POV-Ray : Newsgroups : povray.off-topic : New Computer Server Time
15 May 2026 18:54:48 EDT (-0400)
  New Computer (Message 31 to 40 of 79)
Subject: Re: New Computer
Date: 14 Aug 2009 02:31:47
Message: <4a8504d3@news.povray.org>
Chambers schrieb:
> Still, it's my first quad core machine, and I'm excited about it :)
You have reason enough to be. Two months ago, I was still working with a
P4, and was still so excited about the AMD Phenom 2 I had bought half a
year ago (as a dedicated Linux/POV-Ray rendering machine :-P) that I was
about to opt for another Phenom for Windows work, too (for a less
frustrating modelling experience :-)). Fortunately the guy at the local
store talked me into buying an i7 instead, but I'm convinced the Phenom
would have done about as well for quite a few years, too, and I would
have left me just as excited ;-)
If it wasn't for the modelling and raytracing, I could have lived
happily with that P4 for another year or two: It's just about the
computing power I needed for everything else, including software
development. If it wasn't for games, I'd say a fast P4 (I had already
upgraded it to the fastest I could get) is as much computing power as
any sane person could possibly need.
... and we have way over 4 times that power on or under our desks - Gee!
Date: 14 Aug 2009 02:55:20
Message: <4a850a58$1@news.povray.org>
Saul Luizaga wrote:
  > but since my budget is smaller I think I'll have to saddle for an
Phenom
> X3 2.33 Ghz, 4GB DDR2-1066, SEAGATE/MAXTOR 500GB 7200 RPM SATA II HDD.
I very nearly went for the x3, but since I was planning to upgrade it
eventually anyway I figured there was no point in buying two processors
for it.
I might as well get the one I wanted to begin with, and save the money
by not buying the other :)
...Chambers
Subject: Re: Thank you!
Date: 14 Aug 2009 03:12:46
Message: <4a850e6e@news.povray.org>
TC schrieb:
> I find the results rather shocking - I would not have guessed that switching
> from 32 to 64 bit would make such a difference.
Neither would I. I had expected the difference to be quite marginal,
having thought that the only significant benefit of 64-bit was in making
more memory available for a single application.
> Since you seem to be intimately involved in Pov Ray beta testing,
I actually consider myself more involved in development than in testing,
but of course I need to test what I have implemented, so yes.
 > maybe you
> can answer the question if the benchmark makes extensive use of memory.
> Maybe the difference between 3 and 6 GB would account for the difference
> between 32/64 OS.
Definitely not - I just checked: While rendering the benchmark, POV-Ray
is utilizing just about 30 MB more than when idle.
I've actually never ever managed to reach even the 2 GB limit on my old
32-bit machine (well, it didn't have more installed anyway). On the
64-bit Linux machine, the worst thing I ever observed was about 700 MB
continuous load with a peak of 800 MB during parsing, IIRC (which was
actually a problem, becaue I had only 4 GB installed at that time, and
was running a full-throttle MegaPOV render - i.e. four separate
instances of POV-Ray. The initial peak memory load kicked the whole
system into "permanent swapping mode", with the MegaPOV instances
busying themselves kicking each other (and of course everything else)
out of physical memory instead of doing anything productive. Operating
the system was of course no fun anymore until I had managed to pause one
of the processes. Sustained memory load was low enough that I could
ultimately resume the fourth process again, but startig them up
simultaneously was too much.)
Date: 14 Aug 2009 03:50:10
Message: <4a851732@news.povray.org>
Chambers wrote:
> Saul Luizaga wrote:
>  > but since my budget is smaller I think I'll have to saddle for an Phenom
> for it.
> ....Chambers
Notice that my Phenom is not Phenom II, just Phenom.
Well if you need the money... but since we POV-Ray you might regret it
later :)
Date: 14 Aug 2009 05:26:05
Message: <4a852dad$1@news.povray.org>
I have made a little research in www.amd.com and the improvements of
Phenom II over Phenom are: Socket AM3, DDR3, +2/+4 MB L3 Cache. I think
I'll make the jump and go for a Phenom II X3 2.8, 6MB L3, 4GB DDR3-1333.
I can't go for the X4 since is only 2.6 and 4MB L3, each core in the X3
will run more efficiently than the ones in the X4, and compensate for
the +2 Ghz of the X4, me thinks.
Date: 14 Aug 2009 05:33:35
Message: <4a852f6f$1@news.povray.org>
Another small improvement is +3.9 Ghz in memory bandwidth due to DDR3.
Date: 14 Aug 2009 06:15:35
Message: <4a853947$1@news.povray.org>
>>> Has anyone ever run the benchmark on an abacus?
>> No, but now I have the urge to create an electromechanical computer
>> and run the benchmark on that.
> Are you aware how many relays you'll need to even store the rendered
> image? :P
> Even a device able to compute a b/w image of a RSOCP would be enough of
> a challenge I guess...
Who said anything about *store*? You could make it output the binary
data to some kind of storage device.
I would suggest that if you want hardware floating-point support, you're
still going to need an absurd number of relays though. ;-)
Date: 14 Aug 2009 06:16:09
Message: <4a853969$1@news.povray.org>
> Ah, the Babbage Computational Engine :)
I think you'll find that was mechanical, not electromechanical. :-P
Date: 14 Aug 2009 08:24:46
Message: <4a85578e$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4a848a81$1@news.povray.org...
> I also heard tell there may also be differences between OS. I'm running XP
> Pro x64, maybe Vista or Win7 do an even better job at making use of HT.
> Don't know about this though.
      No, Vista Home is exactly the same time.  :)
      Win7 may be better though.
      ~Steve~
Date: 14 Aug 2009 11:30:20
Message: <4a85830c$1@news.povray.org>
> image? :P
We have lots of empty space in the warehouse, right now. ;)
Definitely. It would be quite fun to build a simple processor like that,
though
~Mike
