POV-Ray : Newsgroups : povray.off-topic : You know... Server Time
9 Nov 2026 23:23:59 EST (-0500)
  You know... (Message 21 to 48 of 48)
<<< Previous 20 Messages Goto Initial 48 Messages
Subject: Re: You know...
Date: 28 Aug 2009 03:51:04
Message: <4a978c68$1@news.povray.org>
> Heh. I don't even go that far.
Yeh the written test (which they do unsupervised) is meant to test the basic
Engineer (and maths) fundamentals.  In the mechanics test we throw in a few
easy electronics questions and vice versa.
> I just have a bunch of questions like "why do they call it raytracing" and
> "what's the difference between a deterministic and a non-deterministic
> state machine" and "what causes a SIG_SEGV" and "what's the difference
> between an inner join and an outer join" and "what's an advantage of UTF-8
> over other encoding schemes" and "what does a translation look-aside
> buffer translate".
We have ones like "draw a diagram to show how an injection molding machine
works" :-)  It's surprising how few people get taught this at university (I
certainly wasn't), yet most people at least have a rough idea what's going
on.
> If you can't get at least a handful of such questions right from outside
> the field you're applying for, I know you're inexperienced, unschooled, or
> uninterested/incapable of expanding your responsibilities.
We have a separate section of the interview where we give them an LCD and
tell them to take it apart and talk through what they think each bit does,
why it's like that, etc.  It's a good one because virtually nobody has ever
done this before so it puts everyone on an equal level, and there are plenty
of mechanical and electrical things to talk about.
Date: 28 Aug 2009 04:32:53
Message: <4a979635$1@news.povray.org>
> and tell them to take it apart and talk through what they think each bit
> does, why it's like that, etc.  It's a good one because virtually nobody
> has ever done this before so it puts everyone on an equal level, and
> there are plenty of mechanical and electrical things to talk about.
And here I was thinking that all the components are microscopic...
Date: 28 Aug 2009 04:36:18
Message: <4a979702@news.povray.org>
Darren New wrote:
> Heh. I don't even go that far. I just have a bunch of questions like
> "why do they call it raytracing" and "what's the difference between a
> deterministic and a non-deterministic state machine" and "what causes a
> SIG_SEGV" and "what's the difference between an inner join and an outer
> join" and "what's an advantage of UTF-8 over other encoding schemes" and
> "what does a translation look-aside buffer translate".
> or uninterested/incapable of expanding your responsibilities.
...OK, how many other people here felt an irresistablel urge to try to
answer all of those?
Date: 28 Aug 2009 04:39:15
Message: <4a9797b3@news.povray.org>
>> I will admit to having done some absurd things like that in introduction
>> to programming classes. Not for having forgotten how to solve the
>> problem, but for the challenge of finding a very bad design and the look
>> on teaching assistants faces when they have to read the code and offer
>> feedback.
> That's cold.  I had a friend who used the entire McDonalds value menu for
> variable names.  Or I think I brought this up before, but I knew someone
> learning c who programmed a sudoku solver and stored the whole thing in binary,
> only the binary numbers were in decimal (e.g. 110110010.999999).  It involved a
> lot of logarithms and powers of ten.
Amatures.
Real coders define a continuation monad who's operators are all ASCII
art, and generate spaghetti code using an epimorphism over endofunctors.
Deobfuscate THAT! O_O
Date: 28 Aug 2009 05:19:37
Message: <4a97a129$1@news.povray.org>
I'd be having trouble with the translation look-aside buffer right now.
I have a feeling that it's about cache memory, or command execution
queue, but that's about how far I spontaneously get without resorting to
My Friend.
But aside from that - yeah :-)
Date: 28 Aug 2009 05:23:55
Message: <4a97a22b@news.povray.org>
> My Friend.
TLB - convert from virtual memory addresses to physical memory
addresses. It's basically a cache of the page mappings. (Let's face it,
accessing RAM for every memory access to figure out where in physical
memory the requested virtual address is would be *really* slow...)
I only know this because I read the Intel reference manuals. For no
reason other than curiosity.
Date: 28 Aug 2009 05:27:59
Message: <4a97a31f@news.povray.org>
Err no, each component is roughly the same size as the display itself.  eg
for a typical 2.0" phone display each component is going to be the same
order of magnitude.  Of course the electronic circuits that are actually on
the glass panel itself are too small to see, for the electronics guys (yes
we only get male applicants) we just show them some simplified circuit
diagrams of important stuff, showing them the transistors under a microscope
wouldn't be too helpful.
Date: 28 Aug 2009 05:28:38
Message: <4a97a346$1@news.povray.org>
I could answer the first one :-D
Date: 28 Aug 2009 05:30:40
Message: <4a97a3c0$1@news.povray.org>
I'd first need to deobfuscate your sentence :-P
Date: 28 Aug 2009 05:31:05
Message: <4a97a3d9$1@news.povray.org>
> Real coders define a continuation monad who's operators are all ASCII art,
We had a function called Viagra in our code.  It was called every second to
check if the lifting arm on our robot was still in the fully raised
position, and if not activate the motor until it hit the limit switch.
Date: 28 Aug 2009 05:31:50
Message: <4a97a406$1@news.povray.org>
> eg for a typical 2.0" phone display each component is going to be the
> same order of magnitude.  Of course the electronic circuits that are
> actually on the glass panel itself are too small to see, for the
> electronics guys (yes we only get male applicants) we just show them
> some simplified circuit diagrams of important stuff, showing them the
> transistors under a microscope wouldn't be too helpful.
Yeah, but, I thought it contains stuff like a half-wave plate (which is
nanometers thick) and stuff.
Date: 28 Aug 2009 05:32:46
Message: <4a97a43e@news.povray.org>
A better question might be "why do they call it a relational database?"
So many people get that one wrong...
Date: 28 Aug 2009 05:35:17
Message: <4a97a4d5@news.povray.org>
>> endofunctors. Deobfuscate THAT! O_O
> to check if the lifting arm on our robot was still in the fully raised
GEEK HUMOUR FTFW!
Date: 28 Aug 2009 05:38:09
Message: <4a97a581$1@news.povray.org>
Actually the half-wave plate (or quarter-wave plate) is part of the
polariser sheet (which contains lots of other layers), these are typically
0.2-0.4mm thick and can easily be seen attached to both sides of the glass.
We expect most candidates to at least have a very basic idea how an LCD
works (we tell them this before the interview).
Other optical sheets in the backlight, like the diffuser and prism array
sheets are thinner, but still easily visible and handle-able as they are all
the same size as the display itself.  In fact you can run your finger nail
along the sheet to see if has any prism structure on it, you could probably
work out the spacing of the prisms from the pitch of the sound somehow
without the need for any microscope.  Also there is another sheet in there
that just looks like a mirror, but obviously it doesn't reflect all the
light or the display wouldn't work.  THat's another good one to ask them
about.
Date: 28 Aug 2009 05:42:47
Message: <4a97a697$1@news.povray.org>
Trust me, if I had the time and energy, I could probably come up with
something horribly contorted in Haskell.
1. It lets you define functions with names like **_<#_^_#>_**
2. It lets you write lines of code and automatically inserts hidden
function calls between them.
3. It allows functions to construct other functions.
Need I continue? Suffice it to say, you could do some seriously messed
up stuff with this puppy...
Date: 28 Aug 2009 05:53:10
Message: <4a97a906$1@news.povray.org>
Ah yes - those animals. I knew I had read about TLBs somewhere somewhen.
Did that, too - but that's probably about a decade ago, and apparently I
never really needed that stuff :-)
Date: 28 Aug 2009 05:55:31
Message: <4a97a993$1@news.povray.org>
LOL! Talk about self-explanatory identifiers :-P
Date: 28 Aug 2009 06:08:13
Message: <4a97ac8d$1@news.povray.org>
I was trying to build a new OS, remember? :-}
(Warp's assessment was correct - I never got past a boot loader that
didn't actually load anything.)
Date: 28 Aug 2009 07:58:55
Message: <4a97c67f@news.povray.org>
  Same here: I knew the concept existed, but the I was not so familiar
with its *name* that I could make the connection.
  Which makes the question maybe a bit unfair: Even if the person does know
what it is about, if he can't remember it from its name, it will look like
he doesn't know about that subject at all.
  Besides, in which job would it be necessary to know this?
  Unicode encodings? Certainly useful to know. Basic SQL knowledge? Can
become handy sometimes even in jobs not directly related to databses.
Knowing what a TLB is and how it works? Exactly where do you need to know
that? It's not like knowing that would change the way you develop programs.
Date: 28 Aug 2009 08:12:05
Message: <4a97c995$1@news.povray.org>
Well, I guess the idea is that by asking *lots* of [admittedly fairly
arbitrary] questions, you get some idea of whether the person in
question knows anything.
Date: 28 Aug 2009 09:29:44
Message: <4a97dbc8$1@news.povray.org>
> programs.
I think any programmer (that isn't just a code-monkey being told what to do)
should have a good understanding of the hardware and what it does and
doesn't do.  Not knowing what a TLB is kind of makes it obvious you don't
really know about the hardware in much detail.  If you don't know what a TLB
is, then you probably also don't know much about how the cache or pipelining
system works.
Date: 28 Aug 2009 11:42:45
Message: <4a97faf5$1@news.povray.org>
Here's my full current list. Each one can be answered in a word or a
sentence or so. There's no deeply tricky questions. Just in case you want to
play around.
Why is it called "Ray tracing"?
Name an important property of a controlled not gate.
What's the difference between an inner join and an outer join?
What part of the computer does RAID affect?
What is the difference between a deterministic and a nondeterministic state
machine?
What colors make up a pixel? Why?
What does O(N^2) measure? What does it mean?
What does a JIT compiler do?
What gets routed over a Petri net?
What causes a SIG_SEGV?
What is the difference between call by reference and call by value?
What are some of the other "call by's" you understand?
What is Byzantine fault tolerance?
Describe several ways to guarantee the prevention of deadlocks.
Describe an advantage of having multiple partitions on a disk
for one operating system.
Name an important difference between threads and processes.
What is a stop bit?
What is a logical contrapositive?
What is a difference between swapping and paging?
Why is the "halting problem" important?
What is an imaginary number? Name a situation where it is useful.
What is a fencepost error? Describe a good way to avoid them.
What does cache coherence mean?
What is priority inversion? How does it happen? How is it "cured"?
What is an advantage of having an index on a relational database table?
What is a disadvantage of having an index on a relational database table?
Name an advantage that UTF-8 has over other Unicode encoding schemes.
What is a rewrite rule?
What is cryptographic non-repudiation?
What does ACID mean in database systems?
What part of the Internet protocol suite is CIDR involved in? Why was it
invented?
How would you sort a list that is too big to fit in memory at once?
What does a fourier transform do? What does it transform into what?
What protocol do "web services" usually use? Name as many levels of
protocol encapsulation as you can, from the application down
to the hardware.
What is unified by the process of logical unification?
What is an important difference between "SOAP" and "REST"?
What is a symetric cryptographic algorithm?
What is a TCP Window?
How does TCP ensure reliability?
Name an important difference between a tar file and a zip file.
What is a CNAME in DNS?
What are the layers called in the OSI protocol stack? What does each do?
Name something the CPU does differently between Kernel mode and User mode.
What is inheritance in an object-oriented system? What is delegation?
What distinguishes a functional programming language from other paradigms?
What property of its input data does a radix sort need that a qucksort does not?
What does SMTP stand for?
What does it mean to say a programming language is "safe"?
What problem does NAT solve in the Internet Protocol world?
Why do computers use binary numbers?
Name one advantage of WIMP over CLI.
Name one advantage of CLI over WIMP.
What does it mean for a system to be "hard real-time"?
What does a translation look-aside buffer translate?
Name one problem with automated garbage collection.
Describe the difference between access control lists and
capability-based permissions.
What does a VM mean, when speaking of programming languages?
What does a VM mean, when speaking of operating systems?
What is a "managed environment," speaking of programming languages?
What is the advantage of 2's compliment arithmetic?
What is a CGI script? How does it differ from an Apache or IIS module?
What is MIME? What benefit does it provide?
* * * Harder questions * * *
What is a business-object layer, and why is it helpful?
What are some advantages of the relational database model over earlier models?
In an RDBMS, what is a primary key? A foreign key? How do you choose
the primary key columns and foreign key columns of a table?
What benefits do ASN.1 object identifiers have over URIs
when used as arbitrary identifiers naming protocol information?
What are some disadvantages?
What is your favorite programming language? Why? What's wrong with it?
What is the most unusual programming language you've learned, even a little?
What makes it unusual? Why did you learn it?
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 28 Aug 2009 11:52:32
Message: <4a97fd40@news.povray.org>
Of course, I can give hints in person. :-)
Computer programming. You should know how the system works, what a L1 vs L2
cache is, etc. If you're writing an OS, you probably should know how page
tables work.
This whole thing started when I was working with a guy named Kevin. He was
an OK programmer, but I kept having to bail him out of corners he'd painted
himself into.  At one point, he had a big complicated way of keeping track
of where he was in a network protocol, using strings with stars and plus
signs and zeros and such to track what messages he'd seen and such, and I
said "why not just use a state machine?"  He said "What's a state machine?"
So the deterministic vs non-deterministic question was the first one on my list.
As I said, these are to assess your breadth of knowledge. It's like asking
someone to write a program to compute prime numbers - you'll never have to
do that at work either.
Date: 28 Aug 2009 11:55:12
Message: <4a97fde0@news.povray.org>
LOL!  I definitely know some engineers I'll tell this one to.
The old OS I worked on had a routine called Enable Interrupts for External
Input and Output. The first comment was "with a sync sync here and a nak nak
there".
Date: 28 Aug 2009 12:14:15
Message: <4a980257@news.povray.org>
  The only places I have heard where they use state machines is in formal
verification apps and regular expression interpreters. But I suppose there
are tons of other places where they are useful as well... :)
  But I think there's a big difference between knowing how to calculate
prime numbers and knowing how virtual paging works at hardware level
(which is completely transparent to everyone except maybe operating system
developers).
Date: 28 Aug 2009 12:43:43
Message: <4a98093f$1@news.povray.org>
Um, network protocols?
http://images.google.com/images?q=tcp+state+machine
> developers).
Yes, there is such a difference. That's why I ask both questions.
And if I need you to figure out what's broken in the OS's paging algorithms
in a year's time, I'd like you to know enough about the subject to be able
to understand a tutorial on the topic.
I don't expect you to know how to program quantum computers, either, but I
expect you to know what quantum computing *is*, to the point that you could
fool the boss into thinking you know something about it. :-)
Anyway, that's one of many questions. If you're working for me, you'll
probably never need a ray tracer, either. But it would be good for you to
know that a ray tracer takes a 3D description and turns it into an image,
for example.
You could say "I'll never need to know that" about every question on that
entire list. A web designer doesn't need to know what a stop bit is or what
priority inversion is. A hardware designer doesn't need to know why you'd
want an index on a relational database table or what protocols web services
use.  It's a breadth of knowledge thing.
Date: 28 Aug 2009 15:34:33
Message: <4a983149@news.povray.org>
> nak there".
EIEIO
http://en.wikipedia.org/wiki/GNU_Hurd#Error_messages
Date: 28 Aug 2009 15:45:37
Message: <4a9833e1@news.povray.org>
> want to play around.
Duh - and I tend to consider myself an all-rounder...
That's a pretty nice one, especially the third part ;-)
> little?
That, too, is a smart thing to ask.
