POV-Ray : Newsgroups : povray.off-topic : how to scheme a cat up? Server Time
24 Jul 2026 08:27:35 EDT (-0400)
  how to scheme a cat up? (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: how to scheme a cat up?
Date: 19 Aug 2009 06:20:32
Message: <4a8bd1f0$1@news.povray.org>
Invisible wrote:
> I'm guessing the real cat program also has assorted command-line
> switches as well though?
OK, so let's ask the manpage:
http://unixhelp.ed.ac.uk/CGI/man-cgi?cat
[BTW, Google for "man cat" turns up some, uh, /interesting/ results
before this one.]
I'll see if I can't produce a full implementation...
Date: 19 Aug 2009 08:52:55
Message: <4a8bf5a7$1@news.povray.org>
Apparently POSIX only specifies the -u option; the rest is extensions.
(Common ones though, apparently.) This is apparantly typical for all
widely-known Unix commands. I guess we can thank 40,000,000 years of
backwards compatibility for that.
The attached program appears to do the job. There are probably still
some bugs in it though.
[I definitely can't guarantee it works the same as GNU cat, because I
don't have anything to test against. It's probably broken in it's
handling of "\n" and/or "\r", the line numbering, the text/binary
distinction, and a few other things.]
Download 'us-ascii' (5 KB)
Date: 19 Aug 2009 09:10:01
Message: <4a8bf9a9$1@news.povray.org>
And back then, primitive humans really enjoyed watching the monkeys work
the abacuses while a cat command was being executed. Or was that
primitive humans really enjoyed watching the monkeys execute a cat?
I can't remember. That was a long time ago ;)
~Mike
Date: 19 Aug 2009 10:33:58
Message: <4a8c0d56$1@news.povray.org>
In article <4a8b7a38@news.povray.org>,
Daniel Bastos wrote:
> This cat does not handle exceptions. I might see how that works next.
Looks like this suffices.
(define (sigint v)
  (fprintf (current-error-port) "^C\n"))
;main
(with-handlers ([exn:break? (lambda (v) (sigint v))])
  (cat (vector->list (current-command-line-arguments))))
It's interesting that I need to (exit) from sigint. What if I would
like to ignore that signal, or continue somehow? No idea what to do.
Hey, if you're very curious, there's some information in v. :-)
Date: 19 Aug 2009 11:00:49
Message: <4a8c13a1$1@news.povray.org>
In article <web.4a8b9c8c606eeda4cb3dd3d0@news.povray.org>,
nemesis wrote:
> Daniel Bastos <dbastos+0### [at] toledocom> wrote:
>> #!/usr/bin/env mzscheme
>> (module cat scheme/base
>> (define (interact f)
>>   (let ([ln (read-line)])
>>      (cond
>>       [(not (eq? ln eof))
>>          (and
>>     (printf "~a\n" (f ln))
>>     (interact f))])))
>> (define (id x) x)
>> (define (cat files)
>>   (for-each
>>    (lambda (x)
>>      (with-input-from-file x
>>        (lambda ()
>>   (interact id))))
>>    files))
>> ;main
>> With with-input-from-file, we get the stdin connected to the file
>> opened, so no changes in interact were required.
> That's the PLT way.  here's another:
By the way, I'm studying Scheme through PLT due to a clue from
authority, which I gathered. I absolutely know nothing about
implementations, but I saw this guy who seems to do his homework using
PLT, so instead of MIT, I picked PLT. Clearly at this point it doesn't
matter, but I already think about portability. Can you give me a word
on portability? On UNIX, I use POSIX as a reference, even though I
don't consider it a standard in a profound way; it works as a document
to help me understand what is like to be common out there. I'd like
that in Scheme.
> #!r6rs
> (import (rnrs base)(rnrs io simple)(rnrs programs))
> ; simple and straightforward standard R6RS scheme solution
> (define (cat files)
>   (for-each
>     (lambda (file)
>       (call-with-input-file file
>         (lambda (port)
>           ; no simple line-oriented IO in standard R6RS
>           ; so you either write one or loop char-by-char
>           (let go ((c (read-char port)))
>             (if (not (eof-object? c))
>               (begin
>                 (write-char c)
>                 (go (read-char port))))))))
>     files))
> (cat (cdr (command-line)))
I've kinda been able to read this; which is cool. But I don't really
get the purpose of ``go'' here.
>> Lisp likes might be hackestables.
> I just love Lisp, Scheme in particular.  Minimalist like C, only much higher
> level.  Incidentally, the only two languages I truly enjoy, for different
> purposes sure.
Same here.
> yes, I'm aware the C solution for this particular example would be way
> shorter... :P
I see it as the same thing; there isn't anything very high level about
cat that could really be taken advantage of a very high level language.
Here's the essence of cat from AT&T UNIX version 7.
while (--argc > 0) {
  if (fflg || (*++argv)[0]=='-' && (*argv)[1]=='\0')
  	fi = stdin;
  else {
  	if ((fi = fopen(*argv, "r")) == NULL) {
  		fprintf(stderr, "cat: can't open %s\n", *argv);
  		continue;
  fstat(fileno(fi), &statb);
  if (statb.st_dev==dev && statb.st_ino==ino) {
  	fprintf(stderr, "cat: input %s is output\n",
  	   fflg?"-": *argv);
  	fclose(fi);
  	continue;
  while ((c = getc(fi)) != EOF)
  	putchar(c);
  if (fi!=stdin)
		fclose(fi);
Hey, looking at this very old cat, I can see that Warp is going to say
that our cats aren't cats after all; we don't read the stdin. And
he'll be right.
Date: 19 Aug 2009 11:07:16
Message: <4a8c1524$1@news.povray.org>
In article <4a8bba80$1@news.povray.org>,
Invisible wrote:
> Warp wrote:
>>   'cat' is a program for concatenating files. It's used like:
>> cat file1 file2 file3 > concatenated_files
>>   Your program does not fulfill this role.
>>   (Some people abuse 'cat' to concatenate one single file with nothing,
>> but that doesn't mean that the role of 'cat' is anything else than
>> concatenating files.)
> Interesting. I thought it was for concatenating a file to stdout...
It is. :-) In the same order in which they are read.
> Alrighty then:
>    import System.Environment
>    main = do
>      args <- getArgs
>      mapM_ (\arg -> readFile arg >>= putStr) args
> That seems to work.
Your cat has a disease, common in recently seen cats, the makes it
ignore the stdin.
Date: 19 Aug 2009 11:10:43
Message: <4a8c15f3@news.povray.org>
In article <4a8bf5a7$1@news.povray.org>,
I can't even say -u is really necessary.
That program is no cat. That's Garfield.
Date: 19 Aug 2009 15:24:29
Message: <4a8c516d$1@news.povray.org>
Daniel Bastos escreveu:
PLT is amazing, an excellent choice.  I hope you also knows how to use
the combination keys for easily navigating/editing Lisp code:
alt+up/down to go up/down a parenthetical level, alt+left/right to go to
the next beginning or end, combine with shift to select and copy/paste
at will.  Turns editing Lisp code a breeze and almost as good as with emacs.
> implementations,
Far too many to know.  It's a minimalist language and several people for
several years tried their hands into making something unique, with
unique frameworks for it.  Some of the bigger and best: PLT, Gambit,
Bigloo, Chez, SISC etc.  In recent years, many excellent performant and
compliant with the latest language standard, R6RS, showed up:  ikarus
and ypsilon come to mind.
> on portability?
Sure:  many Scheme implementations are pretty portable. :)
Use what the implementation provides for system level access and you
should be fine.
Forget about low-level system access.  Leave that to C.
> that in Scheme.
>> #!r6rs
>> (define (cat files)
>>   (for-each
>>     (lambda (file)
>>         (lambda (port)
>>               (begin
>>                 (write-char c)
>>     files))
let creates lexical scopes.  It's actually just a macro.
(let ((x 2)) (+ 1 x))
turns into:
((lambda (x) (+ 1 x)) 2)
(let label (bindings ...) ...) is called a named let.  It turns the let
body into a full fleged local function of name label.
It's most immediate use is to create loops out of functions calls, since
as you know, there's no such builtin looping facility in functional
languages.
I could have defined an inner or outer function named go or whatever,
but simply used let.  The normal let bindings turn into parameters with
initial values for the function.  Thus,
calls the function again.  Beware that many people enjoy creating such
loops like (let loop (...) ...) but the label may be any of your choice.
  Also, the body may sport several exits as stop condition.
There's no stack growing because of that last call, since the last call
is the call to the function itself.  It's in tail position and suffers
an optimization called tail call elimination, which instead of actually
creating a new call stack, it replaces the current arguments with the
new arguments and goes to the first instruction again.  It can do it
because it's in tail position, it's the last thing done in a function
body and it can be proved that no value other than the final value is
needed for the return of the function as whole.  So, no need for a stack.
If the last call was something like (+ 1 (go ...)) than the call to go
would not be in tail position because some expression is expecting the
value it returns.
>> shorter... :P
>   	fi = stdin;
>   	putchar(c);
>   if (fi!=stdin)
> 		fclose(fi);
that is the short essence without error handling. :)
> he'll be right.
Bah, just a matter of reorganizing a bit adding a short if before for-each:
(define (cat files)
   (define (process port)
           (begin
             (write-char c)
   (if (null? files) (process (current-input-port))
       (for-each
        (lambda (file) (call-with-input-file file process))
        files)))
perhaps you should add (rnrs io ports) to the import list.
If you want to know more about Scheme:
http://www.r6rs.org/
http://schemers.org/
a game sig: http://tinyurl.com/d3rxz9
Date: 19 Aug 2009 17:36:19
Message: <4a8c7052@news.povray.org>
  I think you have way too much time on your hands... :P
Date: 20 Aug 2009 04:05:58
Message: <4a8d03e6$1@news.povray.org>
You *think*?!
I thought we already settled this one, many years ago. ;-)
Besides, it's not a very long program, and I haven't actually tested it
properly. (As you probably know, testing typically takes a really long
time.)
