POV-Ray : Newsgroups : povray.off-topic : Hee hee ... AMD Opterons, and it runs on SuSe Linux Server Time
21 Dec 2025 14:00:10 EST (-0500)
  Hee hee ... AMD Opterons, and it runs on SuSe Linux (Message 1 to 10 of 10)
Subject: Hee hee ... AMD Opterons, and it runs on SuSe Linux
Date: 19 Aug 2009 09:18:57
Message: <4a8bfbc1$1@news.povray.org>
http://www.cray.com/Products/XT5m/Product/Specifications.aspx
You know what I'm thinking .... 192 per cabinet XD
BTW, I didn't know there were 6-core CPU's out, now?
~Mike
Subject: Re: Hee hee ... AMD Opterons, and it runs on SuSe Linux
Date: 19 Aug 2009 09:38:15
Message: <4a8c0047@news.povray.org>
Would be a nice heater for the winter.
Date: 19 Aug 2009 11:53:31
Message: <4a8c1ffb$1@news.povray.org>
Yeah, I hear there's a few in the pipeline if not actually relased quite
yet. (But then, I know that from Wikipedia, so...)
Date: 19 Aug 2009 11:54:21
Message: <4a8c202d$1@news.povray.org>
Cache  	64K L1 instruction cache, 65K L1 data cache
I'd like to know how they worked *that* trick.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 19 Aug 2009 14:25:02
Message: <4a8c437e$1@news.povray.org>
Makes me think "you can't crank out scenes as fast as this baby could
possibly render them" :P
(Time to get POV-Ray running distributed renders on networked computers...)
Now where do I find a 3-phase 400 or 480 VAC power outlet... is that the
same as used for electric ovens? ;-)
Date: 19 Aug 2009 14:32:16
Message: <4a8c4530$1@news.povray.org>
Yup, SUSE all the way - a fair number of the larger MP supercomputers out
there run SUSE these days. :-)
Jim
Date: 19 Aug 2009 14:44:59
Message: <4a8c482b$1@news.povray.org>
We have 3-phase 480 here at work :-D
~Mike
Date: 20 Aug 2009 02:59:15
Message: <4a8cf443$1@news.povray.org>
In the UK at least normal domestic ovens use the standard single phase power
supply, they just usually have a dedicated cable and breaker at 40A or
whatever.  Ditto with electric showers.  On commercial sites it's quite
common as a lot of even small industrial equipment is designed for 3 phase.
At work we have a 1m^3 enviromental chamber that runs off a 3 phase 20A
supply, has one of those big chunky round plugs that makes you feel like it
actually does something :-)
However I heard in Germany that it's quite common to have 3-phase delivered
to your house, so maybe some more powerful devices make use of this? I don't
know, will need to investigate at home :-)
Date: 20 Aug 2009 03:58:08
Message: <4a8d0210$1@news.povray.org>
Server Error in '/' Application.
Runtime Error
Description: An application error occurred on the server. The current
custom error settings for this application prevent the details of the
application error from being viewed remotely (for security reasons). It
could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be
viewable on remote machines, please create a <customErrors> tag within a
"web.config" configuration file located in the root directory of the
current web application. This <customErrors> tag should then have its
"mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
     <system.web>
         <customErrors mode="Off"/>
     </system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom
error page by modifying the "defaultRedirect" attribute of the
application's <customErrors> configuration tag to point to a custom
error page URL.
<configuration>
     <system.web>
         <customErrors mode="RemoteOnly"
defaultRedirect="mycustompage.htm"/>
     </system.web>
</configuration>
Does anyone else find this amusing? ;-)
Date: 20 Aug 2009 05:27:48
Message: <4a8d1714$1@news.povray.org>
> delivered to your house, so maybe some more powerful devices make use of
> this? I don't know, will need to investigate at home :-)
Indeed, in Germany the common electric oven runs on 3-phase. They don't
come with a plug & socket though, just a plastic box on the wall with
screw terminals.
The standard mains 230V is derived from the 3-phase by simply taking one
of those phases vs. N (via a max. 10A breaker).
