since it's a
>> single byte, no strings longer than 255 characters...)
> Yep, Turbo Pascal stored the length rather than using the C method of
> null-terminating the string.
...with the disadvantage of having a maximum string size, and the
advantage of making certain memory management operations much easier...
Ah, the days of plain ASCII, before anybody spoke of Unicode. Hey, wait
a sec - C is *still* back in the days of plain ASCII...
http://blog.orphi.me.uk/
Date: 3 Sep 2009 16:16:46
Message: <4aa0242e$1@news.povray.org>
Yep.
Not with a good unicode library. ;-)
Jim
Date: 3 Sep 2009 17:14:25
Message: <4AA031B1.7090906@hotmail.com>
On 3-9-2009 11:09, Stephen wrote:
> On Thu, 03 Sep 2009 10:06:46 +0100, Invisible <voi### [at] devnull> wrote:
>>>> Rain water isn't chemically pure. (Depending on pollution levels.) Once
>>>> the pylon gets wet, it's entire surface is covered in a continuous sheet
>>>> of water, which also covers all of the cables. So why don't they short out?
>>> There are insulators between the cables and pylons so there is no path for the
>>> electricity to flow there.
>> Indeed. This is why it works when they're dry.
>> However, when those insulators are covered with a continuous layer of
>> water...
> Look at the insulators, they are a strange shape. That shape ensures that they
> are not covered with a continuous layer of water. Magic, isn't it :)
For some reason I saw nobody referring to these as 'magic mushrooms', I
wonder why.
Date: 3 Sep 2009 17:32:48
Message: <4aa03600$1@news.povray.org>
Every machine has a maximum string size. What you really mean is "a maximum
string size small enough I've bumped into it often enough to be annoying."
I knew a professor who taught "There's two kinds of programming languages.
Those that support bounds-checks on their fundamental data types, and those
that don't know they need to support bounds-checks on their fundamental data
types."  (Or something to that effect.)
Date: 3 Sep 2009 18:21:19
Message: <o9g0a5lg4dtr5vudl78nljlbslns66ppei@4ax.com>
On 3 Sep 2009 12:17:42 -0400, Jim Henderson <nos### [at] nospamcom> wrote:
>and software like Harvard Graphics
A rave from the grave :)
Regards
Date: 3 Sep 2009 18:23:33
Message: <fdg0a550066nhe0d5dt32s1dj0pcr2tiul@4ax.com>
>wonder why.
'Caus you'd be spaced out :)
Regards
Date: 3 Sep 2009 18:25:56
Message: <6gg0a51pqtdkiqlh5lbv7jh2sm6n5htjgt@4ax.com>
>> out?
>Because the bare wire isn't exposed, it's insulated.
Not on this side of the pond, Jim.
>And in order to
>short out, you have to have a path for electrons to flow.  Arguably it
>would take a pretty strong rainstorm to give the current someplace to go
>to.
I think he means jump or track to.
Regards
Date: 3 Sep 2009 18:27:59
Message: <6mg0a5l66q3doqp5allqor5c70bmgl9arn@4ax.com>
On 3 Sep 2009 11:58:49 -0400, Jim Henderson <nos### [at] nospamcom> wrote:
>On Thu, 03 Sep 2009 10:06:55 +0100, Stephen wrote:
>> So it is much simplier
>> and cheaper for overhead cables to be left bare and make sure that there
>> is a lot of space between them.
>Weird, over here, the power lines are insulated....
Yes but you Yanks have money to burn :P
Regards
Date: 3 Sep 2009 18:36:05
Message: <f2h0a55k8m88ftlt24nvv8p9rv3vemaolq@4ax.com>
On Thu, 03 Sep 2009 17:59:21 +0200, "Fredrik Eriksson"
<fe79}--at--{yahoo}--dot--{com> wrote:
>On Thu, 03 Sep 2009 17:37:20 +0200, Stephen <mcavoysAT@aoldotcom> wrote:
>> Actually it is quite hard to ignite petrol from a petrol pump with a
>> naked flame.
>That depends on the flame.
Yip! A thermite lance or a nova will do it ;)
>> Besides having a LEL (Lower Explosive Limit) petrol has an Upper
>> Explosive Limit (UEL) where above that level the gas/air mixture is
>> too rich to burn. In the open air the gas/air mixture goes from too
>> rich to too leen very quickly. I once saw a petrol pump attendant put
>> a lit cigarette into the mouth of a full petrol tank.
>http://www.intuitor.com/moviephysics/mpmain.html#cigarettes
That agrees with what I said, I think.
Regards
Date: 3 Sep 2009 18:55:20
Message: <op.uzpdykcg7bxctx@bigfrog.bredbandsbolaget.se>
>>> naked flame.
A match will do just as well.
Regarding cigarettes, yes.
FE
