POV-Ray : Newsgroups : povray.off-topic : This is great Server Time
31 Mar 2026 07:04:07 EDT (-0400)
  This is great (Message 5 to 14 of 94)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: This is great
Date: 21 Aug 2009 05:54:25
Message: <4a8e6ed1$1@news.povray.org>
It burns! IT BURNS!! >_<
I especially like the claims of "every time we added debug code, the bug
went away". Surely it is impossible to work under such conditions...
Date: 21 Aug 2009 06:00:00
Message: <web.4a8e6f77bb556bbb6dd25f0b0@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> http://www.gamasutra.com/view/feature/4111/dirty_coding_tricks.php
> I especially like the last one.
I prefer the penultimate one - the idea of the comedy developer face in the
corner of the screen getting all grr! when the frame rate drops - made me
chuckle.
Date: 21 Aug 2009 06:04:03
Message: <4a8e7113$1@news.povray.org>
> chuckle.
Not so much a coding trick as an interesting application of
psychology... but bizare, all the same. ;-)
Date: 21 Aug 2009 06:23:14
Message: <4a8e7592@news.povray.org>
Not impossible, but it should make you realise that developing software for
profit is quite different than doing it as a hobby.
Date: 21 Aug 2009 06:25:41
Message: <4a8e7625$1@news.povray.org>
> for profit is quite different than doing it as a hobby.
It certainly makes me realise that I prefer safe languages over
efficient ones any day of the week. :-P
Date: 21 Aug 2009 06:30:00
Message: <web.4a8e76b3bb556bbb6dd25f0b0@news.povray.org>
> > chuckle.
Well, it had to be coded, didn't it? :)
He should have made the angrier faces steadily greener! I guess that would have
taken the edge off the psychology.
Date: 21 Aug 2009 08:48:50
Message: <4a8e97b2@news.povray.org>
Heisenbugs are always lots of fun. ;)
~Mike
Date: 21 Aug 2009 09:38:36
Message: <4a8ea35c$1@news.povray.org>
Well, I tell you that's pure reality. Last project I was working on,
"let's just ship the device with debug output X enabled by default" was
quite a common suggestion during troubleshooting. We managed to keep it
a joke though - the customer would not have been amused.
And some issues we did indeed fix using the "if you're falling through a
hole, don't do it" kind of approach, because the errors occurred so
infrequently that we just had no chance of ever finding the root cause.
Yeah, it's kind of fun developing software for devices where
occasionally the only way to get any helpful debug information out of
the thing is by switching an LED on or off, and errors might just as
well be hardware-related.
Date: 21 Aug 2009 09:43:03
Message: <4a8ea467$1@news.povray.org>
You can get such issues with "safe" languages, too: All you need is some
race conditions that kick in when performance is particularly good, but
don't if performance is bogged down a deal by debug output.
Date: 21 Aug 2009 10:01:23
Message: <4a8ea8b2@news.povray.org>
  That was a relatively common problem in C and C++ years ago, but nowadays
especially C++ compilers have got much better at debugging such things. For
example Visual C++, when compiling in debug mode, will add bounds checks to
all STL code and IIRC raw array accesses (although there are limits to the
latter, as it's quite difficult to check bounds when pointer arithmetic is
being performed). gcc has a precompiler constant which, when defined, turns
on similar checks to all STL code. Then you can use valgrind to catch the
rest.
  The only situation nowadays where you might end up having such heisenbugs
in C++ which are not caught by the compiler even in debug mode is if you
use dirty raw pointer arithmetic hacks, which is something you seldom really
have to do in clean good-quality code, not even if you aim for maximum
efficiency.
