POV-Ray : Newsgroups : povray.off-topic : Turing determination Server Time
17 Jul 2026 02:29:42 EDT (-0400)
  Turing determination (Message 11 to 20 of 60)
Subject: Re: Turing determination
Date: 22 Jul 2009 14:17:59
Message: <4a6757d7@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> - What is the "most powerful" language for which you *can* tell is an
>> arbitrary program will halt?
> I forget what it's called, but basically anything with for loops instead
> of while loops does the trick. You have to rule out recursion also.
> Essentially, anything with indefinite loops is out, as far as I understand.
I believe it's called a "primitive recursive" language.
This is also relevant:
http://en.wikipedia.org/wiki/Total_functional_programming
Date: 22 Jul 2009 14:18:36
Message: <4a6757fc$1@news.povray.org>
Yes, that rings a bell. :-)
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 22 Jul 2009 14:27:42
Message: <4a675a1e$1@news.povray.org>
news:4a671eb6@news.povray.org...
> Invisible <voi### [at] devnull> wrote:
> > It's common knowledge that if you write an arbitrary program in a
> > Turing-complete programming language, it is impossible to determine
> > whether the program will ever halt.
>   That's not stated correctly. It's impossible to create an algorithm
which
> would tell for all possible programs whether they terminate or not.
Even so, one has to be careful, for it's possible to determine if any such
finite program will halt or not - just run the program until all possible
states would be exhausted.
Date: 22 Jul 2009 14:55:19
Message: <4A676097.3020908@hotmail.com>
On 22-7-2009 18:24, Darren New wrote:
>>>> an arbitrary program will halt?
>>> instead of while loops does the trick. You have to rule out recursion
>>> also. Essentially, anything with indefinite loops is out, as far as I
>>> understand.
>> So no GOTO then?
> Forward goto, sure. :-)
define forward
>> Basically, anything where flow control is data-dependent?
> No. Well, yes, in a sense. You're trying to simplify something that's
> already trivially simple, and in so doing just raising questions about
> what you mean by your version of the words.  "Indefinite loops are out."
> A loop you can't look at and tell at compile time the maximum number of
> times it'll loop is an indefinite loop. While loops are not indefinite
> loops if you can tell at compile time how often they'll loop: See
> Eiffel's loops, for example.
> Recursion is OK as long as you have an upper bound on how often you
> recurse, somehow.
>> Seems to me that almost anything remotely useful to know is undecidable.
> Only on unbounded computers.
Perhaps also things that are decidable are not really useful to know.
Example: you are going to die. See, not a bit of information added to
the common knowledge, but is was decidable.
Date: 22 Jul 2009 14:58:28
Message: <4A676153.2010902@hotmail.com>
> which
Why would the number of states be finite and why do you assume determinism?
Date: 22 Jul 2009 15:05:45
Message: <4a676309$1@news.povray.org>
Am Wed, 22 Jul 2009 20:55:19 +0200 schrieb andrel:
>>> So no GOTO then?
> define forward
Higher adress than current one in sequential memory?
Date: 22 Jul 2009 15:15:13
Message: <4A676541.4010800@hotmail.com>
>>>> So no GOTO then?
>> define forward
Physical memory or logical?
Date: 22 Jul 2009 15:24:34
Message: <4a676772@news.povray.org>
  A finite program might never exhaust all possible states with unbounded
memory.
Date: 22 Jul 2009 15:27:49
Message: <4a676835$1@news.povray.org>
Am Wed, 22 Jul 2009 21:15:13 +0200 schrieb andrel:
>>>>> So no GOTO then?
>>> define forward
Logical and assuming the program and the MMU doesn't do "nasty" stuff :).
Date: 22 Jul 2009 15:56:12
Message: <4A676EDB.2090603@hotmail.com>
>>>>>> So no GOTO then?
>>>> define forward
I think we can safely assume that the program is in one block, or are
there systems where parts of programs van be in more than one segment?
Also assume that you can not execute something in a data or stack segment.
We have nearly pinned it.
Now we only have to make sure a compiler leaves the order of the
statements in place or it knows compile time where everything will end
up. Shouldn't be too difficult.
Codebuster's verdict: possible.
