POV-Ray : Newsgroups : povray.off-topic : how to scheme a cat up? Server Time
24 Jul 2026 09:58:51 EDT (-0400)
  how to scheme a cat up? (Message 21 to 22 of 22)
Subject: Re: how to scheme a cat up?
Date: 20 Aug 2009 05:45:50
Message: <4a8d1b4e$1@news.povray.org>
In article <4a8c516d$1@news.povray.org>,
nemesis wrote:
> PLT is amazing, an excellent choice.  I hope you also knows how to
> use the combination keys for easily navigating/editing Lisp code:
> alt+up/down to go up/down a parenthetical level, alt+left/right to
> go to the next beginning or end, combine with shift to select and
> copy/paste at will.  Turns editing Lisp code a breeze and almost as
> good as with emacs.
Hm. In DrScheme? I'm not using it. I only use mzscheme and I write the
code in anything. Usually on emacs.
> In recent years, many excellent performant and compliant with the
> latest language standard, R6RS, showed up: ikarus and ypsilon come
> to mind.
R6RS is sorta like POSIX or more sorta like ANSI C?
>> Can you give me a word on portability?
> Sure:  many Scheme implementations are pretty portable. :)
The implementation itself? I meant the scheme code itself. So that if
I move from mz to $y scheme, then my code would still run. If there is
a document saying which functions are likely to be common among
certain implementations, then that could be my favorite subset of
documentation. (I'll be reading the r6rs web document after posting
this.)
>> On UNIX, I use POSIX as a reference, even though I
> Forget about low-level system access.  Leave that to C.
I meant it as an analogy. When I'm working directly with UNIX, then
POSIX is a good document. Not to be followed, I say, but to be
noticed.
>>> #!r6rs
>>> (import (rnrs base)(rnrs io simple)(rnrs programs))
>>> ; simple and straightforward standard R6RS scheme solution
>>> (define (cat files)
>>>   (for-each
>>>     (lambda (file)
>>>       (call-with-input-file file
>>>         (lambda (port)
>>>           ; no simple line-oriented IO in standard R6RS
>>>           ; so you either write one or loop char-by-char
>>>           (let go ((c (read-char port)))
>>>             (if (not (eof-object? c))
>>>               (begin
>>>                 (write-char c)
>>>                 (go (read-char port))))))))
>>>     files))
>>> (cat (cdr (command-line)))
>> I've kinda been able to read this; which is cool. But I don't really
>> get the purpose of ``go'' here.
> let creates lexical scopes.  It's actually just a macro.
So a lexical scope is a scope from the point of view of a macro? To a
C programmer, the analogy would be scope of variables defined by a cpp
macro?
> (let ((x 2)) (+ 1 x))
> turns into:
> ((lambda (x) (+ 1 x)) 2)
That's instructive. There's probably a macro to expand macros? That be
even more instructive.
> (let label (bindings ...) ...) is called a named let.  It turns the let
> body into a full fleged local function of name label.
Interesting. So let can be used to also group statements, right? For
example, (let () (+ 1 1) (* 3 4)). But what I have in mind is i/o,
which is where a sequence of isolated statements makes more sense.
(let () (display "this ")
        (display "could help ")
	(display "an imperative typa guy\n"))
> It's most immediate use is to create loops out of functions calls, since
> as you know, there's no such builtin looping facility in functional
> languages.
Makes sense. When people are functional, they don't run in circles.
> I could have defined an inner or outer function named go or whatever,
> but simply used let.  The normal let bindings turn into parameters with
> initial values for the function.  Thus,
> calls the function again.  Beware that many people enjoy creating such
> loops like (let loop (...) ...) but the label may be any of your choice.
So (go) was a function, with an initial value in c. Cool. Now it makes
perfect sense. Load another c, and continue.
>   Also, the body may sport several exits as stop condition.
I'm yet to see how to break out of loops. I mean, recursion. That is,
I'm yet to find out how to return earlier. That appears to be simply
to protect the region of code that would run in case whe need not
return earlier. So if eof shows up, then the usual block of code does
not run, and the last statement of the function runs which is its
return statement. IOW, we never break out; we simply get faster to the
end of the function. True?
>> Hey, looking at this very old cat, I can see that Warp is going to say
>> that our cats aren't cats after all; we don't read the stdin. And
>> he'll be right.
> Bah, just a matter of reorganizing a bit adding a short if before for-each:
> (define (cat files)
>    (define (process port)
>            (begin
>              (write-char c)
>    (if (null? files) (process (current-input-port))
>        (for-each
>         (lambda (file) (call-with-input-file file process))
>         files)))
I don't think that's going to satisfy Warp, even though I just met
her, or him. Because, although you appear to listen to the stdin if no
files are given, a real cat would also pay attention to a file named
Changing subject. It is ugly to assign functionality to file names,
but it is much more likely, I say, that we will eventually need to
read a couple files plus the stdin, than to name a file as -.
Date: 20 Aug 2009 14:14:50
Message: <4a8d929a@news.povray.org>
Daniel Bastos escreveu:
Then you are well served anyway.
>> to mind.
ANSI C, of course.  There are several POSIX in the Scheme world, it's
the libs particular to a given implementation.
> this.)
R6RS is the latest standard, many implementations are using it already.
  R5RS is more supported in some of the most robust out there, including
Gambit and Bigloo.  R5RS is far less modular, there's only a single
namespace.  Standard modules from R6RS are truly the single best
addition to the language in a long time, though you could of course
create ad hoc modules based solely on lexical scoping...
>>>> #!r6rs
>>>> (define (cat files)
>>>>   (for-each
>>>>     (lambda (file)
>>>>         (lambda (port)
>>>>               (begin
>>>>                 (write-char c)
>>>>     files))
> macro?
No, nothing to do with macros, macros don't know about types or scope,
just symbol substitution.
I suggest you read about scoping somewhere.  In C, there's only global
scope, local scope and static scope per compilation unit.  Basically,
lexical scope is the scope as it appears in the source text:  inner
variables are only seen by inner functions, to find the value of a
variable you just need to look it up in the chain of definitions as
written in source code.  Like:
(let ((a 1))
   ; a seen here
   (let ((b 2))
     ; a and b seen here
     (+ a b))) ; -> 3
Lexical scoping as introduced by Algol comes into play once you
understand how it was done before with dynamic scoping, like in elisp
still today.  You could, for instance:
(define (foo) (+ 1 a))
(let ((a 2))
   (foo))
and it would work.  Fact is that it doesn't work under lexical (also
called static) scoping because at the time of foo's definition, there's
no variable a in scope.
BTW, if instead of let you use define a, it works.  define does not
introduce lexical scope, it plainly modifies the global scope and, as
you know, side effects are bad. ;)
>> turns into:
Go easy on macros, it can be brain damaging... :)
but you can indeed call macros inside other macros.
Those are not statements, those are expressions and only the value of
the last one is returned from such a sequence.  But yes, you can use
let.  It's exactly like the body of a function in that you can have a
sequence of arbitrary expressions, still only the value of the last is
returned.
yes, or begin, another macro.
>> languages.
There's only functions and function calling.
yes, if it's not eof, then write the char and go again with another char. :)
well, but I've shown you:  when it's eof, it stops.  It only further
recurses if there's another char read.
You're still thinking about a C call stack here.  go is the last thing
done in the body, it's in tail position and thus it's tail call
optimized to remove call stacks.  It return imediatelly, there's no call
stack rewinding because there's no stack growth.
But this example is essentially a loop for the purpose of side-effect
only, it doesn't need a return value.  If you needed one, you could
simply rework it a bit:
(if (eof-object? c) my-return-value
    else-expression)
you could make it check if file is a "-" before calling process in the
for-each loop and if it is, call (current-input-port).
BTW, perhaps you could use the comp.lang.scheme newsgroups to obtain
more suited answers...
a game sig: http://tinyurl.com/d3rxz9
