POV-Ray : Newsgroups : povray.off-topic : Mysteries of the universe Server Time
21 Jun 2026 07:04:51 EDT (-0400)
  Mysteries of the universe (Message 84 to 93 of 223)
Subject: Re: Mysteries of the universe
Date: 3 Sep 2009 13:31:47
Message: <4a9ffd83$1@news.povray.org>
Darren New schrieb:
> scott wrote:
>> Anyway, take 200 metres of this stuff (which I make weighs 10 tons):
>> http://www.csunitec.com/saws/new-river-band-saw.html
> Cool. It doesn't really look that big from the ground, does it?
Those are cables for underground power transmission. They need an awful
lot of insulation I bet. So overhead lines are likely to be a good deal
thinner. The German Wikipedia mentions a typical cross-section of 60
mm^2 of steel surrounded by 257 mm^2 of aluminum, so the diameter should
be close to 20 mm.
Date: 3 Sep 2009 14:06:38
Message: <4aa005ae@news.povray.org>
Fredrik Eriksson <fe79}--at--{yahoo}--dot--{com> wrote:
> On Thu, 03 Sep 2009 17:55:43 +0200, Darren New <dne### [at] sanrrcom> wrote:
> > Warp wrote:
> >>    AFAIK the bright colors work as a warning signal. Predators learn to
> >> distinguish the poisonous prey by their color.
> > This clearly works poorly if the prey is so poisonous they kill the
> > predator with one meal.
> It works perfectly if the predator does not eat the prey himself, but
> instead feeds his offspring with it.
  Note that not all poisons are deadly.
Date: 3 Sep 2009 14:40:00
Message: <web.4aa00cd139795a72a7b77dd90@news.povray.org>
> Oh, there's the snake. GIYF.  Can you tell which is poisonous and which
> isn't? Notice the different order of the stripes.
"Red on yellow, kills a fellow..." I forget the rest, but remembering the first
part is enough, really.
-Reactor
Date: 3 Sep 2009 14:50:53
Message: <4aa0100d$1@news.povray.org>
The rest goes "Red on Black will kill Jack."
Me, I'll stay away from both of em. ;-)
Date: 3 Sep 2009 15:21:03
Message: <4aa0171f$1@news.povray.org>
On Thu, 03 Sep 2009 11:50:51 -0700, Darren New wrote:
>> the first part is enough, really.
But your name isn't Jack, at least I don't think it is. ;-)
Jim
Date: 3 Sep 2009 15:56:23
Message: <4aa01f67$1@news.povray.org>
>> As *I* remember, Pascal arrays start at whatever index you tell them to
>> start at. (E.g, you can make the first index be 17 if you want...)
>> VAR stuff : ARRAY [17..21] OF INT;
> I was thinking positions for a string.  In Pascal, using the string
> "abcdef", position 1 is "a".  In C, it's position 0.
Probably.
IIRC, in Turbo Pascal, position 0 is the length. (And since it's a
single byte, no strings longer than 255 characters...)
http://blog.orphi.me.uk/
Date: 3 Sep 2009 16:01:30
Message: <4aa0209a$1@news.povray.org>
>>> to start at. (E.g, you can make the first index be 17 if you want...)
> Probably.
Yep, Turbo Pascal stored the length rather than using the C method of
null-terminating the string.
Jim
Date: 3 Sep 2009 16:14:20
Message: <4aa0239c$1@news.povray.org>
...with the disadvantage of having a maximum string size, and the
advantage of making certain memory management operations much easier...
Ah, the days of plain ASCII, before anybody spoke of Unicode. Hey, wait
a sec - C is *still* back in the days of plain ASCII...
Date: 3 Sep 2009 16:16:46
Message: <4aa0242e$1@news.povray.org>
Yep.
Not with a good unicode library. ;-)
Jim
Date: 3 Sep 2009 17:14:25
Message: <4AA031B1.7090906@hotmail.com>
On 3-9-2009 11:09, Stephen wrote:
> On Thu, 03 Sep 2009 10:06:46 +0100, Invisible <voi### [at] devnull> wrote:
>>>> Rain water isn't chemically pure. (Depending on pollution levels.) Once
>>>> the pylon gets wet, it's entire surface is covered in a continuous sheet
>>>> of water, which also covers all of the cables. So why don't they short out?
>>> There are insulators between the cables and pylons so there is no path for the
>>> electricity to flow there.
>> Indeed. This is why it works when they're dry.
>> However, when those insulators are covered with a continuous layer of
>> water...
> Look at the insulators, they are a strange shape. That shape ensures that they
> are not covered with a continuous layer of water. Magic, isn't it :)
For some reason I saw nobody referring to these as 'magic mushrooms', I
wonder why.
