Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> On the other hand, radio waves are *so* big they go thru lots of inter-atom
>> holes at once (like a wave going past a row of pylons holding up a pier) and
>> hence will go thru walls where visible light won't.
> I don't think it's as simple as the wavelength determining how well
> electromagnetic radiation can traverse through matter. For example, x-rays
> have a shorter wavelength than visible light, yet x-rays have more penetration
> through matter.
I think the way it works is this:
X-rays actually are small enough to go between the atoms (altho they'll
still interact with the electrons, which is why metal still stops them,
having a "sea" of electrons on the surface).
Visible light hits (most) atoms and gets absorbed, reflected, etc.
Radio waves are physically bigger than the atoms (and the whole house, for
that matter) so they basically are ghosting along like a car through air.
If you have a stiff screen with water waves going thru, waves much smaller
than the holes will go thru, and waves much bigger than the holes will go
thru all the holes at once and reform on the other side. Waves bigger than
the holes but smaller than two holes will mostly bounce.
The higher the frequency, the "smaller" the photon is physically (as in, the
more precisely you can know its position).
At least, that's the naive layman understanding I use to sound like I know
what I'm talking about in newsgroups. ;-)
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
Of course it gets more complicated when you consider that some materials
let visible light through (such as glass) while other materials don't, even
though their density might be the same.
On Sat, 01 Aug 2009 14:29:00 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
>Listening to some music, I observe that most of the drumbeat sounds
>appear to be in the region below 200 Hz.
>Wolfram Alpha tells me [EVENTUALLY!] that a 200 Hz sound has a
>wavelength of about 170 cm.
>Question: Since the doorway to be bedroom is less than 170 cm wide, does
>that mean those waves can't leave the room? Or does the fact that it's
>more than 170 cm tall negate that?
Sound waves are compressional (is that a word?) and rely on a medium to travel
in.
So tell your mother that she can't possibly be hearing them. ;)
Regards
> in.
Because Andy's mum is not a medium?
>> in.
If she were then Andrew could give her a drink then punch her. Which would be
striking a happy medium. :P
Regards
Here I'd rather view them as photons, to whom I do not want to attach a
size. Perhaps the wavelength can be used to "fake" a size of the photon,
though.
Keep in mind that everything I say is a bit of guessing and not
actually studied (well, not all of it at least).
Essentially, an electron in an atom will usually absorb a photon only
if the photon has an energy such that there is an available energy level
for the electron to go to. For insulators, that means it will (usually)
have to cross the band gap. For metals, there is no (initial) band gap
and so electrons of low frequency are readily absorbed. Perhaps that's
why metals can easily get in the way of radio waves?
However, I think there are higher bandgaps in metals, and so photons of
a certain energy range will pass through.
(Insulators also have higher bandgaps).
There's no "true" reflection. Quoting Wikipedia:
"Light waves incident on a material induce small oscillations of
polarisation in the individual atoms, causing each atom to radiate a
weak secondary wave (in all directions like a dipole antenna). All of
these waves add up to specular reflection..."
For stuff like refraction, essentially, the material will get polarized
by the fields of the photons trying to pass through it. This will result
in internal electric fields that interact with that of the photon, and
result in a reduced speed, change in direction, etc. Essentially, the
relative permittivity that we used in physics courses is simply a model
of the effect of polarization on the external waves.
I find it disturbing that Wikipedia's article on refraction has no
actual physical explanation, but I suspect I'm close.
> for that matter) so they basically are ghosting along like a car through
> air.
For me, I'd prefer to view it more in terms of photons interacting
electrically with the solid (and/or taking into account the band
structure) rather than size. Although as I said, perhaps one could
produce an "effective" size which matches both what you say and the
actual theory - although there may be materials that fail the "size"
theory.
When I studied solid state physics, we didn't cover interactions with
light. And I never thought to see if there was a pattern between lattice
constants (the spacing between atoms in the crystal), and their band
energies. I actually expect that the relationship between the band
energies/gaps and lattice constant is poor/nonexistent - which may
weaken your approach of using size for intermediate frequencies.
Kotter: "Have you ever considered becoming a vet?"
Epstein: "Uh...Uh no. My brother Sanchez was in the army. Didn't like it
a bit."
Does science even fully agree on the physics of refraction?
Don't really know. However, I think it does agree on the physics behind
refractive index. It's just a function of the permittivity, which
electromagnetics precisely describes (in terms of waves). I don't know
if there's a "particle" explanation.
a bit."
> behind refractive index. It's just a function of the permittivity, which
IIRC, it's accurate enough that predictions of refraction based on
permittivity yield correct results, even for fringe cases like negative
or really high indices of refraction.
Chambers
"Warp" <war### [at] tagpovrayorg> wrote in message
news:4a75aa3e@news.povray.org...
no
Yes, AFAIK, but the "problem" is that there are many levels of
understanding. Our everyday experiences can be a hindrance when trying to
understand things at a more "fundamental" level. Refraction (reflection,
dispersion, ...etc) are all emergent and not fundamental processes in QFT,
for instance. There, all you have are 1) emission of a photon 2) absorption
of a photon and the boring case of 3) unhindered transmission of a photon.
There's practically no common ground as far as the fundamental processes go
with classical wave mechanics. But it turns out, that within applicable
domains, their conclusions/predictions agree, and where they don't, we
realize we are out of the respective applicable domains.
